Posted at 1/8/2016 02:16:10
Thanks very much.
Is it possible to fix the following bugs.
1. Bluetooth Headset Mic not working.
Solution is to disable internal mic first to route sound through Bluetooth headset mic.
Soundabout app from Google Play Store can do this correctly.
2. On some 4K TV's UHD resolution setting in Android Settings, Display causes users to get a black screen.
3. Feature - Use Ethernet connection but trick Android system to believe it is actually a wifi connection.
On Android KitKat you could install Xposed Framework and 'Fake Wifi' v1.7 module to do this.
This helps to download big games from Google Play Store that only download through a wifi connection.
It also helps some streaming apps that only work on phones/tablets with a wifi connection and not work with an ethernet connection.
4. Feature - Support for Xpoesed Framework Lollipop edition.
To install different modules to give Android extra features.
5.Hide HDMI State, set it to '0' instead of '1' permanently - Some streaming apps only work on phones/tablets without an HDMI connection.
6. On some TV's like Phillips users get green/purple screen colors on their TV's
7. Feature - TVHeadend support library & tv tuner modules and startup script to load modules.
8. USB Keyboard repeating keys bug. I'm not sure if this is fixable.
