news?
100
news?
Posted at 8/26/2017 08:14:35      View4690 | Replies8        Print      Only Author   [Copy Link] 1#
so what is going on with development on this board? The add says "vulkan support," but there is none. What is happening with the drivers? Are we going to see something soon? Seriously what is going on with this? I have been searching for any info that I can find, but have found nothing. Any insight is welcome. Thanks
Posted at 8/26/2017 15:14:16        Only Author  2#
To be honest, I'm slowly starting to regret buying the board and the eDP screen - there's little to no support offered to those, other than once-released firmware that can't even be worked on
super moderator
Rank: 8Rank: 8
Posted at 8/28/2017 10:24:13        Only Author  3#
Hi guys,
Yes, the vulkan has been supported in android 7.1 on firefly-rk33399. Did you have any problem?
Posted at 8/28/2017 18:08:17        Only Author  4#
When I try running the vulkan caps viewer it comes up with "no vulkan supported gpu found." https://github.com/SaschaWillems/VulkanCapsViewer.
And when I attempt to run dolphin with the Vulkan backend I get "error could not load Vulkan libraries." Is there something that I'm missing? even though vulkan is "supported" do I still need to manually install those drivers? In what capacity do you say that Vulkan is supported? Where are the Firefly RK3399 specific drivers? I'm still pretty new to this BTW, and I'm looking for the layman's version, if possible, in regards to the info I have requested. I really would like to do some graphically intensive work with this board, but so far the Vulkan API is seemingly not available. The fact that this board has the Mali 864, and is capable of Vulkan is the only reason I purchased this board....... because it fit my purposes. It seems a little disappointing. Again, I may be missing something. Let me know what I need to do in order to activate whatever I need to activate to get this working.
Posted at 8/28/2017 18:19:41        Only Author  5#
Also, When I check the Vulkan website for ARM boards that have support the only Firefly device is the RK3288. The 3399 is not mentioned anywhere.
Posted at 1/11/2026 01:05:28        Only Author  6#
지금 같은 상황에서 몇년간SAP C-THR94-2505시험자격증만 소지한다면 일상생활에서많은 도움이 될것입니다. 하지만 문제는 어떻게SAP C-THR94-2505시험을 간단하게 많은 공을 들이지 않고 시험을 패스할것인가이다? 우리Itexamdump는 여러분의 이러한 문제들을 언제드지 해결해드리겠습니다. 우리의C-THR94-2505시험마스터방법은 바로IT전문가들이제공한 시험관련 최신연구자료들입니다. 우리Itexamdump 여러분은C-THR94-2505시험관련 최신버전자료들을 얻을 수 있습니다. Itexamdump을 선택함으로써 여러분은 성공도 선택한것이라고 볼수 있습니다.
Posted at 1/12/2026 12:44:16        Only Author  7#
ˤΤä뤳Ȥ򤤤ĤҪ󤷤ʤǡ˽ˤ˺ΤäƤ뤳Ȥ褯٤ǤšǤͬǤܥ˂ʁ줷Ƥ顢ܥϟoՓʤإޤ˷ơʤäͨšTä顢W礫ͤޤǤ顢ITJԇYܤäơԷ֤ߤ٤Ǥ CertShikenOracle1z0-1054-25Oracle Financials Cloud: General Ledger 2025 Implementation ProfessionalԇY}ϤʤɹؤΥ`ȥåȤ뤨ޤIT šTϤۤȤЄӤޤ顢ʤϤޤΤäƤΤǤ鷺CertShikenOracle1z0-1054-25ԇYȥ`˥YϤُ뤷ޤ礦
Posted at 1/15/2026 14:56:34        Only Author  8#
I sincerely thank you for sharing this impactful article! Get free New Data-Cloud-Consultant test cram sheet file to enhance your IT expertise. Wishing you success!
Posted at 1/23/2026 01:27:07        Only Author  9#
Your article has left a significant mark on me, thank you for it. Thanks to the 1Z0-340-25 study demo, I got promoted and received a salary boost. Its free now. Wishing you all a successful career advancement!
