USB-to-UART Minicom input not working
145
Posted at 11/6/2017 18:31:59      View5026 | Replies3        Print      Only Author   [Copy Link] 1#
Hi,
I followed instructions from http://wiki.t-firefly.com/index. ... 399/Serial_debug/en to setup my USB to UART module. I can see the board booting (with all kernel logs) on my minicom. However, my keyboard input is not being accepted. I'm not able to login using keyboard from minicom.
I've made sure that Hardware Flow Control is 'NO'.
What am I missing? Could someone help.
Thanks,
San
Posted at 11/6/2017 18:50:48        Only Author  2#
It started working after I swapped the GNG and RXD Pins.
Looks like the connection shown in http://wiki.t-firefly.com/index. ... 399/Serial_debug/en is wrong.
On the USB-to-UART board, the left most pin is GND, Middle is TXD and the right most is RXD. The diagram in the above link has GND and RXD swapped, which is wrong.
Thanks,
San
Posted at 1/9/2026 22:35:03        Only Author  3#
The article was a real source of inspiration. This Dumps AZ-801 PDF helped me achieve a promotion and salary increase. Now its free for everyone. Wishing you all a smooth path to promotion!
Posted at 1/11/2026 12:15:05        Only Author  4#
Your article was a true eye-opener, thank you for sharing it. Sharpen your IT expertise with free Analytics-Con-201 test simulator fee. Wishing you success!
