ROC-RK3308-CC Docker container for Buildroot building
1661
administrator
Rank: 9Rank: 9Rank: 9
Posted at 4/13/2019 10:26:09      View4672 | Replies5        Print      Only Author   [Copy Link] 1#
Preface
This is a Docker container for Buildroot building. It was created to support the Firefly Open Source Project. We install the required dependencies and make the development environment based on Ubuntu 16.04 LTS.
It currently only supports to ROC-RK3308-CC Buildroot SDK.
Install Docker CE
To install Docker CE, you need the 64-bit version of one of these Ubuntu versions:
  • Bionic 18.04 (LTS)
  • Xenial 16.04 (LTS)
  • Trusty 14.04 (LTS) (older than Docker CE v18.06)
You can refer to Get Docker CE for Ubuntu to install Docker CE.
The Automatic tool: DKCook
DKCook is a hell script programming, put at FFTools/DockerCook/.
If you cant find FFTools, please update the SDK.
DKCookdefault use a docker image tchip/buildroot-builderit will automatically download the buildroot-builder from Docker Hub.
To build the SDK, you can add ./FFTools/DockerCook/DKCook in front of the building command. As below:
Building the whole SDK
  1. $ cd SDK/
  2. $ ./FFTools/DockerCook/DKCook ./build.sh
Copy the code
Building kernel
  1. $ cd SDK/
  2. $ ./FFTools/DockerCook/DKCook ./build.sh kernel
Copy the code
Or building kernel step by step
  1. $ cd SDK/
  2. $ ./FFTools/DockerCook/DKCook --run
Copy the code
NOTE
If you have build the SDK on PC, and want to do it in container instead. Or the opposite. You must rebuild the whole SDK with new environment(rm SDK/buildroot/output/ directory), to avoid some misstake.
Advanced
If you are familiar with Docker, you can customize the Docker operation by referring to the following.
Docker image from
There are two ways to get Docker image:
  • Generating a Docker image by Dockerfile
  • Get the docker image from Docker Hub
Generating the Docker image
Github for Dockerfile: https://github.com/T-Firefly/buildroot-builder
Get the project:
  1. $ git clone https://github.com/T-Firefly/buildroot-builder.git
Copy the code
Run commands
  1. $ cd DockerCook/
  2. $ docker build -t buildroot-builder .
Copy the code
Download the Docker image
You can download the docker image from Docker Hub , search for tchip/buildroot-builder.
Run commands:
  1. $ docker pull tchip/buildroot-builder:latest
Copy the code
Command line
The container default working directory is /home/project, it is also a mountpoint that can be used to mount your current working directory into the container, like:
  1. docker run -it --rm \
  2.             -e USER_ID=$UID \
  3.             --mount type=bind,source="$PWD",target="/home/project" \
  4.             buildroot-builder \
  5.             /bin/bash
Copy the code
Run bash into container, to build the SDK refer to Building System Firmware.
Docs
Docker Documentation
Access Firefly Wiki to know more
Posted at 1/10/2026 05:19:53        Only Author  2#
Fast2test의Microsoft인증 MB-330덤프는 인터넷에서 검색되는Microsoft인증 MB-330시험공부자료중 가장 출중한 시험준비 자료입니다. Microsoft인증 MB-330덤프를 공부하면 시험패스는 물론이고 IT지식을 더 많이 쌓을수 있어 일거량득입니다.자격증을 취득하여 자신있게 승진하여 연봉협상하세요.
Posted at 1/11/2026 06:19:40        Only Author  3#
A޵ģҪărֵLԇһ҂Fast2test SalesforceMule-Dev-202ԇӖYϡ҂Fast2testԞITJC{oĿǰW·ܚgӭеӖYϾWվMule-Dev-202ԇšIеһ̱@NҵYκΕr@ñ^Ҫ҂C׌һpͨ^ԇҲ׌Ĺճ׃ζ߀ԎھSµ;͙C@ڌ@rXărֵhh@X
Posted at 1/11/2026 22:39:58        Only Author  4#
PSM-IIIԇY}ϸƷ|ǤꡢԇY˺g˺ϸ񤹤Τޤ PSM-IIIԇY|ˤꡢ99κϸʤȸߤҥåʤä뤿ᡢScrumԇY˺ϸǤʤȤ䤹ҪϤޤ PSM-IIIԇYȥȤϡTҤˤäƾ졢UYNʌTҤˤäƳJ졢ՓȌg_k״rˏꤸƸ¤ޤ PSM-IIIɥȥȤϡԇY򥷥ߥ`Ȥƥߥ󥰙CܤϤ뤳ȤǤޤ
Posted at 1/18/2026 13:42:31        Only Author  5#
Thank you for your article, it was incredibly thought-provoking. The F5CAB5 valid exam camp file exam is near! Hope I nail it!
Posted at 2/8/2026 13:59:03        Only Author  6#
Your article is absolutely mesmerizing, thank you for sharing! About to face the HPE0-G04 latest free study questions exam C hoping for good results!
