Add a third-party app on Android
10
Posted at 12/10/2016 11:16:17      View4466 | Replies6        Print      Only Author   [Copy Link] 1#
Take the apk of firefly official SDKas an example to simply introduce how to add third-party applications.
To find thisdirectory(vendor/firefly/firefly_assistant) in SDK, it should be the Fireflyofficial to add apk by their own, then use it as an example.
Steps:
1Create a directory under the vendor, such as:
2Put the apk and related library files into the directory, suchas: DLNARemoteService.apk libtchip-vinit.so
3Create an Android.mk file:
vendor/firefly/firefly_assistant/Android.mk
The code:
  1. LOCAL_PATH := $(my-dir)
  2. include $(CLEAR_VARS)
  3. LOCAL_MODULE := DLNARemoteService
  4. LOCAL_MODULE_CLASS := APPS
  5. LOCAL_MODULE_PATH := $(TARGET_OUT_APPS)
  6. LOCAL_SRC_FILES := $(LOCAL_MODULE)$(COMMON_ANDROID_PACKAGE_SUFFIX)
  7. LOCAL_CERTIFICATE := PRESIGNED
  8. LOCAL_MODULE_TAGS := optional
  9. LOCAL_MODULE_SUFFIX := $(COMMON_ANDROID_PACKAGE_SUFFIX)
  10. include $(BUILD_PREBUILT)
Copy the code
LOCAL_MODULE :=DLNARemoteService (The name of APK)
LOCAL_MODULE_PATH :=$(TARGET_OUT_APPS) ( after compilation, apk in the directory (/ system / app /) )
4Create a mk file, such asvendor/firefly/firefly_assistant.mk
  1. CUR_PATH := vendor/firefly/
  2. # add remote for remoteservice
  3. PRODUCT_PACKAGES += \
  4.           DLNARemoteService
  5. PRODUCT_COPY_FILES +=$(CUR_PATH)/firefly_assistant/libtchip-vinit.so:system/lib/libtchip-vinit.s
Copy the code
PRODUCT_PACKAGES followed by apk names
PRODUCT_COPY_FILES followed by the path tothe library file
5. device/rockchip/rksdk/device.mk to add:
includevendor/firefly/firefly_assistant.mk
The position aftercompilation
out/target/product/rk3288/system/app/DLNARemoteService.apk
Posted at 1/9/2026 06:48:17        Only Author  2#
This article is very practical, and I have gained a lot of inspiration from it. Sharing EAEP2201 valid exam tutorial exam questions for freeopen the door to promotions and salary increases!
Posted at 1/9/2026 19:28:51        Only Author  3#
Im truly grateful for your article, it really made an impression. The SAE-C01 test score report content is impressive, and its available at no cost.
Posted at 1/12/2026 02:52:45        Only Author  4#
Your article was so unique, thank you for sharing this fresh perspective. Get the Valid C_BW4H_2505 dumps questions that helped me succeed in my careerfor free today!
Posted at 1/13/2026 01:32:28        Only Author  5#
This article is exceptional in every way, Im so thankful for your share. Here's the Online BUS105 version exam that played a significant role in my promotion and salary increase. Its free for everyone today. Good luck!
restricted members
Posted at 1/17/2026 19:44:31        Only Author  6#
It was such a valuable learning experience. Heres the free Pass NCP-EUC guarantee material! Wishing everyone good luck on their exams!
Posted at 2/20/2026 23:00:54        Only Author  7#
This article is really amazing, and I've learned a lot from it. Here's the CPIM-8.0 latest test pdf test that helped me land my promotion and raise. It's free todaygood luck with your career progress!
