[General] Pass Guaranteed Quiz 2026 Juniper High Hit-Rate JN0-664: Test Service Provider,
72
【General】 Pass Guaranteed Quiz 2026 Juniper High Hit-Rate JN0-664: Test Service Provider,
Posted at 1/9/2026 15:09:41      View:163 | Replies:2        Print      Only Author   [Copy Link] 1#
What's more, part of that VCE4Dumps JN0-664 dumps now are free: https://drive.google.com/open?id=1HDLMCJnGcKQPaBcN_JPT6GAk8jOwG_s3
Even you have no basic knowledge about the JN0-664 study materials. You still can pass the exam with our help. The key point is that you are serious on our JN0-664 exam questions and not just kidding. Our JN0-664 practice engine can offer you the most professional guidance, which is helpful for your gaining the certificate. And our JN0-664 learning guide contains the most useful content and keypoints which will come up in the real exam.
If you buy the Software or the APP online version of our JN0-664 study materials, you will find that the timer can aid you control the time. Once it is time to submit your exercises, the system of the JN0-664 preparation exam will automatically finish your operation. After a several time, you will get used to finish your test on time. If you are satisfied with our JN0-664 training guide, come to choose and purchase.
Latest JN0-664 Exam Vce & JN0-664 Simulated TestWe provide the free demos before the clients decide to buy our JN0-664 study materials. The clients can visit our company’s website to have a look at the demos freely. Through looking at the demos the clients can understand part of the contents of our JN0-664 study materials, the form of the questions and answers and our software, then confirm the value of our JN0-664 Study Materials. If the clients are satisfied with our JN0-664 study materials they can purchase them immediately. They can avoid spending unnecessary money and choose the most useful and efficient JN0-664 study materials.
Juniper JN0-664 certification exam is a computer-based test that consists of 65 multiple-choice questions. Candidates have 120 minutes to complete the exam, and they must achieve a passing score of 65% or higher to earn the certification. JN0-664 Exam is administered by Pearson VUE, and it can be taken at any Pearson VUE testing center worldwide.
Juniper Service Provider, Professional (JNCIP-SP) Sample Questions (Q49-Q54):NEW QUESTION # 49
A packet is received on an interface configured with transmission scheduling. One of the configured queues In this scenario, which two actions will be taken by default on a Junos device? (Choose two.)
  • A. The excess traffic will be discarded
  • B. The exceeding queue will be considered to have positive bandwidth credit
  • C. The excess traffic will use bandwidth available from other queues
  • D. The exceeding queue will be considered to have negative bandwidth credit.
https://www.juniper.net/document ... urity-overview.html When a Junos device receives a packet on an interface with transmission scheduling, traffic is placed into different queues based on Class of Service (CoS) policies. If a queue exceeds its allocated bandwidth, Junos has default behaviors for handling excess traffic.
Key Junos Behaviors for Transmission Scheduling
Queues Can Borrow Bandwidth from Other Queues ✅
If a queue has excess traffic, it can use bandwidth from underutilized queues, as long as bandwidth is available.
Reference from Juniper Documentation:
"By default, each queue can exceed the assigned bandwidth if additional bandwidth is available from other queues." Queues Have Credit-Based Tracking ✅ A queue that stays within its allocated bandwidth is considered to have positive bandwidth credit.
A queue that exceeds its allocation is considered to have negative bandwidth credit.
"A queue receiving traffic in excess of its bandwidth allocation is considered to have negative bandwidth credit." Evaluating the Answer Choices
✅ B. The exceeding queue will be considered to have negative bandwidth credit.
Correct, because when a queue exceeds its allocated bandwidth, Junos assigns it negative bandwidth credit.
This means the queue is in debt and must recover before it can transmit additional packets.
✅ C. The excess traffic will use bandwidth available from other queues.
Correct, because Junos allows excess traffic to borrow bandwidth from underutilized queues by default.
If a forwarding class does not use its allocated bandwidth, other queues can borrow the unused bandwidth.
Why the Other Answers Are Incorrect?
❌ A. The excess traffic will be discarded.
Incorrect, because Junos does not immediately discard excess traffic unless the queue cannot borrow bandwidth.
By default, Junos allows bandwidth sharing, and only if no bandwidth is available does it drop packets.
❌ D. The exceeding queue will be considered to have positive bandwidth credit.
Incorrect, because when a queue exceeds its assigned bandwidth, it gets negative bandwidth credit, not positive credit.
Verified Juniper Official Reference
Junos CoS Transmission Scheduling Overview
NEW QUESTION # 50
Which two statements are correct about VPLS tunnels? (Choose two.)
  • A. BGP-signaled VPLS tunnels can use either RSVP or LDP between the PE routers.
  • B. BGP-signaled VPLS tunnels require manual provisioning of sites.
  • C. LDP-signaled VPLS tunnels only support control bit 0.
  • D. LDP-signaled VPLS tunnels use auto-discovery to provision sites
https://www.juniper.net/document ... rvice/topics/task/v
https://www.juniper.net/document ... iguring-vpls-routin
NEW QUESTION # 51
Exhibit
You are running a service provider network and must transport a customer's IPv6 traffic across your IPv4-based MPLS network using BGP You have already configured mpis ipv6-tunneling on your PE routers.
Which two statements are correct about the BGP configuration in this scenario? (Choose two.)
  • A. You must configure family inet6 labcled-unicast between PE routers.
  • B. You must configure family inet6 unicaat between PE and CE routers.
  • C. You must configure family inet6 add-path between PE and CE routers.
  • D. You must configure family inet6 unicast between PE routers
To transport IPv6 traffic over an IPv4-based MPLS network using BGP, you need to configure two address families: family inet6 labeled-unicast and family inet6 unicast. The former is used to exchange IPv6 routes with MPLS labels between PE routers, and the latter is used to exchange IPv6 routes without labels between PE and CE routers. The mpis ipv6-tunneling command enables the PE routers to encapsulate the IPv6 packets with an MPLS label stack and an IPv4 header before sending them over the MPLS network.
NEW QUESTION # 52
  • A. The exceeding queue will be considered to have positive bandwidth credit
  • B. The excess traffic will be discarded
  • C. The excess traffic will use bandwidth available from other queueses
https://www.juniper.net/document ... ept/cos-transmissio
NEW QUESTION # 53
Exhibit
R1 and R8 are not receiving each other's routes
Referring to the exhibit, what are three configuration commands that would solve this problem? (Choose three.)
  • A. Configure loops and advertise-peer-as on routers in AS 64497 and AS 64450.
  • B. Configure remove-private on advertisements from AS 64500 toward AS 64499
  • C. Configure as-override on advertisement from AS 64500 toward AS 64512.
  • D. Configure remove-private on advertisements from AS 64497 toward AS 64498
  • E. Configure loops on routers in AS 65412 and advertise-peer-as on routers in AS 64498.
Answer: B,D,E
The problem in this scenario is that R1 and R8 are not receiving each other's routes because of private AS numbers in the AS path. Private AS numbers are not globally unique and are not advertised to external BGP peers. To solve this problem, you need to do the following:
* Configure loops on routers in AS 65412 and advertise-peer-as on routers in AS 64498. This allows R5 and R6 to advertise their own AS number (65412) instead of their peer's AS number (64498) when sending updates to R7 and R8. This prevents a loop detection issue that would cause R7 and R8 to reject the routes from R5 and R62.
* Configure remove-private on advertisements from AS 64497 toward AS 64498 and from AS 64500
* toward AS 64499. This removes any private AS numbers from the AS path before sending updates to external BGP peers. This allows R2 and R3 to receive the routes from R1 and R4, respectively3.
NEW QUESTION # 54
No matter when you need help on our JN0-664 training questions, the after-sale service staffs in our company share a passion for you, an intense focus on teamwork, speed and agility, and a commitment to trust and respect for all individuals. At present, our company is a leading global provider of JN0-664 Preparation exam in the international market. And as you know, the first-class quality comes with the first-class service. So you will find our JN0-664 is the best in every detail!
Latest JN0-664 Exam Vce: https://www.vce4dumps.com/JN0-664-valid-torrent.html
P.S. Free & New JN0-664 dumps are available on Google Drive shared by VCE4Dumps: https://drive.google.com/open?id=1HDLMCJnGcKQPaBcN_JPT6GAk8jOwG_s3
Posted at 1/11/2026 12:03:32        Only Author  2#
Such an outstanding article, thank you for your generosity in sharing. The Latest BUS105 practice questions ppt platform offers comprehensive content for free, aimed at helping you.
Posted at 2/13/2026 15:00:03        Only Author  3#
This article is outstanding, I’m so grateful for your sharing. I used the JN0-224 high quality to earn a promotion and salary boost. Now, it’s free for everyone. Best of luck on your career journey!
