Network performance
2
Network performance
Posted at 12/28/2014 18:20:30      View11836 | Replies7        Print      Only Author   [Copy Link] 1#
Hi everybody
My board has ethernet problems in 1000/full mode , iperf output indicates 1,5mbps in tcp. When i force 100/full i got 90mbps in iperf. Rsults are the same under linux and android
Is it a kernel bug ??
Thx you
Pacopad
vip
Rank: 6Rank: 6
Posted at 12/29/2014 09:18:33        Only Author  2#
show the attachme which include kernel log when connect 1000 mode.
Posted at 12/29/2014 16:32:03        Only Author  3#
Hi Zhansb,
here is the full boot log http://pastebin.com/KhHqCQwb
Then when i put the wire in 100Mbps switch
[  326.247106] libphy: stmmac-0:01 - Link is Down
[  336.087163] stmmc_pltfr_fix_mac_speed: fix speed to 100
[  336.087181] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
[  336.087190] libphy: stmmac-0:01 - Link is Up - 100/Full
I got packet loss when i ping a computer on my network.
ping 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.874 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.499 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.417 ms
64 bytes from 192.168.1.1: icmp_seq=4 ttl=64 time=0.622 ms
64 bytes from 192.168.1.1: icmp_seq=5 ttl=64 time=0.495 ms
64 bytes from 192.168.1.1: icmp_seq=6 ttl=64 time=0.390 ms
64 bytes from 192.168.1.1: icmp_seq=7 ttl=64 time=0.415 ms
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=0.461 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=0.415 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=0.469 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=0.427 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=0.491 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=0.440 ms
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=0.611 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=0.583 ms
64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=0.441 ms
64 bytes from 192.168.1.1: icmp_seq=20 ttl=64 time=0.510 ms
64 bytes from 192.168.1.1: icmp_seq=21 ttl=64 time=0.579 ms
^C
--- 192.168.1.1 ping statistics ---
21 packets transmitted, 18 received, 14% packet loss, time 19994ms
rtt min/avg/max/mdev = 0.390/0.507/0.874/0.115 ms
I'm an IT Tech so i got all basic verifications, i changed switch and wires. My network is ok with other computers and devices.
Thx for your help
Pacopad
vip
Rank: 6Rank: 6
Posted at 12/30/2014 09:47:27        Only Author  4#
make sure your network cable and router support 1000M?
if they are correct ,the log will be like this:
[  453.385496] stmmc_pltfr_fix_mac_speed: fix speed to 1000
[  453.385735] stmmc_pltfr_fix_mac_speed: fix speed for RGMII
[  453.385844] libphy: stmmac-0:01 - Link is Up - 1000/Full
Posted at 12/30/2014 16:25:38        Only Author  5#
Hi,
The 1000/full logs are in the pastebin Line 1135.
My network is giga ok , working good with computer and PS3 and synology ds415
Please could you give me a ral way to Check ?? I tryed at office i got same matter, is my board dfective ???
Pacopad
Posted at 12/30/2014 19:34:36        Only Author  6#
try connect device and computer directly .
set a static ip for device . make sure the same network segment and under the 1000/Full environment
try to ping your computer again .check the Packet loss rate and iperf your computer ip again.
Posted at 12/30/2014 21:19:42        Only Author  7#
Here are results of my tests
COMPUTER <-> FIREFLY DIRECTLY CONNECTED 1000/FULL
Mac-Pro:~ pacopad$ iperf -c 192.168.1.151 -i2 -t120
Client connecting to 192.168.1.151, TCP port 5001
TCP window size:  129 KByte (default)
[  4] local 192.168.1.1 port 50131 connected with 192.168.1.151 port 5001
[ ID] Interval       Transfer     Bandwidth
[  4]  0.0- 2.0 sec   256 KBytes  1.05 Mbits/sec
[  4]  2.0- 4.0 sec   256 KBytes  1.05 Mbits/sec
[  4]  4.0- 6.0 sec   128 KBytes   524 Kbits/sec
[  4]  6.0- 8.0 sec   128 KBytes   524 Kbits/sec
[  4]  8.0-10.0 sec  0.00 Bytes  0.00 bits/sec
[  4] 10.0-12.0 sec   128 KBytes   524 Kbits/sec
[  4] 12.0-14.0 sec  0.00 Bytes  0.00 bits/sec
^C[  4] 14.0-16.0 sec   128 KBytes   524 Kbits/sec
[  4] 16.0-18.0 sec  0.00 Bytes  0.00 bits/sec
[  4] 18.0-20.0 sec  0.00 Bytes  0.00 bits/sec
[  4] 20.0-22.0 sec  0.00 Bytes  0.00 bits/sec
[  4]  0.0-23.7 sec  1.12 MBytes   399 Kbits/sec
COMPUTER <-> FIREFLY DIRECTLY CONNECTED 100/FULL FORCED ON FIREFLY
[  4] local 192.168.1.1 port 50137 connected with 192.168.1.151 port 5001
[  4]  0.0- 2.0 sec  22.8 MBytes  95.4 Mbits/sec
[  4]  2.0- 4.0 sec  22.6 MBytes  94.9 Mbits/sec
[  4]  4.0- 6.0 sec  22.5 MBytes  94.4 Mbits/sec
[  4]  6.0- 8.0 sec  22.4 MBytes  93.8 Mbits/sec
[  4]  8.0-10.0 sec  22.4 MBytes  93.8 Mbits/sec
[  4] 10.0-12.0 sec  22.4 MBytes  93.8 Mbits/sec
[  4] 12.0-14.0 sec  22.6 MBytes  94.9 Mbits/sec
[  4] 14.0-16.0 sec  22.1 MBytes  92.8 Mbits/sec
[  4] 16.0-18.0 sec  22.5 MBytes  94.4 Mbits/sec
^C[  4]  0.0-19.4 sec   218 MBytes  94.3 Mbits/sec
COMPUTER <-> NAS SYNOLOGY THROUGH NETWORK
Mac-Pro:~ pacopad$ iperf -c 192.168.1.2 -i2 -t120
Client connecting to 192.168.1.2, TCP port 5001
[  4] local 192.168.1.1 port 50159 connected with 192.168.1.2 port 5001
[  4]  0.0- 2.0 sec   223 MBytes   935 Mbits/sec
[  4]  2.0- 4.0 sec   223 MBytes   934 Mbits/sec
[  4]  4.0- 6.0 sec   223 MBytes   935 Mbits/sec
[  4]  6.0- 8.0 sec   223 MBytes   934 Mbits/sec
[  4]  8.0-10.0 sec   223 MBytes   934 Mbits/sec
[  4] 10.0-12.0 sec   223 MBytes   935 Mbits/sec
[  4] 12.0-14.0 sec   223 MBytes   934 Mbits/sec
[  4] 14.0-16.0 sec   223 MBytes   934 Mbits/sec
[  4] 16.0-18.0 sec   223 MBytes   935 Mbits/sec
^C[  4]  0.0-18.7 sec  2.04 GBytes   935 Mbits/sec
It really think there is a problem and that's not located on my network
I 'll try to compile a 3.17 kernel to see if there are changes
Thx
Pacopad
Posted at 1/23/2026 11:27:00        Only Author  8#
That article was a real treasure trove of knowledge. Here's the New Cloud-Digital-Leader exam dumps test that helped me land my promotion and raise. It's free todaygood luck with your career progress!
