How I can remove bottom toolbar from android
240
Posted at 2/20/2018 12:30:19      View6870 | Replies9        Print      Only Author   [Copy Link] 1#
Hello,
I am working on a project which requires to remove the bottom toolbar(Three buttons: back,home and kill all the application).For that what changes I need to make in android source code?
Posted at 2/23/2018 14:32:18        Only Author  2#
u mean how to hide the navigation bar ?
or keep the bar and just remove the button u want ?
Posted at 2/27/2018 13:39:24        Only Author  3#
leungɭ Posted at 2/23/2018 14:32
Yes,That will work,too.
How can I hide navigation bar?
Posted at 2/27/2018 14:33:41        Only Author  4#
KrunalShah Posted at 2/27/2018 13:39
Settings-> display -> Show StatusBar
Posted at 2/28/2018 17:51:06        Only Author  5#
leungɭ Posted at 2/27/2018 14:33
No, I want to do this from firmware side. Please suggest what can be done from firmware side to hide the toolbar?
Posted at 3/1/2018 09:31:50        Only Author  6#
KrunalShah Posted at 2/28/2018 17:51
No, I want to do this from firmware side. Please suggest what can be done from firmware side to hi ...
  1. frameworks/base/packages/SettingsProvider/res/values/defaults.xml
  2.    <!-- should show the hidebar button default -->
  3.     <bool name="def_hidebar_button_show">true</bool>
  4.         <!-- statusbar is show -->
  5.         <bool name="def_statusbar_show">false</bool>
Copy the code
try this . if cannot work, search the key word above to modify
Posted at 3/6/2018 11:55:45        Only Author  7#
leungɭ Posted at 3/1/2018 09:31
Thanx, let me try this first
Posted at 3/7/2018 12:16:54        Only Author  8#
I tried this but it is not working.Do we have any other way?
restricted members
Posted at 1/18/2026 03:50:38        Only Author  9#
Your article was truly eye-catching and impressive, thank you! The content from MD-102 test review is valuable, and it's available without charge.
Posted at 1/23/2026 22:09:41        Only Author  10#
This article has really touched me, thank you for sharing! I hope the FCSS_NST_SE-7.6 new exam collection file material helps, and it's entirely free.
