RK 3399 no flash over USB
9
Posted at 11/18/2017 20:45:51      View6161 | Replies7        Print      Only Author   [Copy Link] 1#
I have successfully tested the compilation of the sources and execution of the program under Linux and Android.I had a great time, the staff was really friendly and I had no problems adapting at all!
The problem that i have with a download of a new application part through the Boot Loader
After connecting the module, the following steps are necessary to configure
The first one, device is cut off all the power sources, such as power adapter and Type-C connection:
        1.Keep Type-A cable connected with host PC.
  • ress and hold RECOVERY key.
  • Connect Type-C cable to the device.
  • After around two seconds, release RECOVERY key.
    The other way
  • Use Type-C cable to connect host and device together.
  • Press and hold RECOVERY key.
  • Shortly press RESET key.
The Device Management, never find a the device name "Rockusb Device
Several times I tried to this Steps but the loader mode is not available and the boot fails.
I try also this If device still can not be found after pressing "RESET", then try this: long press "PWRKEY" after short pressing of "RESET", before finally releasing "RECOVERY".
and nothing the bootloader  has no connection over USB
What can I do
Posted at 11/23/2017 10:11:03        Only Author  2#
Use the debug Uart to see what s going on .
if you can see the log below .
  1. #Boot ver: 2017-10-13#1.06
  2. empty serial no.
  3. reboot rockusb.
Copy the code
RK3399 is in the loader mode, and that time ,you need to check your PC usb driver or the Type-C wire.
Posted at 12/21/2017 15:38:25        Only Author  3#
Fashion is generally dismissed as being a frivolous frippery, any kind of nonsense, something which really won't matter by any means. Those missing any interest within the topic are often more when compared with scathing over it. But the folks are absent some thing.        www.chaseshopping.com
Your pattern statement can certainly say a number of things about the actual image and also the method that you simply dress. Are you able to impress, turn-off, or maybe invite appealing compliments? There are just as much ways to make a fashion assertion as possible find style types. Exactly what does your own thing state?        www.answerfashion.com
In creating a excellent career about this field, you should also choose the very best job which supports you attain a booming position. It's essential because pattern industry could be a diverse field and you'll only alter lives if you may be extraordinarily great within the particular area.        www.xchangefashion.com
Making it as being a Fashion Designer today is actually work. This write-up may push you within the right program and permit you to focus round the key areas you need to address to be able to succeed available on the market.        www.wizardsfashion.com
If you may be a buddies of pattern then you will know it is usually transforming. It will likely be hard to keep to day in what's very warm and what is not because there may be so considerably that pattern covers.        www.warriorfashion.com
When it comes to fashion, many people do not know where to begin. Following websites, reading magazines, and going to several style retailers may give you support in discovering fashion suggestions. Here are often some tips to be able to learn how you can create pattern inspired clothes.        www.specialistsfashion.com
Fashion recognizes any perform of dressing that is popular inside a particular second or within the particular place. Fashion could be a style or perhaps a practice particularly in clothes, footwear, elements, in makeup as well as in entire body art (at the. g pirecing, pores and skin icon).        www.professionalsfashion.com
Pattern, in the actual native belief, is any kind of term for the most fashionable and well-liked design associated with clothing, foot wear as well as accessories concerning personal grooming. Oahu may be the latest trend within the attire of the individual utilizing a certain key in habits, because properly.        www.prepfashion.com
Fashion design may be the talent concerning applying design to entire body shapes every single child create trendy garments. That you should succeed in this world of pattern and design you have to manage to complete paintings as well as paintings.        www.factsfashion.com
A plenty of couples believe that they may use a tiny bit of professional guidance to plan their dream wedding. Some couples believe that they need lots of help! Discovering which type of wedding professional to interact can turn out to be confusing, since everybody can get in touch with himself or maybe herself by simply whatever subject they need.        www.workwedding.com
It's any kind of preconceived look at that involved and marriage is expensive. The biggest expense might actually be the venue that could cost an organization fixed daily rate. You may be surprised to hear that haggling with the high cost on the area        www.universitywedding.com
In order to construct an exceptional income through learning to become a wedding expert photographer, you tend not to simply end up being regarded the blessed digital photographer or certainly be a master of the camera. You have to also find methods to demonstrate by which to other people.        www.supportwedding.com
One of the extremely most important options for wedding celebration couples which are interested within preserving the specific memories of those wedding day should be to hire an expert wedding expert photographer. However it is very typical for the groom as well as bride in order to prioritize about everything except that'll be their specific wedding expert photographer.        www.studentwedding.com
Every thing different arrives initial, the actual outfit as well as tux, the specific bouquet, the specific reception. It truly is at their unique bottom using the list that'll be inside charged using the wedding pictures.        www.momswedding.com
Utilizing becoming married photographer is essential for anyone who is thinking about preserving memories of those special night. While very common for that groom as well as bride to bother about various regions of their wedding such as the flowers        www.knowwedding.com
Some people simply think that they'll just choose a wedding photographer and still have their pictures taken. Occasionally, the bridegroom and bride-to-be may choose undertake a relative or a close friend become the official wedding ceremony photographer with regard to special night.        www.howwedding.com
Such elements as professionalism and reliability and believe in, experience and also the opportunity to supply photo services in a number of formats are just some advantages of obtaining an expert wedding expert photographer.        www.answerwedding.com
Do you realize how a number of universal laws you'll find? Or exactly where did these people work? They might be an aged and truthful guide every single child living spiritually, as you'll discover if you retain reading...        www.lawshowcase.com
What's going to be regulation regarding appeal? This question is doing air yesteryear decade given that the theory with this particular law grew to become public subsequent your release using the book "The Secret". On this page the laws of attraction remains mentioned within details        www.lawextreme.com
Everything regarding this universe is more intelligent when compared with we provide credit concerning; it is really a real stunning coherence by which run our very own lives. We happen to be here every single child mould the specific energies straight into matter as well as create as well as share Happy Living.        www.lawcountry.com
The universe includes distinct rules and guidelines that guideline our lifestyle. Both achievement and frustration are within your control. Despite your general condition, you'll be able to make a noticable difference in a person life and initiate attracting much better things by using these rules...        www.lawbucket.com
California is called to have many of the strictest gun control laws in the usa with approximately 950 tool laws currently in position. Supporters concerning stricter gun laws dispute why these types of laws are essential to manage crime        www.lawadventure.com
Nearly just about all finance careers need you to be excellent with numbers and learn about basic business statistics. Let's look at some within the lucrative financial education options.        enterprisefinance.com
Equity funding means the particular, own money and funding. Usually scaled-down scale company including partnerships together with sole proprietorships are usually operated simply by their vendor trough their own finance. Joint expense companies operate by equity shares        anywherefinance.com
High technologies won't make reference to your course involving technologies because numerous technology are in fact considered present day at a particular point, before remaining considered minimum tech in addition to obsolete as time passes.        glamtechnology.com
Information technology generally may be the term for those varieties associated with technology used in the style, storage, exchange and by utilizing data, conversation together with all multi-media types of communication. Using computer technology constantly changing        getyourtechnology.com
An description simply associated with 2G together with 3G Technology and exactly what they mean for you personally these times. You may spot exactly how 3G Phones offer incredible features including photo-editing, film reports as well as virtual actuality.        faketechnology.com
There are in fact great breakthroughs inside technologies sector more than prior couple of ages. Consumers that have been alive towards the past 45 years possess witnessed what wound up being as soon as deemed not possible are therefore prevalent they are assumed.        naughtytechnology.com
In 1997 Mr. Clayton Mirielle. Christensen (A brand new Harvard Business School Teacher) introduces an entire new phrase "Disruptive Technology". He additionally describes which will displaces an established technology.        amateurtechnology.com
Previously, cooling vast majority solids such as sugar, fertilizer, ingredients, plastics, dried out biosolids, nutritional vitamins, and a myriad of other kinds involving grains, crystals together with bulk powders with the traditional systems won't guarantee top quality final options.        thattechnology.com
Posted at 1/15/2026 05:17:02        Only Author  4#
I walked away from that article with a deeper understanding. Free access to C_P2WAB_2507 latest soft simulations materialsgood luck!
restricted members
Posted at 1/15/2026 22:21:06        Only Author  5#
By reading this article, I feel that I have experienced a lot of growth. Enhance your IT knowledge with free 220-1101 new exam collection materials. Best of luck on your exams!
restricted members
Posted at 1/19/2026 05:34:14        Only Author  6#
I learned so much from the articleit was truly beneficial. Enhance your IT knowledge and get free Databricks-Certified-Data-Analyst-Associate valid exam dumps.zip. Best wishes for success!
Posted at 2/16/2026 14:13:52        Only Author  7#
IT업계에서 자신만의 위치를 찾으려면 자격증을 많이 취득하는것이 큰 도움이 될것입니다. Amazon 인증 AIP-C01시험은 아주 유용한 시험입니다. Amazon 인증AIP-C01시험출제경향을 퍼펙트하게 연구하여ass4Test에서는Amazon 인증AIP-C01시험대비덤프를 출시하였습니다. Pass4Test에서 제공해드리는Amazon 인증AIP-C01시험덤프는 시장에서 판매하고 있는Amazon 인증AIP-C01덤프중 가장 최신버전덤프로서 덤프에 있는 문제만 공부하시면 시험통과가 쉬워집니다.
Posted at 2/22/2026 23:39:21        Only Author  8#
Thank you for sharing this truly remarkable article! Free 312-50 latest real test answers available to enhance your IT expertise. Good luck!
