mali gpu driver for X11 released!
844
Posted at 2/15/2016 14:19:17      View:8205 | Replies:4        Print      Only Author   [Copy Link] 1#
Hi all,
I just noticed that ARM released the mali gpu driver for X11. See: http://malideveloper.arm.com/res ... user-space-drivers/ under topic r6p0-02rel0 for Firefly
You probably also need to compile the corresponding kernel device driver. See: http://malideveloper.arm.com/res ... gpu-kernel-drivers/ withe same release r6p0-02rel0.
So finally GPU support for X11 should be available! Just hope someone can put some effort in to integrating and get this working for firefly!
Cheers -- mac_l1
Posted at 2/26/2016 19:10:30        Only Author  recommend
What needs to be done, as I posted before in http://bbs.t-firefly.com/forum.p ... =697&page=1#pid3499
With this release from ARM the current status is:
1) Kernel mali driver: just checked firefly's lollipop git repo and correct version is already included in lollipop kernel, so should work.
2) User space mali drivers for X11: binary libs made and released by ARM, downloadable. Don't know how linkable they are for what specific linux versions.
Still open, to do: the X11 DRIVERS
3) DRM driver - For X11 support you also need to build rockchip drm kernel driver. Seems there is one included in lollipop kernel of firefly's github (see https://bitbucket.org/T-Firefly/firenow-lollipop/src/95519f45c3214fb3b3547c9fdeca3cb8715d5210/kernel/drivers/gpu/drm/rockchip/?at=Firefly-RK3288),  or another one is provided in mminds github: https://github.com/mmind/linux-r ... vel/somewhat-stable. Tried the first one few months ago and that didnt build then, the latter one is probably made for kernel 4.x. If buildable, this gives some drm.ko file that offers a generic GPU rendering interface needed by X. So some work to be done here.
4) xf86-video-armsoc - You also need a X11 user-space display driver specific for that GPU, and this is provided in mminds github: https://github.com/mmind/xf86-video-armsoc/tree/packaging/debian. X11 server will load this driver to do the accelerated display stuff.
Besides these 4 drivers, maybe some generic X11 components need to be rebuild.
And again, basically, that's all ;-)
Just hope some hero developer is willing to put some effort into this and make it work!
已有 1评分Prestige +10 Money +11 Contribution +12 Pack up reason
psycmos + 10 + 11 + 12
View all ratings
Posted at 2/15/2016 17:15:19        Only Author  3#
Great !
Posted at 2/21/2016 22:29:01        Only Author  4#
Nice !!
Does anyone managed to use this driver ?
Do you guys know what to put on xorg.conf ?
Should the default firefly kernel support it. ?
Thanks !!
Posted at 3/6/2016 10:03:45        Only Author  5#
Hi all:
   If RK3288 gpu have gstreamer plugin for hw decode?
