How to add RK Kodi 16 Support to Firefly RK3288
Posted at 3/5/2016 11:33:36
Add this to Firefly SDK for Audio Pass-Through
- diff --git a/core/jni/android_media_AudioTrack.cpp b/core/jni/android_media_AudioTrack.cpp
- index ab38864..c387858 100644
- --- a/core/jni/android_media_AudioTrack.cpp
- +++ b/core/jni/android_media_AudioTrack.cpp
- @@ -68,6 +68,7 @@ struct audiotrack_callback_cookie {
- // keep these values in sync with AudioTrack.java
- #define MODE_STATIC 0
- #define MODE_STREAM 1
- +#define MODE_STREAM_DIRECT 2
- class AudioTrackJniStorage {
- @@ -333,6 +334,26 @@ android_media_AudioTrack_setup(JNIEnv *env, jobject thiz, jobject weak_this,
- -1, -1, // default uid, pid values
- paa);
- break;
- + case MODE_STREAM_DIRECT:
- + status = lpTrack->set(
- + AUDIO_STREAM_DEFAULT,// stream type, but more info conveyed in paa (last argument)
- + sampleRateInHertz,
- + format,// word length, PCM
- + nativeChannelMask,
- + frameCount,
- + AUDIO_OUTPUT_FLAG_DIRECT,
- + audioCallback, &(lpJniStorage->mCallbackData),//callback, callback data (user)
- + 0,// notificationFrames == 0 since not using EVENT_MORE_DATA to feed the AudioTrack
- + 0,// shared mem
- + true,// thread can call Java
- + sessionId,// audio session ID
- + AudioTrack::TRANSFER_SYNC,
- + NULL, // default offloadInfo
- + -1, -1, // default uid, pid values
- + paa);
- + break;
- default:
- ALOGE("Unknown mode %d", memoryMode);
- diff --git a/media/java/android/media/AudioTrack.java b/media/java/android/media/AudioTrack.java
- index 547d87e..ea56cc9 100644
- --- a/media/java/android/media/AudioTrack.java
- +++ b/media/java/android/media/AudioTrack.java
- @@ -92,7 +92,7 @@ public class AudioTrack
- /** Minimum value for sample rate */
- private static final int SAMPLE_RATE_HZ_MIN = 4000;
- /** Maximum value for sample rate */
- - private static final int SAMPLE_RATE_HZ_MAX = 96000;
- + private static final int SAMPLE_RATE_HZ_MAX = 192000;
- /** Maximum value for AudioTrack channel count */
- private static final int CHANNEL_COUNT_MAX = 8;
- @@ -116,6 +116,7 @@ public class AudioTrack
- public static final int MODE_STREAM = 1;
- + public static final int MODE_STREAM_DIRECT = 2;
- * State of an AudioTrack that was not successfully initialized upon creation.
- @@ -528,7 +529,7 @@ public class AudioTrack
- // audio load mode
- - if (((mode != MODE_STREAM) && (mode != MODE_STATIC)) ||
- + if (((mode != MODE_STREAM) && (mode != MODE_STATIC) && (mode != MODE_STREAM_DIRECT)) ||
- ((mode != MODE_STREAM) && !AudioFormat.isEncodingLinearPcm(mAudioFormat))) {
- throw new IllegalArgumentException("Invalid mode.");
Copy the code
Now you can build normal RK Kodi apk from this source
https://github.com/zidootech/zid ... zidoo-rk3368-16.0b4
It is also possible to rebase RK changes in above code to official Kodi Jarvis 16 Final branch and build it.
