Video decoding issue when running FutureMark PCMark for Android
175
Posted at 5/21/2015 07:53:32      View:3285 | Replies:7        Print      Only Author   [Copy Link] 1#
Firefly has an issue with video playback. This is a dump of the framebuffer during the video playback test of Futuremark PCMark for Android. It only shows a green screen, however I can see an outline of the video being decoded and diplayed so something else is wrong..
As a result in PCMark for Android by FutureMark the overall score is 0.
Same issue happens on Ugoos UT3.. leading me to think this is a low level driver issue that Rockchip needs to fix.
For reference, here is the Firefly 3DMark Ice Storm Benchmark: 7069
super moderator
Rank: 8Rank: 8
Posted at 5/21/2015 11:22:56        Only Author  2#
Hi , this maybe the problem of opengl es
does the app of  "Futuremark PCMark for Android"  use the opengl es for display ?
the resolution is  follow :
1 use the newest firreware or soucecode .
2 get two libs here : http://developer.t-firefly.com/f ... thread&tid=1088
3 put hwcom...so to /system/lib/hw/ by adb shell ,remember remount it first.
4 put  librkff..so to /system/lib/
5 reboot the board.
6 after the board is restarted, put this command in shell  :
    setprop video.use.overlay 0
then ,
start your app and test .
Posted at 5/21/2015 11:49:31        Only Author  3#
Thanks isle, your procedure fixed the issue. Will these changes be pushed to the SDK?
Attached are the two files: so others don't have to signup for the other forum..
hwcomposer rkffplayer.zip (119.42 KB, Down times: 14)
Yes, "PCMark for Android" is a benchmarking tool and it uses OpenGL ES for display.
Heres the results from "PCMark for Android" : 4087
super moderator
Rank: 8Rank: 8
Posted at 5/22/2015 10:11:53        Only Author  4#
when  the  "video.use.overlay"  is set to 0 . It whill slow down the  video display .
so we won't put these to the SDK.
we have reported this issue to rockchip ,But they have no schedule to fix it.
Posted at 5/22/2015 19:30:42        Only Author  5#
Use stageflight player instead of the rkffplayer, can display video on OpenGL texture.
setprop sys.ffmpeg_sf.switch 1
But stageflight player seems to not be able to play all of the video....
