I set a mount point and now it will not boot
57
Posted at 4/23/2017 09:59:10      View6105 | Replies9        Print      Only Author   [Copy Link] 1#
Hello, I defined a mount point in /etc/fstab and does not start and I do not get the terminal to get the mount point, how can I fix the problem?
super moderator
Rank: 8Rank: 8
Posted at 4/24/2017 15:49:38        Only Author  2#
show us your "/etc/fstab" file  .
Posted at 4/26/2017 08:45:30        Only Author  3#
isle Posted at 4/24/2017 15:49
It does not start, the screen turns on and goes black, but it does not show me anything else
What I can do?
super moderator
Rank: 8Rank: 8
Posted at 4/28/2017 10:42:55        Only Author  4#
get  the X log in '/var/log/Xorg.0.log"  from uart. then post it up.
Posted at 4/29/2017 10:00:23        Only Author  5#
isle Posted at 4/28/2017 10:42
How do I do it? If you don't let me do anything, I don't start any OS
Posted at 4/29/2017 10:28:50        Only Author  6#
Sounds stupid but touch any key on the keyboard and I shut down the screen and start linux and I could get the mount point that was in /etc/fstab
super moderator
Rank: 8Rank: 8
Posted at 5/2/2017 09:24:19        Only Author  7#
Posted at 1/14/2026 22:27:30        Only Author  8#
This article is a gem, thank you for sharing it with us! Best of luck in your exams! Valid test L5M6 format questions are available for free!
restricted members
Posted at 1/28/2026 04:36:51        Only Author  9#
Fast2test는 고객님께서 첫번째Cisco 100-140-KR시험에서 패스할수 있도록 최선을 다하고 있습니다. 만일 어떤 이유로 인해 고객이 첫 번째 시도에서 실패를 한다면, Fast2test는 고객에게Cisco 100-140-KR덤프비용 전액을 환불 해드립니다.환불보상은 다음의 필수적인 정보들을 전제로 합니다.
restricted members
Posted at 1/28/2026 14:44:38        Only Author  10#
Das IT-Expertenteam von ZertPruefung haben eine kurzfristige Schulungsmethode nach ihren Kenntnissen und Erfahrungen bearbeitet. Diese Dumps könne Ihnen effektiv helfen, in kurzer Zeit den erwarteten Effekt zu erzielen, besonders fr diejenigen, die arbeiten und zuleich lernen. ZertPruefung kann Ihnen viel Zeit und Energir ersparen. Wählen Sie ZertPruefung und Sie werden Ihre wnschten Schulungsmaterialien zur Salesforce Mule-Arch-202 Zertifizierungsprfung bekommen.
