[General] HPE0-S59 Practice Exam Questions, Verified Answers - Pass Your Exams For Sure!
75
General HPE0-S59 Practice Exam Questions, Verified Answers - Pass Your Exams For Sure!
Posted at 1/8/2026 20:02:15      View153 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 HP HPE0-S59 dumps are available on Google Drive shared by Lead2PassExam: https://drive.google.com/open?id=1jEv9e88v51XMsrRxhC-tlkcDdWPdByu2
As long as you buy our HPE0-S59 practice materials and take it seriously consideration, we can promise that you will pass your HPE0-S59 exam and get your certification in a short time. We can claim that if you study with our HPE0-S59 Guide quiz for 20 to 30 hours, you will be confident to pass the exam for sure. So choose our exam braindumps to help you review, you will benefit a lot from our HPE0-S59 study guide.
The path to achieving success in the HP HPE0-S59 certification ExamIt's not easy to become an HPE0-S59 certified professional. The first step is to pass your HPE0-S59 exam with high marks. The second step is to choose the right HPE0-S59 exam preparation material. But how do you choose the best study guide?
  • Check out the price and quality
The most expensive product does not always guarantee high quality. It's good for you to check out reviews of different products online before making a buying decision.
  • Check out the coverage
Every exam guide covers a different range of topics, so before choosing one, make sure that it meets your needs and can help you pass your exam successfully. HP HPE0-S59 Exam Dumps will enhance your skills.
  • Check out the format
Make sure that the study guide has all the necessary features such as examples, practice exams and explanations for answers so that you can prepare yourself well for your exam
Valid HPE0-S59 Latest Dumps Free, HPE0-S59 Preparation StoreHere, we provide you with HPE0-S59 accurate questions & answers which will be occurred in the actual test. About explanations, the difficult issues will be along with detail explanations, so that you can easy to get the content of our HP HPE0-S59 pdf vce and have a basic knowledge of the key points. Besides, you can choose the HPE0-S59 Vce Format files for simulation test. It can help you enhance your memory and consolidate the knowledge, thus the successful pass is no longer a difficult thing.
HPE Compute Solutions Sample Questions (Q67-Q72):NEW QUESTION # 67
Your customer has an HPE Synergy frame equipped with a D3940 Storage Module. Each of the compute nodes has an appropriate storage controller Installed and two 12Gb SAS switches installed in the first fabric.
The customer reports that compute nodes cannot access the storage module. What should you verify first when troubleshooting this problem?
  • A. If there Is a logical interconnect created based on the 12Gb SAS switches.
  • B. If the D3940 storage module is property licensed through HPE OneView interface.
  • C. If the D3940 module is imported in managed state that allows volume provisioning.
  • D. If there is at least one ISCSI network configured that will provide access to the module.
When compute nodes cannot access the D3940 Storage Module in an HPE Synergy environment, the first thing to check is whether a logical interconnect has been created based on the 12Gb SAS switches. Logical interconnects are essential for defining the connection and communication pathways between the compute nodes and the storage module. Without a proper logical interconnect configuration, the compute nodes will not be able to access the storage module.
NEW QUESTION # 68
Your customer wants to add dedicated Fibre Channel connectivity to the HPE Synergy frame running HPE Synergy 480 Gen10 compute modules, each with one CPU socket populated.
Currently they use two 12 Gb SAS switches and two HPE Virtual Connect SE 100Gb F32 Modules for HPE Synergy installed in third fabric.
What must be done to enable dedicated FC connectivity for this HPE Synergy frame?
  • A. For VC-FC modules, all of server facing ports must be property licensed.
  • B. For Brocade switches, a logical interconnect group must be created in HPE OneView.
  • C. SAS switches must be moved to second fabric and FC modules Installed in the first one.
  • D. A second CPU must be installed for all HPE Synergy 480 Gen10 compute nodes.
To enable dedicated Fibre Channel (FC) connectivity in an HPE Synergy frame, if using Brocade switches, it is necessary to create a logical interconnect group in HPE OneView. This group defines the configuration and management of FC connectivity for the compute modules. Properly configuring and managing this logical interconnect group ensures that the compute modules can establish dedicated FC connections.
NEW QUESTION # 69
Your customer with an HPE Synergy environment needs to prevent a timeout and loss of communication during an external switch firmware upgrade. Which parameter can the customer configure within an uplink set to meet their requirements?
  • A. The customer should set the connection mode to manual.
  • B. The customer should disable LACP failover trigger.
  • C. The customer should set LACP timer to long.
  • D. The customer should enable LACP load-balancing.
NEW QUESTION # 70
Your customer manages HPE Synergy using HPE OneView. For one of its projects, the company purchased 50 HPE.
ProLiant DK385 Gen10 Plus v2. They plan to manage the new systems using HPE OneView as well.
What should the customer do to manage rack system using HPE OneView?
  • A. add the rack system to the HPE OneView instance used to manage HPE Synergy to centralize management of all systems.
  • B. Deploy HPE OneView Global Dashboard and add the rack systems there, as AMD systems are not directly in HPE OneView.
  • C. connect the rack system to an IPDU and add the IPDU to the HPE. OneView instance that is used for HPE synergy management.
  • D. Deploy an HPE OneView virtual appliance, and, after configuration, use it to manage only the rack systems.
HPE OneView can manage both HPE Synergy and HPE ProLiant rack servers, but not from the same appliance instance when Synergy is involved.
When HPE OneView is used to manage HPE Synergy, it uses a special Synergy-specific appliance (Composer or Composer2), which cannot directly manage rack servers like the HPE ProLiant DL385 Gen10 Plus v2.
To manage rack servers, the customer must deploy a separate HPE OneView virtual appliance dedicated for that purpose.
Once deployed and configured, this appliance can manage HPE ProLiant rack servers independently.
NEW QUESTION # 71
Your customer has the following HPE Synergy setup:
- 15 HPE Synergy 12000 frames with 50Gb connectivity to each server
port
- 2 HPE Composer 2 modules
- 15 HPE D3940 Storage Modules, one per frame
- 2 HPE 12Gb SAS switches per frame
Which statement about this setup is true?
  • A. To manage 15 frames, additional HPE Composers are required.
  • B. The customer must create at least five logical enclosures for this setup.
  • C. If properly cabled, any compute node can access any HPE D3490 storage module
  • D. The customer can install up to 12 HPE Synergy 480 compute nodes per frame.
With 15 HPE Synergy 12000 frames, the customer must create multiple logical enclosures to manage the setup efficiently. HPE Synergy typically supports up to five frames per logical enclosure, meaning that at least five logical enclosures would be necessary to manage all 15 frames. This ensures proper organization, management, and scalability of the resources.
NEW QUESTION # 72
Many people prefer to buy our HPE0-S59 study materials because they deeply believe that if only they buy them can definitely pass the test. The reason why they like our HPE0-S59 study materials is that our HPE0-S59 study materials quality is very high and the service is wonderful. For years we always devote ourselves to perfecting our HPE0-S59 Study Materials and shaping our products into the model products which other companies strive hard to emulate.
HPE0-S59 Preparation Store: https://www.lead2passexam.com/HP/valid-HPE0-S59-exam-dumps.html
BTW, DOWNLOAD part of Lead2PassExam HPE0-S59 dumps from Cloud Storage: https://drive.google.com/open?id=1jEv9e88v51XMsrRxhC-tlkcDdWPdByu2
Posted at 1/12/2026 00:59:58        Only Author  2#
Your article is fantastic, I really appreciate you sharing it! Heres the Valid visual 312-85 cert test test that helped me get a promotion and pay raise. It's free for everyone today. Best of luck with your career!
