Posted at 4/23/2016 00:19:39
Hi
Do you see Fire Easy setting in Android Settings?
I don't think the firmware was built with the Fire easy files to make it compatible.
You can flash custom Android firmware with 'Le Home Assistant' the same as Firefly than you can connect. But you need to flash your Firefly kernel & resource.img afterwards.
http://freaktab.com/forum/tv-pla ... p-rom-v1-4-by-mo123
You can use the AndroidTool v2.35, the last tab to split your Firefly Reloaded image into the separate images and then just flash those 2 images from the first tab of the flash tool after flashing the v1.4 custom firmware by using the second tab of the flash tool. |
