[Fireprime] s5k4ec AF function has some error!!
48
Posted at 6/12/2018 13:05:50      View4333 | Replies3        Print      Only Author   [Copy Link] 1#
Hi,
I have a problem using the s5k4ec module that you made.
I modified your /media/video/s5k4ec.c to use Auto Focus as follows:
static unsigned int SensorConfiguration = (CFG_WhiteBalance|CFG_Effect
                                           |CFG_Scene|CFG_Focus
                                           |CFG_FocusZone);
//below is original code.
//static unsigned int SensorConfiguration = (CFG_WhiteBalance|CFG_Effect
//                                           |CFG_Scene
//                                           |CFG_FocusZone);
Without the AF function, the captured image is too burred, that is, it is not clean.
If I use AF, the image is better than no AF.
But it is still burr.
So, I debugged the code, and then I found some error in your code
the debugging message as follows:
== error log  ->why this log is happening?
[   72.292728] s5k4ec[8452] [jaym ################ single focus mode set !
[   74.265015] s5k4ec(8479): s5k4ec[8479] [jaym ######]focus state(0x4718) is error!
== source code s5k4ec.c
static int sensor_focus_af_single_usr_cb(struct i2c_client *client)
        int ret = 0;
        char cnt;
        u16 state;
        struct af_cmdinfo cmdinfo;
        //char s_zone[5],i;
        cmdinfo.cmd_tag = 0x01;
        cmdinfo.validate_bit = 0x80;
                printk("%s[%d] [jaym ################ single focus mode set !\n",SENSOR_NAME_STRING(),__LINE__);
  sensor_write(client,0xFCFC, 0xD000),
  sensor_write(client,0x0028, 0x7000),
  sensor_write(client,0x002A, 0x028E),
  sensor_write(client,0x0F12, 0x0000),
  sensor_write(client,0x002A, 0x028C),
  sensor_write(client,0x0F12, 0x0005),
  //sensor_write(client,0xffff, 150),   // delay 150ms
        cnt = 0;
        state=0x0000;
        do
                if (cnt != 0) {
                        msleep(1);
                cnt++;
                sensor_write(client,0x002E, 0x2EEE),
                ret = sensor_read(client, 0x0f12, &state);
                //printk("[jaym ] printk ######### \n");
        }while((state != 0x0002) && (cnt<100));
        if (state != 0x0002) {
                SENSOR_TR("%s[%d] [jaym ######]focus state(0x%x) is error!\n",SENSOR_NAME_STRING(),__LINE__,state);
ret = -1;
goto sensor_af_single_end;
        } else {
                SENSOR_DG("%s[%d] single focus mode set success!\n",SENSOR_NAME_STRING(),__LINE__);
sensor_af_single_end:
        return ret;
Can you help me why this is happening?
thank you
Posted at 6/15/2018 17:30:55        Only Author  2#
I fixed it,
sensor_write(client,0x002c, 0x7000);
it needs more write,,,,
But its captured image is still burred..
I need it to be more cleared.
Somebody can help???
Posted at 1/25/2026 12:40:54        Only Author  3#
This is a stellar article, thank you for sharing it with us. I got promoted and received a raise thanks to this DP-900 latest test practice. Now, Im sharing it for free with everyone. Best of luck with your career growth!
Posted at 1/29/2026 22:39:23        Only Author  4#
I walked away from the article feeling much more informed. The Reliable SDS test notes platform offers detailed material at no cost, aimed at assisting you.
