Posted at 3/4/2016 11:56:49
Hello busybee !
First of all, thanks for your reply, I really appreciate it !
I see some recuring problems with users and the support of the firefly. Here are the main problems that I can spot
1) Why are there just old Ubuntu 14.04 images on the official repository ? According to my view of the firefly, it is a really great performing chip that could easily be used as a desktop replacement, and, If we use it as such, sometimes we need new libraries and software that are only available on new versions of Ubuntu. You could answer this question saying that I could build a new image of Ubuntu with any version I want, as explained on the wiki, but, as I've already read on this forum, there are some users that don't have the required knowledge to do it.
2) Why not support other linux distros ? Supporting other linux distros shouldn't be much different thant supporting Ubuntu, i.e, the process of building the Ubuntu image should be analogue to building any other linux distro. One example of this is that I've built an Arch Linux image following the firefly's Ubuntu wiki !
3) Why not create/update the kernel repository with at least a kernel 4.x ? Sometimes I have to use some functions and funcionalities that exists on kernel 4.x or plus and I couldn't still compile sucessfuly the mainline kernel using the VGA or HDMI output, so I'm still stucked with the stock kernel 3.10 of more than 3 years ago.
4) The forth point is more an advice. Generally, mali GPUs are a real pain in any arm based boards running linux. Why not use next time a more linux-friendly GPU, like the one Raspberry PI uses, which is well documented and the drivers are available ?!
Thank you, hope this discussion can give us better directions |
