Valid MTCNA Practice Questions | MTCNA Latest Exam Questions
Posted at 2/23/2026 13:00:09
2026 Latest Lead1Pass MTCNA PDF Dumps and MTCNA Exam Engine Free Share: https://drive.google.com/open?id=1p6fiNNiJcX0883v351EQD9Y6X10NlcbX
Lead1Pass is continuing to provide the candidates with MikroTik certification exam-related reference materials for years. Lead1Pass is the website that is validated by all the MTCNA test-takers, which can provide all candidates with the best questions and answers. Lead1Pass comprehensively ensures the interests of all candidates, which enjoys immense praise of the candidates. Moreover Lead1Pass is the most trusted website on the current market.
One of the most popular certifications offered by MikroTik is the MikroTik Certified Network Associate (MTCNA) certification. MikroTik Certified Network Associate Exam certification is designed for network administrators, technicians, and other IT professionals who work with MikroTik routers and other networking equipment. The MTCNA exam tests candidates on their understanding of basic networking concepts, as well as their ability to configure and troubleshoot MikroTik routers.
MikroTik MTCNA (MikroTik Certified Network Associate) Certification Exam is a globally recognized certification that validates the expertise of network professionals in configuring, managing, and troubleshooting MikroTik routers and networks. MikroTik Certified Network Associate Exam certification exam is designed to test the knowledge and skills of individuals with entry-level expertise in networking and MikroTik RouterOS software.
Valid MTCNA Practice Questions - Quiz MTCNA - First-grade MikroTik Certified Network Associate Exam Latest Exam QuestionsNew developments in the tech sector always bring new job opportunities. These new jobs have to be filled with the MTCNA certification holders. So to fill the space, you need to pass the MTCNA Exam. Earning the MTCNA certification helps you clear the obstacles you face while working in the MikroTik field.
MikroTik MTCNA Certification Exam is a globally recognized certification that validates the skills and knowledge of network administrators and engineers in configuring and managing MikroTik routers and networks. MTCNA exam is designed to test the candidate's ability to configure, manage, and troubleshoot MikroTik routers and networks. MikroTik Certified Network Associate Exam certification is ideal for individuals who want to improve their networking skills and advance their careers in the networking industry.
MikroTik Certified Network Associate Exam Sample Questions (Q190-Q195):NEW QUESTION # 190
What kind of users are listed in the Secrets window of the PPP menu?
- A. pppoe users
- B. pptp users
- C. l2tp users
- D. wireless users
- E. Hot-Spot users
- F. winbox users
Answer: A,B,C
NEW QUESTION # 191
On the advanced menu of the wireless setup there is a parameter called "Area", it works directly with:
- A. Access List
- B. Security Profile
- C. Connect List
- D. None of these
NEW QUESTION # 192
Which of the following describe the DHCP Discover message?
* It uses FF:FF:FF:FF:FF:FF as a layer 2 broadcast.
* It uses UDP as the Transport layer protocol.
* It uses TCP as the Transport layer protocol.
* It does not use a layer 2 destination address.
- A. 1 only
- B. 1 and 2
- C. 3 and 4
- D. 4 only
When a client sends a DHCP Discover message:
* It does not yet have an IP address, so it sends a Layer 2 broadcast (FF:FF:FF:FF:FF:FF).
* DHCP uses UDP, not TCP.
* Specifically, it uses UDP port 67 (server) and 68 (client).
* Layer 2 destination is broadcast - it certainly does use a Layer 2 address.
MTCNA Course Material - DHCP Process:
"The client broadcasts a DHCP Discover message to FF:FF:FF:FF:FF:FF using UDP ports 67 and 68." Rene Meneses MTCNA Study Guide - DHCP Message Types:
"DHCP uses UDP. Discovery messages are Layer 2 broadcasts to locate a DHCP server." MikroTik Wiki - DHCP Protocol Behavior:
"The Discover message uses UDP and broadcast MAC addressing."
Statements:
* 1: True (Layer 2 broadcast)
* 2: True (Uses UDP)
* 3: False (TCP not used)
* 4: False (Layer 2 destination address is broadcast)
NEW QUESTION # 193
What is the default protocol/port of (secure) winbox?
- A. UDP/5678
- B. TCP/8291
- C. TCP/8080
- D. TCP/22
NEW QUESTION # 194
Your company has been assigned a 172.16.25.0/25 network from your ISP. What are the possible options to divide the network into subnets?
- A. two times /26
- B. one /23 and one /27
- C. four times /27
- D. two times /24
The 172.16.25.0/25 subnet provides 128 IP addresses (2
