New Topic
Enable The I2S MCLK
524
Posted at 2/4/2016 13:08:43        Only Author  11#
Hi sweckhoff,
Have you finally solved your problem?
Could you please share kernel sources?
I also have to connect external audio codec(SSM2603) to RK3128 and having "lots" difficulties.
vip
Rank: 6Rank: 6
Posted at 2/16/2016 17:01:11        Only Author  12#
jonsmirl Posted at 10/27/2015 05:07
The I2S section is also missing support for enabling an external I2S clock.
[size=13.63636302948px]try to add the following codec to enable I2s0 clk in rk30_i2s.c :
   i2s->clk_i2s_2ch_out = clk_get(&pdev->dev, "clk_i2s_2ch_out");
  if (IS_ERR(i2s->clk_i2s_2ch_out)) {
    dev_err(&pdev->dev, "Can't retrieve clk_i2s_2ch_out\n");
    ret = PTR_ERR(i2s->clk_i2s_2ch_out);
    goto err;
    clk_prepare_enable(i2s->clk_i2s_2ch_out);
Posted at 2/27/2017 04:51:48        Only Author  13#
Is 8 channel i2S accessible on external pins in RK3128 like RK3066 and RK3288 ?
Return to List
12
