Cannot get GPIO control working via sysfs!
11
Posted at 12/15/2018 00:49:16      View5828 | Replies4        Print      Only Author   [Copy Link] 1#
Hello,
I am trying to control GPIO pins using sysfs but nothing is working. I have tried both armbian and ubuntu.
Here's my code:
[Trying to control Pin 40 on the board]
on debian, I tried:
echo "93" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio93/direction
echo 1 > /sys/class/gpio/gpio93/value
on ubuntu, I tried the above and also tried using 1093 instead of 93. Nothing works.
I get no errors, but the pin voltage is not changing.
Can someone please point me to a properly documented way to control GPIO on ROC-RK3328-CC ?
Posted at 12/15/2018 09:20:20        Only Author  2#
Is there no proper, official documentation for the GPIO pins on the ROC-RK3328-CC ?
The only "documentation" I've seen online doesn't work https://libre.computer/2018/05/1 ... e-for-aml-s905x-cc/
vip
Rank: 6Rank: 6
Posted at 12/18/2018 17:50:18        Only Author  3#
@dijitanix , which pin do you want to manipulate?
Posted at 1/15/2026 21:30:26        Only Author  4#
Im amazed at how powerful your article is, thank you for sharing! Heres the Practice test JS-Dev-101 pdf test material for free. Best of luck in your exams!
Posted at 2/9/2026 16:32:01        Only Author  5#
AmazonAWS-Solutions-AssociateԇYȤζȡPʤҡIt-Passportsdž}Υǩ``ɤԇȤǤޤǩ`ˤäơAWS-Solutions-Associate}ϤʤmϤ뤫жϤޤmϤȡʤϰĤُIǤޤIt-PassportsAWS-Solutions-Associate}ϱؤʤγɹصEǤ
