New Topic
[Linux] will Ubuntu 18.04 image be made for RK3399
153
Linux will Ubuntu 18.04 image be made for RK3399
Posted at 6/27/2018 18:37:10      View19447 | Replies28        Print      Only Author   [Copy Link] 1#
was wondering if any plans to release a 18.04 image for RK3399 are in the works
as 16.04 does not support this board much
Posted at 8/7/2018 22:43:11        Only Author  2#
I'm wondering the same.
There is also a performance concern : tests I made on diverse SBCs show a huge improvement when using 18.04.
Posted at 9/12/2018 00:53:51        Only Author  3#
It's easy to update to 18.04 yourself.
  1. sudo sed -i -- 's/xenial/bionic/g' /etc/apt/sources.list
  2. apt update && apt full-upgrade
Copy the code
is perfectly fine. You are probably running out of space on the eMMC if you use the factory image, but even then,
  1. apt -f install && apt autoremove && apt clean && apt update && apt full-upgrade
Copy the code
once or twice gives you a running 18.04LTS system.
First thing I did with my RK3399.
Posted at 9/15/2018 20:14:49        Only Author  4#
I tried so to update my firefly 3399 from 16.04 to 18.04. But in my case there is an access error
E: Could not open lock file / var / lib / dpkg / lock - open (13: Permission denied)
E: Unable to lock the administration directory (/ var / lib / dpkg /), are you root?
I also tried to enter commands through the sudo but this did not change anything.
Posted at 11/2/2018 16:23:39        Only Author  5#
Cherry Posted at 9/15/2018 20:14
just Delete lock-open
`sudo rm -f /var/lib/dpkg/lock-open`
Posted at 12/6/2018 01:41:10        Only Author  6#
Getting this error
Errors were encountered while processing:
/var/cache/apt/archives/libgles2_1.0.0-2ubuntu2.2_arm64.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
vip
Rank: 6Rank: 6
Posted at 12/6/2018 11:20:56        Only Author  7#
Actually, there's a new  ubuntu 18.04 for Firefly-RK3399 in
  http://www.t-firefly.com/doc/download/page/id/3.html
But it is in Baidu Pan up till now.  We're working on moving it to Google Drive.
vip
Rank: 6Rank: 6
Posted at 12/7/2018 10:38:20        Only Author  8#
Here comes the Ubuntu 18.04 firmware for Firefly-RK3399, with Google Drive link:
    https://drive.google.com/drive/f ... 089aMAW_4cDGF11F2ou
Uncompress the downloaded file using:
    unxz -k Firefly-RK3399-ubuntu18.04_20181017.img.xz
This firmware uses the gpt partition scheme. Therefore you need the latest
v3.4 upgrade_tool to upgrade the firmware. Download it from:
    http://download.t-firefly.com/pr ... grade_Tool_1.34.zip
To install upgrade_tool to /usr/local/bin, run:
    unzip Linux_Upgrade_Tool_1.34.zip
    cd Linux_Upgrade_Tool/Linux_Upgrade_Tool/
    chmod 755 upgrade_tool
    mv gpt_upgrade_tool
    sudo cp gpt_upgrade_tool config.ini /usr/local/bin/
Now that flashing tool `gpt_upgrade_tool` and firmware file are ready.
To upgrade from the old ubuntu 16.04, the board needs to enter MaskRom mode.
There're two methods:
1. Using the cutting edge metal tweezers following:
    http://en.t-firefly.com/index.php/doc/product/info/id/479.html
2. Or from the running Ubuntu 16.04, unplug the SD Card, and zero head zone of the eMMC by:
    sudo dd if=/dev/zero of=/dev/mmcblk? count=$((0x2000))
    # Connect the TypeC cable with PC
    sudo reboot
Flash the firmware:
    cd /path/to/the/Firefly-RK3399-ubuntu18.04_20181017.img
    gpt_upgrade_tool uf Firefly-RK3399-ubuntu18.04_20181017.img
Good luck. If any question, write here. I'll try my best to help.
Posted at 12/26/2018 03:18:36        Only Author  9#
Dear Penguin,
How is the 4K performance of this img? Is there any problem for sound and video? Did you meet same problems? If yes pls share your steps.
Posted at 1/9/2019 23:06:50        Only Author  10#
Hey Penguin,
I tried installing using your steps for ROC-RK3399-PC. But the upgrade tool wasn't detecting it.
Can you provide a direct SD Boot image for ubuntu18?
Thanks!!
Return to List
123
