[Linux] rk3x-i2c ff160000.i2c: timeout,
16
Linux rk3x-i2c ff160000.i2c: timeout,
Posted at 4/23/2019 15:45:21      View12576 | Replies6        Print      Only Author   [Copy Link] 1#
hello,
System. ubuntu 16.04..
I've got the error..
[ 1226.207054] rk3x-i2c ff160000.i2c: timeout, ipd: 0x10, state: 1
[ 1226.208047] cpu cpu0: _set_opp_voltage: failed to set voltage (1125000 1125000 1125000 mV): -110
[ 1226.209343] cpufreq: __target_index: Failed to change cpu frequency: -110
why does it happen?
Regards,
Nick
vip
Rank: 6Rank: 6
Posted at 4/25/2019 14:33:05        Only Author  2#
Hi @nick76, from your log, it seems that the RK805 (PMU) is having trouble in i2c communication,
which then is unable to provide the specific regulator voltage for cpu0.
Is this error always happening? Could you try the latest 18.04 firmware?
restricted members
Posted at 1/9/2026 21:56:12        Only Author  3#
JPNTestNCA-AIIO}ϵʤ100_뤳ȤǤޤΆ}ä줾ˤ{ԇY˺ϸ񤵤ޤ󡢤ϤʤȫȻŬҪʤȤζǤϤޤ󡣤ʤҪΤϡ}˳뤹٤ƤΆ}愇㏊뤳ȤǤηǡԇYܤȤ˺g˒QȤǤޤǤJPNTestΆ}ϤʤԇYΜʂ䤹rg˹s뤳ȤǤޤϤʤNCA-AIIOJԇY˺ϸǤ뱣ϤǤYϤǤǤϡ礯JPNTestΥȤ򥯥åƆ}ُ뤷ޤ礦ˡُ뤹ǰˡYϤΥץԇȤǤޤСʤԷdž}Ʒ|ɤ_뤳ȤǤޤ
Posted at 1/10/2026 23:05:50        Only Author  4#
What a motivating article, thanks for sharing it with us! Sharing Latest Databricks-Certified-Professional-Data-Engineer exam cost exam questions for freeopen the door to promotions and salary increases!
Posted at 1/22/2026 18:37:25        Only Author  5#
The logic in the article is very clear, and it has helped me understand many complex concepts. The H12-811_V1.0-ENU reliable test cram pdf exam questions are free for everyone. Best of luck in your studies!
restricted members
Posted at 1/27/2026 15:20:24        Only Author  6#
This article is truly magnificent, thank you for sharing your knowledge. Here goes the Project-Management latest test camp pdf exam! Hoping for success!
restricted members
Posted at 3/8/2026 21:56:58        Only Author  7#
Im in awe of your article, thank you for sharing! Reliable 1z0-1075-25 real exam is a free resource, full of valuable content to help you succeed.
