Plat-Dev-210考試重點 - Plat-Dev-210熱門認證
Posted at yesterday 23:34
從Google Drive中免費下載最新的Fast2test Plat-Dev-210 PDF版考試題庫:https://drive.google.com/open?id=1ypllh3Ghu0KPW9N3Xi57EvCItEFO5gPZ
IT行業中很多雄心勃勃的專業人士為了在IT行業中能更上一層樓,離IT頂峰更近一步,都會選擇Salesforce Plat-Dev-210這個難度較高的認證考試來獲取通認證證書從而獲得行業認可。Salesforce Plat-Dev-210 的難度比較高所以通過率也比較低。但是報名參加Salesforce Plat-Dev-210 認證考試是個明智的選擇,因為在如今競爭激烈的IT行業應該要不斷的提升自己。但是您可以選擇很多方式幫你通過考試。
Salesforce Plat-Dev-210 考試大綱:| 主題 | 簡介 | | 主題 1 | - Omnistudio Data Mappers: This part of the exam measures the skills of a Data Engineer and focuses on the use of Omnistudio Data Mappers for extracting, transforming, and loading data. It includes identifying the appropriate Data Mapper for a given requirement, as well as determining the necessary Extract, Load, Transform, and Turbo Extract functionalities based on specific use cases. This section ensures the candidate can effectively map and manipulate data to support business processes.
| | 主題 2 | - Omniscripts: This portion of the exam measures the skills of a Business Analyst and focuses on the use of OmniScripts to create dynamic, guided user experiences. It includes comparing and contrasting various OmniScript elements and their configurations to fulfill given use cases. The section also examines the candidate's understanding of the JSON structure that supports OmniScripts, as well as the ability to select appropriate elements and properties to address functional requirements effectively.
| | 主題 3 | - Integration Procedures: This section measures the skills of an Integration Architect and involves designing and configuring Integration Procedures to automate processes and integrate systems. It requires comparing and contrasting different elements and configurations within Integration Procedures to meet specific use cases. Candidates are also tested on selecting the correct elements and properties to satisfy functional requirements, ensuring seamless data flow and process automation.
| | 主題 4 | - Expression Sets & Decision Matrices: This section measures the skills of a Logic Designer and covers the configuration and application of Expression Sets and Decision Matrices within Omnistudio tools. It requires demonstrating an understanding of how Expression Sets evaluate conditions and how Decision Matrices use rule-based logic to determine outcomes. This knowledge is essential for automating decisions and streamlining complex business processes.
| | 主題 5 | - Integrated Troubleshooting and Deployment: This final section measures the skills of a Support Engineer and focuses on identifying and resolving issues within Omnistudio tools. It involves diagnosing errors based on given scenarios and determining where breakdowns occur in the data flow for specific customer issues. This ensures the candidate can effectively troubleshoot, debug, and maintain solutions to ensure optimal performance and reliability.
Plat-Dev-210考試重點將是您通過Salesforce Certified Omnistudio Developer的最佳選擇Fast2test的專業及高品質的產品是提供IT認證資料的行業佼佼者,選擇了Fast2test就是選擇了成功,Fast2test Salesforce的Plat-Dev-210考試培訓資料是保證你通向成功的法寶,有了它你將取得優異的成績,並獲得認證,走向你的理想之地。
最新的 Salesforce Developer Plat-Dev-210 免費考試真題 (Q66-Q71):問題 #66
A developer creates an OmniScript to update billing information. After analyzing the different types of customer interactions that occur at the company, the developer determines updating billing information should be included in the majority of customer interactions.
What should the developer use to configure the action that invokes the OmniScript?
- A. OmniScript Action
- B. Lightning Action
- C. Custom Action
答案:A
解題說明:
From OmniStudio Best Practices for Modular Script Design, OmniScript Actions are the preferred mechanism to invoke another OmniScript within a parent OmniScript. This approach enables reusability and modularization, especially when a function (like updating billing information) is common across many interactions.
* A. OmniScript Action - This is the correct and standard method for embedding or launching one OmniScript from another. It allows developers to reuse common scripts without duplicating logic.
Incorrect Options:
* B. Custom Action requires custom Apex or LWC development, which is unnecessary for this use case.
* C. Lightning Action is typically used to invoke OmniScripts from Lightning pages, not within OmniScripts themselves.
OmniStudio Developer Guide # OmniScript Actions
問題 #67
A developer needs to display the following information together on one FlexCard:
* Account name, address, phone number, website
* Primary contact first name, contact name, address, phone number, email The account information must always be visible, and the contact information should only be visible as needed by the user.
What approach should the developer use to display the contact information on the card?
- A. Use a Data table element
- B. Use a conditional FlexCard State
- C. Set the class'' collapsible'' on the block element
- D. Set the collapsible property on the block element
答案:D
解題說明:
Setting the collapsible property on the block element allows the user to expand or collapse the block as needed. Using a Data table element is not suitable for displaying contact information. Setting the class'' collapsible'' on the block element has no effect. Using a conditional FlexCard State requires a condition to be met, not a user choice.
問題 #68
When launching an OmniScript from an action on a FlexCard, the OmniScript displays, but no Salesforce data is populated:
Which two errors could cause this behavior?
Choose 2 answers
Choose 2 answers
- A. In the DataRaptor Extract Action, the Input Parameters Filter Value is misspelled.
- B. There is no active version of the Data Raptor Extract.
- C. There is non active version of the OmniScript
- D. The Id Field for Actions in the FlexCard is blank.
答案:A,D
解題說明:
The Id Field for Actions in the FlexCard specifies which field from the FlexCard data source will be used as the record ID for the OmniScript. If this field is blank, the OmniScript will not receive any record ID and will not be able to retrieve any Salesforce data. In the DataRaptor Extract Action, the Input Parameters Filter Value determines how to filter the data based on the record ID. If this value is misspelled, the DataRaptor Extract will not be able to match the record ID and will not return any data.
問題 #69
Refer to the exhibit below. What JSON code correctly represents the step in the OmniScript Structure panel shown?
答案:D
解題說明:
The JSON code correctly represents the step in the OmniScript Structure panel shown. The JSON code has the following properties:
* The type is "Step", which indicates that this is a step element in the OmniScript.
* The label is "Step 1", which matches the label shown in the panel.
* The name is "Step1", which matches the name shown in the panel.
* The elements property is an array that contains one element, which is a text field.
* The text field element has the following properties:
* The type is "Text", which indicates that this is a text field element.
* The label is "Text Field 1", which matches the label shown in the panel.
* The name is "TextField1", which matches the name shown in the panel.
* The value property is an empty string, which indicates that this text field has no default value.
問題 #70
A developer needs to create a list of cases for an account in a single Datable in a FlexCard. Like the one shown below.
How can the developer configure the FlexCard to display the case records in this way?
- A. Enable the record Looping feature on the data table elements
- B. Select the Repeatable Mode property on the data table elements
- C. Disable the Repeat Record feature on the FlexCard setup tab
- D. Enable the Repeat Records feature on the FlexCard Setup tab
答案:B
解題說明:
The Repeatable Mode property on the data table elements allows the developer to display multiple records in a single data table. The Repeat Records feature on the FlexCard Setup tab is used to display multiple FlexCards for each record in a data source. The Record Looping feature on the data table elements is used to iterate over a list of records and perform actions on each record. The Overwrite Target for all Null input checkbox on the Account id field is used to overwrite the existing value in the target object with null if the input value is null.
問題 #71
Fast2test為考生提供真正有效的考試學習資料,充分利用我們的Salesforce Plat-Dev-210題庫問題和答案,可以節約您的時間和金錢。考生需要深入了解學習我們的Plat-Dev-210考古題,為獲得認證奠定堅實的基礎,您會發現這是真實有效的,全球的IT人員都在使用我們的Plat-Dev-210題庫資料。快來購買Plat-Dev-210考古題吧!如果您想要真正的考試模擬,那就選擇我們的Plat-Dev-210題庫在線測試引擎版本,支持多個設備安裝,還支持離線使用。
Plat-Dev-210熱門認證: https://tw.fast2test.com/Plat-Dev-210-premium-file.html
- 高質量的Plat-Dev-210考試重點,免費下載Plat-Dev-210考試資料幫助妳通過Plat-Dev-210考試 🐩 免費下載▶ Plat-Dev-210 ◀只需在▛ [url]www.testpdf.net ▟上搜索Plat-Dev-210考試證照[/url]
- 高質量的Plat-Dev-210考試重點,免費下載Plat-Dev-210考試資料幫助妳通過Plat-Dev-210考試 🦍 複製網址【 [url]www.newdumpspdf.com 】打開並搜索▷ Plat-Dev-210 ◁免費下載Plat-Dev-210認證題庫[/url]
- 最好的Salesforce Plat-Dev-210考試重點是行業領先材料&無與倫比的Plat-Dev-210熱門認證 🍣 免費下載➤ Plat-Dev-210 ⮘只需在“ [url]www.vcesoft.com ”上搜索Plat-Dev-210熱門認證[/url]
- 有效的Plat-Dev-210考試重點和資格考試考試領導者和高質量的Plat-Dev-210熱門認證 🧍 透過▶ [url]www.newdumpspdf.com ◀輕鬆獲取▶ Plat-Dev-210 ◀免費下載Plat-Dev-210考證[/url]
- 準確的Plat-Dev-210考試重點和資格考試中的領先提供商&可信賴的Plat-Dev-210熱門認證 🦍 來自網站⮆ tw.fast2test.com ⮄打開並搜索⮆ Plat-Dev-210 ⮄免費下載Plat-Dev-210熱門考古題
- Plat-Dev-210考試大綱 🥙 Plat-Dev-210考試指南 🦏 Plat-Dev-210考試指南 🛬 進入▷ [url]www.newdumpspdf.com ◁搜尋➠ Plat-Dev-210 🠰免費下載Plat-Dev-210題庫[/url]
- Plat-Dev-210證照指南 ◀ Plat-Dev-210 PDF 🐅 Plat-Dev-210考試指南 🥴 立即到▷ [url]www.newdumpspdf.com ◁上搜索【 Plat-Dev-210 】以獲取免費下載Plat-Dev-210認證題庫[/url]
- 最受歡迎的Plat-Dev-210考試重點,覆蓋大量的Salesforce認證Plat-Dev-210考試知識點 📆 「 [url]www.newdumpspdf.com 」上的「 Plat-Dev-210 」免費下載只需搜尋Plat-Dev-210考試指南[/url]
- 覆蓋全面的Salesforce Plat-Dev-210考試重點是行業領先材料和經過驗證的Plat-Dev-210:Salesforce Certified Omnistudio Developer 🏴 「 tw.fast2test.com 」最新{ Plat-Dev-210 }問題集合Plat-Dev-210考試證照
- [url=https://entertainmens.nl/?s=%e5%b0%88%e6%a5%adPlat-Dev-210%e8%80%83%e8%a9%a6%e9%87%8d%e9%bb%9e%e5%8f%8a%e8%b3%87%e6%a0%bc%e8%80%83%e8%a9%a6%e9%a0%98%e5%85%88%e4%be%9b%e6%87%89%e5%95%86%e5%92%8c%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89%e7%9a%84Salesforce%20Salesforce%20Certified%20Omnistudio%20Developer%20%f0%9f%8d%ad%20%e4%be%86%e8%87%aa%e7%b6%b2%e7%ab%99%ef%bc%88%20www.newdumpspdf.com%20%ef%bc%89%e6%89%93%e9%96%8b%e4%b8%a6%e6%90%9c%e7%b4%a2[%20Plat-Dev-210%20]%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89Plat-Dev-210%e7%86%b1%e9%96%80%e8%80%83%e9%a1%8c]專業Plat-Dev-210考試重點及資格考試領先供應商和免費下載的Salesforce Salesforce Certified Omnistudio Developer 🍭 來自網站( www.newdumpspdf.com )打開並搜索[ Plat-Dev-210 ]免費下載Plat-Dev-210熱門考題[/url]
- 最好的Salesforce Plat-Dev-210考試重點是行業領先材料&無與倫比的Plat-Dev-210熱門認證 🚓 《 [url]www.newdumpspdf.com 》是獲取▷ Plat-Dev-210 ◁免費下載的最佳網站Plat-Dev-210證照指南[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, career-aouom.bringsell.com, massageben.com, ycs.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, techupskill.io, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! 免費下載Fast2test Plat-Dev-210考試題庫的完整版:https://drive.google.com/open?id=1ypllh3Ghu0KPW9N3Xi57EvCItEFO5gPZ
