Board not booting with Firefly-RK3399_Android7.1.1_git_20170518.7z
Posted at 4/26/2018 20:11:12
View12830
Replies7
Hi,
I'm using a RK3399 EVB (https://shop.t-firefly.com/goods.php?id=45)
I've downloaded the Android 7.1.1 source code from https://drive.google.com/drive/f ... gAqAVDNGNkdzZVcwTG8 .
I followed the instructions from http://en.t-firefly.com/doc/product/info/275.html, built and flashed the images on my board.
Kernel comes up and hangs. Given below is the boot log. Could you please help?
U-Boot 2017.02-RK3399-06 (Apr 12 2018 - 14:17:47)
CPU: rk3399
cpu version = 0
CPU's clock information:
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
cpll = 800000000HZ
dpll = 792000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
Board: Rockchip platform Board
Uboot as second level loader
DRAM: Found dram banks: 1
Adding bank:0000000000200000(000000007fe00000)
128 MiB
SdmmcInit = 0 20
storage init OK!
Using default environment
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
Load FDT from resource image.
power key: bank-0 pin-5
usb bc: can find node by path: /dwc-control-usb/usb_bc
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=66
aplll = 816000000HZ
apllb = 24000000HZ
gpll = 800000000HZ
cpll = 800000000HZ
dpll = 792000000HZ
vpll = 24000000HZ
npll = 24000000HZ
ppll = 676000000HZ
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2018-04-12#1.06
empty serial no.
normal boot.
checkKey
vbus = 1
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
can't find power_ctr node for panel
enable[0] disable[0]
read logo on state from dts [1]
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 0x0@0-0
[EDID-EXTEND] It is a CEA 861 Series Extension.
no baseparametr,find best edid mode,vic=16
hdmi_dev->video.vic is 4
rk lcdc - 0 dclk set: dclk = 74250000HZ, pll select = 0, div = 1
hdmi_dev_config_video vic 4 color_output 3 color_output_depth 8
pixel clk is 74250000 tmds clk is 74250000
hsync_pol 1 vsync_pol 1
[HDMI] sucess output HDMI.
PHY PLL not locked: PCLK_ON=1,TMDSCLK_ON=0
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
failed to display kernel logo
checkKey
vbus = 1
got recovery cmd from misc.
load fdt from resouce.
Secure Boot state: 0
kernel @ 0x00280000 (0x011f7420)
ramdisk @ 0x05bf0000 (0x00778b00)
bootrk: do_bootm_linux...
Loading Device Tree to 0000000005600000, end 0000000005614937 ... OK
Add bank:0000000000200000, 000000007fe00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Initializing cgroup subsys schedtune
[ 0.000000] Linux version 4.4.55 (balaji@balaji-OptiPlex-7050) (gcc version 4.9 20150123 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Apr 11 20:11:26 IST 2018
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] hdmi init vic is -1
[ 0.000000] cma: Reserved 16 MiB at 0x000000007f000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc07ef03000 s45248 r8192 d32576 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 515592
[ 0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtd0
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] software IO TLB [mem 0x7edb5000-0x7edf5000] (0MB) mapped at [ffffffc07edb5000-ffffffc07edf4fff]
[ 0.000000] Memory: 2013820K/2095104K available (11198K kernel code, 1372K rwdata, 4948K rodata, 832K init, 1079K bss, 64900K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff8009050000 - 0xffffff8009120000 ( 832 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008b70000 ( 11200 KB)
[ 0.000000] .rodata : 0xffffff8008b70000 - 0xffffff8009050000 ( 4992 KB)
[ 0.000000] .data : 0xffffff8009120000 - 0xffffff80092772e0 ( 1373 KB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc2000000 ( 31 MB actual)
[ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc080000000 ( 2046 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[ 0.000000] ITS: allocated 65536 Devices @7c400000 (psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GIC: using LPI property table @0x000000007c480000
[ 0.000000] ITS: Allocated 1792 chunks for LPIs
[ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[ 0.000000] CPU0: using LPI pending table @0x000000007c490000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[ 0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.001820] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.002808] pid_max: default: 32768 minimum: 301
[ 0.003315] Security Framework initialized
[ 0.003715] SELinux: Initializing.
[ 0.004153] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.004797] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.006250] Initializing cgroup subsys freezer
[ 0.006689] Initializing cgroup subsys debug
[ 0.007965] sched-energy: Sched-energy-costs installed from DT
[ 0.008530] CPU0: update cpu_capacity 401
[ 0.008997] ASID allocator initialised with 65536 entries
[ 0.025814] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.027045] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[ 0.039196] Detected VIPT I-cache on CPU1
[ 0.039227] CPU1: found redistributor 1 region 0:0x00000000fef20000
[ 0.039262] CPU1: using LPI pending table @0x000000007c5f0000
[ 0.039305] CPU1: update cpu_capacity 401
[ 0.039308] CPU1: Booted secondary processor [410fd034]
[ 0.049196] Detected VIPT I-cache on CPU2
[ 0.049216] CPU2: found redistributor 2 region 0:0x00000000fef40000
[ 0.049249] CPU2: using LPI pending table @0x000000007c620000
[ 0.049276] CPU2: update cpu_capacity 401
[ 0.049279] CPU2: Booted secondary processor [410fd034]
[ 0.059233] Detected VIPT I-cache on CPU3
[ 0.059252] CPU3: found redistributor 3 region 0:0x00000000fef60000
[ 0.059284] CPU3: using LPI pending table @0x000000007c660000
[ 0.059311] CPU3: update cpu_capacity 401
[ 0.059314] CPU3: Booted secondary processor [410fd034]
[ 0.069272] Detected PIPT I-cache on CPU4
[ 0.069299] CPU4: found redistributor 100 region 0:0x00000000fef80000
[ 0.069335] CPU4: using LPI pending table @0x000000007c6a0000
[ 0.069374] CPU4: update cpu_capacity 1024
[ 0.069377] CPU4: Booted secondary processor [410fd082]
[ 0.079300] Detected PIPT I-cache on CPU5
[ 0.079318] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[ 0.079350] CPU5: using LPI pending table @0x000000007c6e0000
[ 0.079377] CPU5: update cpu_capacity 1024
[ 0.079380] CPU5: Booted secondary processor [410fd082]
[ 0.079463] Brought up 6 CPUs
[ 0.091879] SMP: Total of 6 processors activated.
[ 0.092333] CPU features: detected feature: GIC system register CPU interface
[ 0.093020] CPU: All CPU(s) started at EL2
[ 0.093452] alternatives: patching kernel code
[ 0.095118] devtmpfs: initialized
[ 0.114658] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.115617] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.117243] pinctrl core: initialized pinctrl subsystem
[ 0.120258] Failed to find legacy iommu devices
[ 0.121257] NET: Registered protocol family 16
[ 0.122399] schedtune: init normalization constants...
[ 0.122899] schedtune: CLUSTER[0-3] min_pwr: 56 max_pwr: 222
[ 0.123527] schedtune: CPU[0] min_pwr: 0 max_pwr: 222
[ 0.124154] schedtune: CPU[1] min_pwr: 0 max_pwr: 222
[ 0.124795] schedtune: CPU[2] min_pwr: 0 max_pwr: 222
[ 0.125423] schedtune: CPU[3] min_pwr: 0 max_pwr: 222
[ 0.126050] schedtune: CLUSTER[4-5] min_pwr: 65 max_pwr: 1108
[ 0.126678] schedtune: CPU[4] min_pwr: 0 max_pwr: 1108
[ 0.127304] schedtune: CPU[5] min_pwr: 0 max_pwr: 1108
[ 0.127930] schedtune: SYSTEM min_pwr: 121 max_pwr: 4434
[ 0.128567] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[ 0.129299] schedtune: verify normalization constants...
[ 0.129809] schedtune: max_pwr/2^0: 4313 => norm_pwr: 1024
[ 0.130343] schedtune: max_pwr/2^1: 2156 => norm_pwr: 511
[ 0.130878] schedtune: max_pwr/2^2: 1078 => norm_pwr: 255
[ 0.131412] schedtune: max_pwr/2^3: 539 => norm_pwr: 127
[ 0.131956] schedtune: max_pwr/2^4: 269 => norm_pwr: 63
[ 0.132491] schedtune: max_pwr/2^5: 134 => norm_pwr: 31
[ 0.133025] schedtune: configured to support 4 boost groups
[ 0.145338] cpuidle: using governor ladder
[ 0.158691] cpuidle: using governor menu
[ 0.159086] Registered FIQ tty driver
[ 0.160080] vdso: 2 pages (1 code @ ffffff8008b76000, 1 data @ ffffff8009124000)
[ 0.160814] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.162287] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.195448] console [pstore0] enabled
[ 0.196021] pstore: Registered ramoops as persistent store backend
[ 0.196618] ramoops: attached 0xf0000@0x110000, ecc: 0/0
<hit enter to activate fiq debugger>
[ 0.200421] console [ttyFIQ0] enabled
[[ 0.200421] console [ttyFIQ0] enabled
[ 0.200967] bootconsole [uart0] disabled
[ 0.202189] Registered fiq debugger ttyFIQ0
[ 0.250571] Rockchip hdmi driver version 2.0
[ 0.252675] iommu: Adding device ff650000.vpu_service to group 0
[ 0.252756] iommu: Adding device ff660000.rkvdec to group 1
[ 0.252822] iommu: Adding device ff670000.iep to group 2
[ 0.252951] iommu: Adding device ff8f0000.vop to group 3
[ 0.253025] iommu: Adding device ff900000.vop to group 4
[ 0.253117] iommu: Adding device ff910000.isp to group 5
[ 0.253191] iommu: Adding device ff920000.isp to group 6
[ 0.253833] rk_iommu ff670800.iommu: can't get aclk
[ 0.253855] rk_iommu ff670800.iommu: can't get hclk
[ 0.254667] SCSI subsystem initialized
[ 0.255008] usbcore: registered new interface driver usbfs
[ 0.255053] usbcore: registered new interface driver hub
[ 0.255127] usbcore: registered new device driver usb
[ 0.255464] media: Linux media interface: v0.10
[ 0.255504] Linux video capture interface: v2.00
[ 0.255624] pps_core: LinuxPPS API ver. 1 registered
[ 0.255635] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.255659] PTP clock support registered
[ 0.256932] Advanced Linux Sound Architecture Driver Initialized.
[ 0.257406] Bluetooth: Core ver 2.21
[ 0.257438] NET: Registered protocol family 31
[ 0.257448] Bluetooth: HCI device and connection manager initialized
[ 0.257464] Bluetooth: HCI socket layer initialized
[ 0.257478] Bluetooth: L2CAP socket layer initialized
[ 0.257506] Bluetooth: SCO socket layer initialized
[ 0.258752] clocksource: Switched to clocksource arch_sys_counter
[ 0.297006] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.297847] NET: Registered protocol family 2
[ 0.298275] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.298382] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.298506] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.298575] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.298603] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.298773] NET: Registered protocol family 1
[ 0.299232] Trying to unpack rootfs image as initramfs...
[ 0.622249] Freeing initrd memory: 7648K (ffffffc005bf0000 - ffffffc006368000)
[ 0.622807] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.622892] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.626479] audit: initializing netlink subsys (disabled)
[ 0.626543] audit: type=2000 audit(0.620:1): initialized
[ 0.634894] VFS: Disk quotas dquot_6.6.0
[ 0.635018] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.636404] fuse init (API version 7.23)
[ 0.640978] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.641008] io scheduler noop registered
[ 0.641168] io scheduler cfq registered (default)
[ 0.642449] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[ 0.646566] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[ 0.646597] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 0.646615] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.168792] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[ 1.168856] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 1.170034] rockchip ion idev is NULL
[ 1.170054] rga2 ff680000.rga: rga ion client create success!
[ 1.170282] rga: Driver loaded successfully ver:3.02
[ 1.170961] iep: failed to find iep power down clock source.
[ 1.171272] IEP Power ON
[ 1.171432] IEP Power OFF
[ 1.171468] IEP Driver loaded succesfully
[ 1.171557] Module initialized.
[ 1.175288] rk-vcodec ff650000.vpu_service: No core reset resource define
[ 1.175344] rk-vcodec ff650000.vpu_service: do not have pd_video
[ 1.175366] rk-vcodec ff650000.vpu_service: probe device
[ 1.175406] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc07bc5e810
[ 1.175563] rk-vcodec ff650000.vpu_service: allocator is drm
[ 1.175621] rk-vcodec ff650000.vpu_service: checking hw id 0
[ 1.176026] rk-vcodec ff650000.vpu_service: init success
[ 1.179690] rk-vcodec ff660000.rkvdec: No core reset resource define
[ 1.179799] rk-vcodec ff660000.rkvdec: do not have pd_video
[ 1.179819] rk-vcodec ff660000.rkvdec: probe device
[ 1.179860] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc07bc5f010
[ 1.179999] rk-vcodec ff660000.rkvdec: allocator is drm
[ 1.180059] rk-vcodec ff660000.rkvdec: checking hw id 6876
[ 1.180351] rk-vcodec ff660000.rkvdec: init success
[ 1.181715] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.181736] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.183056] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.183074] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.Y�305] rockchip-cpuinfo cpuinfo: Serial : 94ac8a393cc45ff5
[ 1.184406] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.185748] console [ttyS0] disabled
[ 1.185792] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[ 1.186314] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[ 1.186697] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[ 1.190396] mali ff9a0000.gpu: Failed to get regulator
[ 1.190420] mali ff9a0000.gpu: Power control initialization failed
[ 1.190700] Unable to detect cache hierarchy from DT for CPU 0
[ 1.199289] brd: module loaded
[ 1.204046] loop: module loaded
[ 1.207910] zram: Added device: zram0
[ 1.208445] SCSI Media Changer driver v0.25
[ 1.212746] tun: Universal TUN/TAP device driver, 1.6
[ 1.212763] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.213808] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[ 1.213834] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[ 1.213848] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[ 1.214036] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[ 1.214049] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[ 1.219128] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.219145] Ring mode enabled
[ 1.219155] DMA HW capability register supported
[ 1.219164] Normal descriptors
[ 1.219175] RX Checksum Offload Engine supported (type 2)
[ 1.219184] TX Checksum insertion supported
[ 1.219193] Wake-Up On Lan supported
[ 1.219235] Enable RX Mitigation via HW Watchdog Timer
[ 1.286328] libphy: stmmac: probed
[ 1.286348] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[ 1.286361] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[ 1.287064] PPP generic driver version 2.4.2
[ 1.287230] PPP BSD Compression module registered
[ 1.287245] PPP Deflate Compression module registered
[ 1.287273] PPP MPPE Compression module registered
[ 1.287291] NET: Registered protocol family 24
[ 1.287329] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.287342] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.287365] Rockchip WiFi SYS interface (V1.00) ...
[ 1.287447] usbcore: registered new interface driver catc
[ 1.287489] usbcore: registered new interface driver kaweth
[ 1.287504] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[ 1.287543] usbcore: registered new interface driver pegasus
[ 1.287585] usbcore: registered new interface driver rtl8150
[ 1.287625] usbcore: registered new interface driver r8152
[ 1.287640] hso: drivers/net/usb/hso.c: Option Wireless
[ 1.287700] usbcore: registered new interface driver hso
[ 1.287748] usbcore: registered new interface driver asix
[ 1.287793] usbcore: registered new interface driver ax88179_178a
[ 1.287834] usbcore: registered new interface driver cdc_ether
[ 1.287873] usbcore: registered new interface driver cdc_eem
[ 1.287913] usbcore: registered new interface driver dm9601
[ 1.287962] usbcore: registered new interface driver smsc75xx
[ 1.288014] usbcore: registered new interface driver smsc95xx
[ 1.288055] usbcore: registered new interface driver gl620a
[ 1.288095] usbcore: registered new interface driver net1080
[ 1.288135] usbcore: registered new interface driver plusb
[ 1.288175] usbcore: registered new interface driver rndis_host
[ 1.288223] usbcore: registered new interface driver cdc_subset
[ 1.288264] usbcore: registered new interface driver zaurus
[ 1.288306] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[ 1.288361] usbcore: registered new interface driver int51x1
[ 1.288402] usbcore: registered new interface driver kalmia
[ 1.288442] usbcore: registered new interface driver ipheth
[ 1.288489] usbcore: registered new interface driver sierra_net
[ 1.288531] usbcore: registered new interface driver cx82310_eth
[ 1.288581] usbcore: registered new interface driver cdc_ncm
[ 1.288625] usbcore: registered new interface driver qmi_wwan
[ 1.288666] usbcore: registered new interface driver cdc_mbim
[ 1.289824] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[ 1.292764] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[ 1.293334] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.293352] ehci-pci: EHCI PCI platform driver
[ 1.293407] ehci-platform: EHCI generic platform driver
[ 1.295184] ehci-platform fe3c0000.usb: EHCI Host Controller
[ 1.295211] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[ 1.295349] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[ 1.302109] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[ 1.302238] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.302255] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.302268] usb usb1: Product: EHCI Host Controller
[ 1.302280] usb usb1: Manufacturer: Linux 4.4.55 ehci_hcd
[ 1.302291] usb usb1: SerialNumber: fe3c0000.usb
[ 1.302768] hub 1-0:1.0: USB hub found
[ 1.302801] hub 1-0:1.0: 1 port detected
[ 1.303275] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.303304] ohci-platform: OHCI generic platform driver
[ 1.303758] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[ 1.303787] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[ 1.303901] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[ 1.359569] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.359590] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.359604] usb usb2: Product: Generic Platform OHCI controller
[ 1.359617] usb usb2: Manufacturer: Linux 4.4.55 ohci_hcd
[ 1.359628] usb usb2: SerialNumber: fe3e0000.usb
[ 1.360038] hub 2-0:1.0: USB hub found
[ 1.360071] hub 2-0:1.0: 1 port detected
[ 1.360823] usbcore: registered new interface driver cdc_acm
[ 1.360835] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.360893] usbcore: registered new interface driver usblp
[ 1.360941] usbcore: registered new interface driver cdc_wdm
[ 1.360988] usbcore: registered new interface driver uas
[ 1.361060] usbcore: registered new interface driver usb-storage
[ 1.361106] usbcore: registered new interface driver ums-alauda
[ 1.361147] usbcore: registered new interface driver ums-cypress
[ 1.361188] usbcore: registered new interface driver ums-datafab
[ 1.361231] usbcore: registered new interface driver ums_eneub6250
[ 1.361272] usbcore: registered new interface driver ums-freecom
[ 1.361313] usbcore: registered new interface driver ums-isd200
[ 1.361353] usbcore: registered new interface driver ums-jumpshot
[ 1.361393] usbcore: registered new interface driver ums-karma
[ 1.361434] usbcore: registered new interface driver ums-onetouch
[ 1.361475] usbcore: registered new interface driver ums-sddr09
[ 1.361517] usbcore: registered new interface driver ums-sddr55
[ 1.361557] usbcore: registered new interface driver ums-usbat
[ 1.361639] usbcore: registered new interface driver usbserial
[ 1.361675] usbcore: registered new interface driver usbserial_generic
[ 1.361705] usbserial: USB Serial support registered for generic
[ 1.361748] usbcore: registered new interface driver option
[ 1.361777] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.361878] usbcore: registered new interface driver trancevibrator
[ 1.361895] usb20_otg: version 3.10a 21-DEC-2012
[ 1.362052] usb20_host: version 3.10a 21-DEC-2012
[ 1.365851] usbcore: registered new interface driver xpad
[ 1.365901] usbcore: registered new interface driver usb_acecad
[ 1.365951] usbcore: registered new interface driver aiptek
[ 1.365997] usbcore: registered new interface driver gtco
[ 1.366042] usbcore: registered new interface driver hanwang
[ 1.366086] usbcore: registered new interface driver kbtab
[ 1.366103] ==gsl_ts_init==
[ 1.366131] ret=0
[ 1.369851] .. rk pwm remotectl v1.1 init
[ 1.370074] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[ 1.370447] sensor_register_slave:mma8452,id=17
[ 1.370466] sensor_register_slave:lis3dh,id=7
[ 1.370481] sensor_register_slave:mma7660,id=18
[ 1.370496] sensor_register_slave:lsm303d,id=22
[ 1.370510] sensor_register_slave:mpu6880_acc,id=24
[ 1.370525] sensor_register_slave:mpu6500_acc,id=25
[ 1.370540] sensor_register_slave:lsm330_acc,id=26
[ 1.370555] sensor_register_slave:akm8975,id=28
[ 1.370570] sensor_register_slave:akm8963,id=29
[ 1.370585] sensor_register_slave:l3g4200d,id=43
[ 1.370599] sensor_register_slave:l3g20d,id=44
[ 1.370613] sensor_register_slave:ewtsa,id=45
[ 1.370629] sensor_register_slave:lsm330_gyro,id=48
[ 1.370643] sensor_register_slave:cm3217,id=50
[ 1.370658] sensor_register_slave:cm3218,id=51
[ 1.371261] i2c /dev entries driver
[ 1.372369] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[ 1.372432] fan53555-reg: supplied by vcc5v0_sys
[ 1.374632] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[ 1.374679] fan53555-reg: supplied by vcc5v0_sys
[ 1.376960] rk808 0-001b: Pmic Chip id: 0x0
[ 1.380038] rk808-regulator rk808-regulator: there is no dvs0 gpio
[ 1.380091] rk808-regulator rk808-regulator: there is no dvs1 gpio
[ 1.380175] DCDC_REG1: supplied by vcc3v3_sys
[ 1.380818] DCDC_REG2: supplied by vcc3v3_sys
[ 1.381306] DCDC_REG3: supplied by vcc3v3_sys
[ 1.381496] DCDC_REG4: supplied by vcc3v3_sys
[ 1.381857] LDO_REG1: supplied by vcc3v3_sys
[ 1.382886] LDO_REG2: supplied by vcc3v3_sys
[ 1.383763] LDO_REG3: supplied by vcc3v3_sys
[ 1.384636] LDO_REG4: supplied by vcc3v3_sys
[ 1.385548] LDO_REG5: supplied by vcc3v3_sys
[ 1.386424] LDO_REG6: supplied by vcc3v3_sys
[ 1.387299] LDO_REG7: supplied by vcc3v3_sys
[ 1.388190] LDO_REG8: supplied by vcc3v3_sys
[ 1.389072] SWITCH_REG1: supplied by vcc3v3_sys
[ 1.389279] SWITCH_REG2: supplied by vcc3v3_sys
[ 1.392557] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[ 1.393068] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fe000
[ 1.393603] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009682000
[ 1.403439] fusb302 4-0022: port 0 probe success
[ 1.403474] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009684000
[ 1.404288] IR NEC protocol handler initialized
[ 1.404303] IR RC5(x/sz) protocol handler initialized
[ 1.404316] IR RC6 protocol handler initialized
[ 1.404330] IR JVC protocol handler initialized
[ 1.404343] IR Sony protocol handler initialized
[ 1.404355] IR SANYO protocol handler initialized
[ 1.404368] IR Sharp protocol handler initialized
[ 1.404381] IR MCE Keyboard/mouse protocol handler initialized
[ 1.404395] IR XMP protocol handler initialized
[ 1.404481] usbcore: registered new interface driver uvcvideo
[ 1.404491] USB Video Class driver (1.1.1)
[ 1.404507] CamSys driver version: v0.33.11, CamSys head file version: v0.13.0
[ 1.405587] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.405587]
[ 1.405671] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy0 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.405671]
[ 1.405696] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy1 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.405696]
[ 1.406523] D1:camsys_platform_probe(1527): ff910000.isp memory:
[ 1.406540] D1:camsys_platform_probe(1543): Register memory (phy: 0xff910000 vir: 0xffffff8009688000 size: 0x4000)
[ 1.406555] D1:camsys_platform_probe(1535): I2c memory (phy: 0x5c5e000 vir: 0xffffffc005c5e000 size: 0x1000)
[ 1.406568] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.406579] D1:camsys_platform_probe(1557): Probe ff910000.isp device success
[ 1.407719] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[ 1.407719]
[ 1.407785] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy0 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.407785]
[ 1.407810] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy1 probe success (reg_phy: 0x0 reg_vir: 0x0 size: 0x0)
[ 1.407810]
[ 1.408565] D1:camsys_platform_probe(1527): ff920000.isp memory:
[ 1.408580] D1:camsys_platform_probe(1543): Register memory (phy: 0xff920000 vir: 0xffffff80096b8000 size: 0x4000)
[ 1.408595] D1:camsys_platform_probe(1535): I2c memory (phy: 0x5c81000 vir: 0xffffffc005c81000 size: 0x1000)
[ 1.408609] D1:camsys_init_ext_fsh_module(20): init external flash module
[ 1.408620] D1:camsys_platform_probe(1557): Probe ff920000.isp device success
[ 1.408969] __power_supply_register: Expected proper parent device for 'test_ac'
[ 1.409094] __power_supply_register: Expected proper parent device for 'test_battery'
[ 1.409331] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 1.409429] __power_supply_register: Expected proper parent device for 'test_usb'
[ 1.410621] rockchip_cpu_avs: cluster0 leakage=26 adjust_volt=0
[ 1.410660] rockchip_cpu_avs: cluster1 leakage=43 adjust_volt=0
[ 1.411740] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[ 1.412324] device-mapper: uevent: version 1.0.3
[ 1.412604] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.412739] Bluetooth: HCI UART driver ver 2.3
[ 1.412753] Bluetooth: HCI UART protocol H4 registered
[ 1.412763] Bluetooth: HCI UART protocol LL registered
[ 1.412778] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[ 1.412788] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[ 1.412798] rtk_btusb: Register usb char device interface for BT driver
[ 1.412977] usbcore: registered new interface driver rtk_btusb
[ 1.417162] sdhci: Secure Digital Host Controller Interface driver
[ 1.417179] sdhci: Copyright(c) Pierre Ossman
[ 1.417193] Synopsys Designware Multimedia Card Interface Driver
[ 1.417994] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.418068] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 1.418090] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 1.418139] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 1.418176] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.418220] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 1.418232] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 1.419132] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[ 1.419188] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[ 1.419208] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[ 1.419250] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[ 1.419274] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 1.419381] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[ 1.419614] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.419861] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[ 1.432190] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 1.446594] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[ 1.446869] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.448496] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[ 1.448514] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[ 1.477524] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[ 1.478980] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.484576] usbcore: registered new interface driver usbhid
[ 1.485133] usbhid: USB HID core driver
[ 1.485753] inv_mpu_iio: inv_mpu_init:742
[ 1.486160] fusb302 4-0022: CC connected in 1 as UFP
[ 1.487685] ashmem: initialized
[ 1.490351] ff100000.saradc supply vref not found, using dummy regulator
[ 1.495500] rknandbase v1.1 2016-01-08
[ 1.496627] usbcore: registered new interface driver snd-usb-audio
[ 1.516670] mmc1: MAN_BKOPS_EN bit is not set
[ 1.516691] u32 classifier
[ 1.516695] Actions configured
[ 1.516792] Netfilter messages via NETLINK v0.30.
[ 1.516925] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 1.517585] ctnetlink v0.93: registering with nfnetlink.
[ 1.518974] xt_time: kernel timezone is -0000
[ 1.520508] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.520809] arp_tables: (C) 2002 David S. Miller
[ 1.521769] Initializing XFRM netlink socket
[ 1.522664] NET: Registered protocol family 10
[ 1.524894] mip6: Mobile IPv6
[ 1.524968] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.529677] sit: IPv6 over IPv4 tunneling driver
[ 1.530561] NET: Registered protocol family 17
[ 1.530634] NET: Registered protocol family 15
[ 1.530708] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.533911] Bridge firewalling registered
[ 1.533957] Ebtables v2.0 registered
[ 1.534615] Bluetooth: RFCOMM TTY layer initialized
[ 1.534665] Bluetooth: RFCOMM socket layer initialized
[ 1.534718] Bluetooth: RFCOMM ver 1.11
[ 1.534765] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.534786] Bluetooth: BNEP filters: protocol multicast
[ 1.534813] Bluetooth: BNEP socket layer initialized
[ 1.534843] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.534869] Bluetooth: HIDP socket layer initialized
[ 1.534949] l2tp_core: L2TP core driver, V2.0
[ 1.534991] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[ 1.535028] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 1.535501] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 1.535599] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6356s
[ 1.535622] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 1.535643] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 1.535749] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[ 1.535772] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 1.535794] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 1.535893] [BT_RFKILL]: Enter rfkill_rk_init
[ 1.536454] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[ 1.536536] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 9.
[ 1.536599] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[ 1.536660] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 4.
[ 1.537873] [BT_RFKILL]: Request irq for bt wakeup host
[ 1.537978] [BT_RFKILL]: ** disable irq
[ 1.538224] [BT_RFKILL]: bt_default device registered.
[ 1.538743] sensor_register_slave:mpu6880_gyro,id=47
[ 1.539658] Registered cp15_barrier emulation handler
[ 1.539987] Registered setend emulation handler
[ 1.540511] mmc1: new HS400 Enhanced strobe MMC card at address 0001
[ 1.541427] registered taskstats version 1
[ 1.541637] pvtm list NULL
[ 1.541788] mmcblk1: mmc1:0001 AJNB4R 14.6 GiB
[ 1.542827] rockchip-usb2phy ff770000.syscon:usb2-phy@e450: vbus_drv is not assigned
[ 1.545592] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[ 1.545816] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[ 1.546483] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 1.546518] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.546612] dwhdmi-rockchip ff940000.hdmi: Detected HDMI controller 0x21:0x1a:0xa0:0xc1
[ 1.546776] mmcblk1boot0: mmc1:0001 AJNB4R partition 1 4.00 MiB
[ 1.547757] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops)
[ 1.548400] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[ 1.548423] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.548441] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[ 1.548700] mmcblk1boot1: mmc1:0001 AJNB4R partition 2 4.00 MiB
[ 1.549096] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[ 1.549398] mmcblk1rpmb: mmc1:0001 AJNB4R partition 3 4.00 MiB
[ 1.549839] parameter: 0x000000000 -- 0x000400000 (4 MB)
[ 1.549859] uboot: 0x000400000 -- 0x000800000 (4 MB)
[ 1.549874] trust: 0x000800000 -- 0x000c00000 (4 MB)
[ 1.549890] misc: 0x000c00000 -- 0x001000000 (4 MB)
[ 1.549905] resource: 0x001000000 -- 0x002000000 (16 MB)
[ 1.549919] kernel: 0x002000000 -- 0x003800000 (24 MB)
[ 1.549933] boot: 0x003800000 -- 0x005800000 (32 MB)
[ 1.549947] recovery: 0x005800000 -- 0x007800000 (32 MB)
[ 1.549961] backup: 0x007800000 -- 0x00e800000 (112 MB)
[ 1.549976] cache: 0x00e800000 -- 0x016800000 (128 MB)
[ 1.549991] system: 0x016800000 -- 0x076800000 (1536 MB)
[ 1.550005] metadata: 0x076800000 -- 0x077800000 (16 MB)
[ 1.550019] baseparamer: 0x077800000 -- 0x077c00000 (4 MB)
[ 1.550034] userdata: 0x077c00000 -- 0x3a3a00000 (12990 MB)
[ 1.550099] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[ 1.612119] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 1.738604] usb 1-1: New USB device found, idVendor=1a40, idProduct=0201
[ 1.738663] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.738691] usb 1-1: Product: USB 2.0 Hub [MTT]
[ 1.739900] hub 1-1:1.0: USB hub found
[ 1.740161] hub 1-1:1.0: 7 ports detected
[ 2.034709] rk_iommu ff903f00.iommu: Unbalanced pm_runtime_enable!
[ 2.039395] rockchip-drm display-subsystem: fb0: frame buffer device
[ 2.056689] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0
[ 2.058243] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 284; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[ 2.058337] vendor storage:20160801 ret = 0
[ 2.059412] mali ff9a0000.gpu: Probed as mali0
[ 2.064160] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.064232] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 3
[ 2.064598] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 2.064688] xhci-hcd xhci-hcd.9.auto: irq 230, io mem 0xfe800000
[ 2.064931] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.064963] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.064989] usb usb3: Product: xHCI Host Controller
[ 2.065012] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd
[ 2.065035] usb usb3: SerialNumber: xhci-hcd.9.auto
[ 2.065906] hub 3-0:1.0: USB hub found
[ 2.065973] hub 3-0:1.0: 1 port detected
[ 2.066472] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[ 2.066510] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 4
[ 2.066637] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.066814] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.066843] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.066869] usb usb4: Product: xHCI Host Controller
[ 2.066891] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd
[ 2.066913] usb usb4: SerialNumber: xhci-hcd.9.auto
[ 2.067748] hub 4-0:1.0: USB hub found
[ 2.067809] hub 4-0:1.0: 1 port detected
[ 2.070204] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 2.070253] usb usb4: USB disconnect, device number 1
[ 2.099138] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[ 2.099179] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[ 2.099459] xhci-hcd xhci-hcd.9.auto: USB bus 4 deregistered
[ 2.099493] xhci-hcd xhci-hcd.9.auto: remove, state 1
[ 2.099534] usb usb3: USB disconnect, device number 1
[ 2.100982] xhci-hcd xhci-hcd.9.auto: USB bus 3 deregistered
[ 2.105331] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.105375] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 3
[ 2.105675] xhci-hcd xhci-hcd.10.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x00030010
[ 2.105742] xhci-hcd xhci-hcd.10.auto: irq 231, io mem 0xfe900000
[ 2.105908] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.105929] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.105948] usb usb3: Product: xHCI Host Controller
[ 2.105963] usb usb3: Manufacturer: Linux 4.4.55 xhci-hcd
[ 2.105978] usb usb3: SerialNumber: xhci-hcd.10.auto
[ 2.106707] hub 3-0:1.0: USB hub found
[ 2.106750] hub 3-0:1.0: 1 port detected
[ 2.107092] xhci-hcd xhci-hcd.10.auto: xHCI Host Controller
[ 2.107118] xhci-hcd xhci-hcd.10.auto: new USB bus registered, assigned bus number 4
[ 2.107201] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.107321] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.107340] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.107358] usb usb4: Product: xHCI Host Controller
[ 2.107373] usb usb4: Manufacturer: Linux 4.4.55 xhci-hcd
[ 2.107387] usb usb4: SerialNumber: xhci-hcd.10.auto
[ 2.108080] hub 4-0:1.0: USB hub found
[ 2.108123] hub 4-0:1.0: 1 port detected
[ 2.110446] ehci-platform fe380000.usb: EHCI Host Controller
[ 2.110482] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[ 2.110695] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[ 2.122222] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[ 2.122408] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.122430] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.122449] usb usb5: Product: EHCI Host Controller
[ 2.122465] usb usb5: Manufacturer: Linux 4.4.55 ehci_hcd
[ 2.122480] usb usb5: SerialNumber: fe380000.usb
[ 2.123276] hub 5-0:1.0: USB hub found
[ 2.123330] hub 5-0:1.0: 1 port detected
[ 2.124138] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[ 2.124178] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[ 2.124346] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[ 2.179794] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.179835] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.179855] usb usb6: Product: Generic Platform OHCI controller
[ 2.179873] usb usb6: Manufacturer: Linux 4.4.55 ohci_hcd
[ 2.179888] usb usb6: SerialNumber: fe3a0000.usb
[ 2.180875] hub 6-0:1.0: USB hub found
[ 2.180924] hub 6-0:1.0: 1 port detected
[ 2.182317] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.182419] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[ 2.182445] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[ 2.182485] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[ 2.182517] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[ 2.182574] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[ 2.182590] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[ 2.182912] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[ 2.195729] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.209052] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[ 2.223839] asoc-simple-card rt5640-sound: rt5640-aif1 <-> ff890000.i2s mapping ok
[ 2.230530] input: rockchip,rt5640-codec Headphone Jack as /devices/platform/rt5640-sound/sound/card0/input1
[ 2.233836] asoc-simple-card spdif-sound: dit-hifi <-> ff870000.spdif mapping ok
[ 2.236412] rk-hdmi-dp-sound hdmi-dp-sound: control 3:0:0:ELD:0 is already present
[ 2.236458] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to add ELD: -16
[ 2.237571] rk-hdmi-dp-sound hdmi-dp-sound: multicodec <-> ff8a0000.i2s mapping ok
[ 2.237664] hdmi-audio-codec hdmi-audio-codec.8.auto: ASoC: Failed to create Playback debugfs file
[ 2.239914] dhd_module_init: in
[ 2.239917]
[ 2.239930] =======================================================
[ 2.239934] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[ 2.239937] =======================================================
[ 2.239942] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[ 2.239950] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.239959] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.239967] RTL871X: module init start
[ 2.239972] RTL871X: rtl8188eu v4.3.24_16705.20160509
[ 2.240072] ======== bcm_wlan_set_plat_data ========
[ 2.240091] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 2.240114] host_oob_irq: 71
[ 2.240129] host_oob_irq_flags=0x4
[ 2.240144] dhd_wifi_platform_load: Enter
[ 2.240187] usbcore: registered new interface driver rtl8188eu
[ 2.240215] RTL871X: module init ret=0
[ 2.240219] Power-up adapter 'DHD generic adapter'
[ 2.240264] otg_wakelock_init: No USB transceiver found
[ 2.240281] wifi_platform_set_power = 1
[ 2.240287] ======== PULL WL_REG_ON HIGH! ========
[ 2.240293] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 2.240299] [WLAN_RFKILL]: wifi turn on power. -1
[ 2.240463] sensor_init: Probe name sensors
[ 2.240490] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[ 2.243398] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 11:03:37 UTC (1358507017)
[ 2.265790] mmc2: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.267486] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.269495] mmc2: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.273313] mmc2: queuing unknown CIS tuple 0x80 (7 bytes)
M�
[ 2.332991] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
Thanks,
San
