Debuging C code on android with gdb ?
77
Posted at 7/26/2017 10:41:21      View3746 | Replies4        Print      Only Author   [Copy Link] 1#
I am attempting to debug the android native code using gdb over adb. However when trying to load a file to debug i get a error
  1. "/home/dan/proj/firefly-rk3399/out/target/product/rk3399_firefly_box/symbols/system/bin/service": not in executable format: File format not recognized
Copy the code
from what Ive been able to find in order to debug this adding LOCAL_CFLAGS += -ggdb and LOCAL_STRIP_MODULE = false to android.mk is required. however i am not sure im adding to the correct android.mk file. ive added it to /frameworks/native/cmds/android.mk
Id like to know if i am adding those flags to the correct android.mk file or
if there is a diffrent debug procedure (that allows me to create breakpoints and step through code)
my gdb debug proceedure:
  1. TARGET SETUP:
  2. $ adb shell
  3. #gdbserver localhost:2345 service list
  4. HOST SETUP:
  5. $adb forward tcp:2345 tcp:2345
  6. $~/proj/firefly-rk3399/prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gdb
  7. (gdb) file ~/proj/firefly-rk3399/out/target/product/rk3399_firefly_box/symbols/system/bin/service
Copy the code
For now im just trying to debug from terminal, from what ive read later on you can link it to eclipse
Posted at 1/10/2026 15:09:03        Only Author  2#
Thank you for your wonderful share; this article really opened my eyes! Free 300-220 reliable exam objectives available for improving your IT skills. Wishing you the best!
restricted members
Posted at 1/18/2026 07:51:44        Only Author  3#
Jeder in der IT-Branche hat seinen eigenen Traum: das Zertifikat von Juniper JN0-224 zu erhalten, berufliche Beförderung oder Gehaltserhöhung zu bekommen. Traum unseres ZertSoft ist es, Ihnen dabei zu helfen, die Juniper JN0-224 Zertifizierungsprfung zu bestehen. Nachdem Sie unsere Schulungsunterlagen gekauft haben, können Sie einjährige Aktualisierung kostenlos genießen. Falls Sie die JN0-224 Prfung leider nicht bestehen, versprechen wir Ihnen eine volle Rckerstattung.
Posted at 1/22/2026 21:35:31        Only Author  4#
ExamPassdump에서 최고최신버전의SAP인증C_THR88_2505시험덤프 즉 문제와 답을 받으실 수 있습니다. 빨리 소지한다면 좋겠죠. 그래야 여러분은 빨리 한번에SAP인증C_THR88_2505시험을 패스하실 수 있습니다.SAP인증C_THR88_2505관련 최고의 자료는 현재까지는ExamPassdump덤프가 최고라고 자신 있습니다.
Posted at 1/29/2026 02:59:16        Only Author  5#
hΤCertJukenˤ륳Х`ǤȫƤSAPC_TS4FI_2023-JPNSAP Certified Associate - SAP S/4HANA Cloud Private Edition, Financial Accounting (C_TS4FI_2023ձZ)ԇYϷdz˴ФǤg٤˰kչƤrˡCertJukenϤФһĤǤǤϤʤۤȤɤˡCertJukenxΤǤCertJukenṩ놖}YϤϽ~ʤԇYܤ뤳Ȥ뤫ǤCertJukenṩYϤ¤Υȥ`˥󥰥ĩ`뤬˥åץǩ`ȤJ^ԇYĿˤQνYǤCertJuken Ϥʤ¤ԇYоYϤṩޤ顢CertJuken SAPC_TS4FI_2023-JPN}֤äƤ顢ԇYֱ椹Ť˜뤳ȤǤϸ񤷤ʤʤȫȻ䤹뤳ȤϤʤݘSԇYܤ뤳ȤǤޤ
