[General] Quiz 1Z1-947 - Oracle GoldenGate 19c Implementation Professional¨CValid Complete
83
¡¾General¡¿ Quiz 1Z1-947 - Oracle GoldenGate 19c Implementation Professional¨CValid Complete
Posted at 1/9/2026 18:43:08      View£º272 | Replies£º4        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of iPassleader 1Z1-947 dumps for free: https://drive.google.com/open?id=1FsIX180NkzV2W0N4bzyUuNRaaeSu1vn9
In our software version of 1Z1-947 exam questions the unique point is that you can take part in the 1Z1-947 practice test before the real 1Z1-947 exam. You never know what you can till you try. so that they can enrich their knowledge before the real 1Z1-947 exam. However, confidence in yourself is the first step on the road to success. Our mock exam provided by us can help every candidate to get familiar with the Real 1Z1-947 Exam, which is meaningful for you to take away the pressure and to build confidence in the approach.
Obtaining an IT certification shows you are an ambitious individual who is always looking to improve your skill set. Most companies think highly of this character. Our 1Z1-947 exam original questions will help you clear exam certainly in a short time. You don't need to worry about how difficulty the exams are. iPassleader release the best high-quality 1Z1-947 Exam original questions to help you most candidates pass exams and achieve their goal surely.
Free PDF 2026 1Z1-947: Trustable Oracle GoldenGate 19c Implementation Professional Complete Exam DumpsEach format of the Oracle Certification Exams not only offers updated exam questions but also additional benefits. A free trial of the Oracle GoldenGate 19c Implementation Professional (1Z1-947) exam dumps prep material before purchasing, up to 1 year of free updates, and a money-back guarantee according to terms and conditions are benefits of buying Oracle GoldenGate 19c Implementation Professional (1Z1-947) real questions today. A support team is also available 24/7 to answer any queries related to the Oracle 1Z1-947 exam dumps.
Oracle GoldenGate 19c Implementation Professional Sample Questions (Q140-Q145):NEW QUESTION # 140
Which Oracle GoldenGate parameter manages conflicts between initial load and change replication?
  • A. HandleCollisions
  • B. PASSTHRU
  • C. CheckpointTable
  • D. DiscardFile
HandleCollisions, specified in the Replicat parameter file. Should be turned off after initial load is complete.
NEW QUESTION # 141
What is implemented by Oracle GoldenGate to be able to obtain trail files from the source when the source Distribution Server cannot initiate communication with the target where the Receiver Server is?
  • A. Microservices Architecture Authentication will initiate communication for the Distribution Server.
  • B. A secured port must be implemented and opened by the target to enable the source Distribution Server to be able to initiate communication with the target's Receiver Server.
  • C. A Receiver Server can pull trail files from Distribution Server using a single port for Reverse proxy.
  • D. The Extract will directly send trail files for the Replicat to receive and apply changes.
In Oracle GoldenGate Microservices Architecture, when the source Distribution Server cannot initiate outbound communication (e.g., due to firewall or network restrictions), the Receiver Server on the target can be configured to pull trail files using Reverse Proxy mode - establishing a single, secure inbound connection.
NEW QUESTION # 142
Which of the following is a typical Oracle GoldenGate Manager parameter?
  • A. ExtTrail
  • B. Port
  • C. DiscardFile
  • D. RmtHost
Port, DynamicPortList, Autostart, AutoRestart, Lag parameters, PurgeOldExtracts, and others. These can be found in the section titled "Manager Parameter Categories."
NEW QUESTION # 143
When using CHECKPOINT BEFORE for EVENTACTIONS, what will an Extract do?
  • A. Extract will Abend while processing the transaction.
  • B. Extract will checkpoint on the starting boundary of the transaction.
  • C. Extract will stop at the end of the transaction.
  • D. Extract will checkpoint at the end of the transaction.
The CHECKPOINT BEFORE clause in EVENTACTIONS causes the Extract to record a checkpoint at the beginning of the transaction, ensuring any triggered action can safely be retried if needed.
NEW QUESTION # 144
Oracle GoldenGate Software Command Interface (GGSCI) is the Oracle GoldenGate command-line utility. You use GGSCI commands to configure, control, and monitor Oracle GoldenGate. GGSCI commands can be collected in a text script called an Obey (.oby) file. How can it be run in Obey scripts and also used in Microservices architecture?
  • A. Launch GGSCI and run from the GGSCI prompt.
  • B. Run scripts from adminclient.
  • C. Log into source or target database as user oggadmin and run script at SQL prompt.
  • D. Run it on the OS logged in as user oggadmin.
For Microservices Architecture, run Obey scripts using the adminclient.
NEW QUESTION # 145
Now we can say that the Oracle 1Z1-947 exam practice questions are real, valid, and updated as per the Oracle GoldenGate 19c Implementation Professional exam syllabus. So rest assured that with the Oracle 1Z1-947 Exam Practice test questions you can ace your exam preparation quickly and be ready to perform well in the final Oracle 1Z1-947 certification exam.
1Z1-947 Pdf Pass Leader: https://www.ipassleader.com/Oracle/1Z1-947-practice-exam-dumps.html
Oracle 1Z1-947 Complete Exam Dumps The aftersales groups are full of good natured employees who are diligent and patient waiting for offering help for you, Exercise Studying for your 1Z1-947 Pdf Pass Leader - Oracle GoldenGate 19c Implementation Professional exam doesn¡¯t have to mean sitting in front of a desk all day/night, Oracle 1Z1-947 Complete Exam Dumps We always insist the aims that serve our customers and deliver customer-centric service, So many customers have been attracted by our 1Z1-947 test guide material.
While it may not be standard, this type of training can demonstrate Authorized 1Z1-947 Certification the breadth of your knowledge as well as your willingness to hone your skills, even in areas where most no longer or never) tread.
Best Oracle 1Z1-947 Complete Exam Dumps Professionally Researched by Oracle Certified TrainersYet a scant five years after introduction, 1Z1-947 Ford killed the Contour due to a plunge in what had already been lackluster sales, The aftersales groups are full of good Authorized 1Z1-947 Certification natured employees who are diligent and patient waiting for offering help for you.
Exercise Studying for your Oracle GoldenGate 19c Implementation Professional exam doesn¡¯t have to mean sitting Authorized 1Z1-947 Certification in front of a desk all day/night, We always insist the aims that serve our customers and deliver customer-centric service.
So many customers have been attracted by our 1Z1-947 Test Guide material, With regard to the shining points of our 1Z1-947 latest questions we really have a lot to say, since our 1Z1-947 testking pdf is compiled by the leading experts who are coming from different countries in the world, our 1Z1-947 accurate torrent has been proven to be the best study materials for the exam during the nearly 10 years.
P.S. Free & New 1Z1-947 dumps are available on Google Drive shared by iPassleader: https://drive.google.com/open?id=1FsIX180NkzV2W0N4bzyUuNRaaeSu1vn9
Posted at 1/18/2026 08:13:24        Only Author  2#
Your article has made a real difference to me, thank you! Wishing everyone good luck with their exams¡ªfree Valid C_P2W62_2023 test collection materials questions are now available!
Posted at 2/3/2026 23:52:50        Only Author  3#
목표를 이루는 방법은 여러가지가 있는데 어느 방법을 선택하면 가장 빨리 목표를 이룰수 있을가요? Microsoft인증 MB-500시험을 패스하는 길에는ITDumpsKR의Microsoft인증 MB-500덤프를 공부하는 것이 가장 좋은 방법이라는것을 굳게 약속드립니다. ITDumpsKR의Microsoft인증 MB-500덤프는 시험문제에 초점을 두어 제작된 공부자료이기에Microsoft인증 MB-500패스를 가장 빠른 시일내에 한방에 할수 있도록 도와드립니다.
Posted at 2/23/2026 18:50:05        Only Author  4#
This article is simply incredible, thank you for sharing! Free NEX valid test lab questions materials¡ªpromotion and salary increase are just a click away!
Posted at 4/19/2026 20:41:38        Only Author  5#
That article was a real treasure trove of knowledge. Enhance your IT knowledge and get free Exam H35-210_V2.5 Tests. Wishing you success!
