[General] Quiz EAEP2201 - Professional Enterprise Administration Professional 2201 New Stu
124
【General】 Quiz EAEP2201 - Professional Enterprise Administration Professional 2201 New Stu
Posted at 1/9/2026 23:47:38      View:116 | Replies:3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpsKing EAEP2201 dumps from Cloud Storage: https://drive.google.com/open?id=1HBi6JgkyRJNs_C3ngREBVN6Z51Rn9Qqn
Perhaps you have also seen the related training tools about Esri certification EAEP2201 exam on other websites, but our DumpsKing has a pivotal position in the field of IT certification exam. DumpsKing research materials can 100% guarantee you to pass the exam. With DumpsKing your career will change and you can promote yourself successfully in the IT area. When you select DumpsKing you'll really know that you are ready to pass Esri Certification EAEP2201 Exam. We not only can help you pass the exam successfully, but also will provide you with a year of free service.
Wrong topic tend to be complex and no regularity, and the EAEP2201 torrent prep can help the users to form a good logical structure of the wrong question, this database to each user in the simulation in the practice of all kinds of wrong topic all induction and collation, and the EAEP2201 study question then to the next step in-depth analysis of the wrong topic, allowing users in which exist in the knowledge module, tell users of our EAEP2201 Exam Question how to make up for their own knowledge loophole, summarizes the method to deal with such questions for, to prevent such mistakes from happening again.
High-quality EAEP2201 – 100% Free New Study Materials | EAEP2201 Reliable Test AnswersIn the matter of quality, our EAEP2201 practice engine is unsustainable with reasonable prices. Despite costs are constantly on the rise these years from all lines of industry, our EAEP2201 learning materials remain low level. That is because our company beholds customer-oriented tenets that guide our everyday work. The achievements of wealth or prestige is no important than your exciting feedback about efficiency and profession of our EAEP2201 Practice Engine. So our EAEP2201 practice materials are great materials you should be proud of and we are!
Esri Enterprise Administration Professional 2201 Sample Questions (Q19-Q24):NEW QUESTION # 19
A GIS administrator is analyzing the usage statistics of ArcGIS Enterprise. The administrator needs to pull tabular statistics on various groups and users about the type of content that they produce and consume.
Which action should the administrator perform?
  • A. Open ArcGIS Server statistics to create a report for commonly used items.
  • B. Run usage reports in Portal for ArcGIS to determine the effect on the organization.
  • C. Use ArcGIS Monitor to capture desired information over a period of time in a report.
NEW QUESTION # 20
A GIS administrator must configure ArcGIS Server so that onlyspecific groups and roles from the identity storecan administer it.
  • A. Disable the primary administrator account
  • B. Configure role-based access through the ArcGIS Server Manager
  • C. Define the shared key used to generate an ArcGIS token
  • D. Use a group-managed service account to administer the server
Theprimary site administrator accountin ArcGIS Server is abuilt-in accountthat bypasses external identity store configurations. To ensureonly users from a configured identity store(e.g., Active Directory) can administer the site, the primary site admin account must bedisabledafter alternative administrative access has been confirmed.
From ArcGIS Server documentation:
"After you configure your ArcGIS Server to use users and roles from an identity store (LDAP or Active Directory), you can disable the primary site administrator account to prevent bypassing the identity store."
* OptionBrelates to token security, not access control.
* OptionCis about running the service securely, not defining user permissions.
Reference:ArcGIS Enterprise -Managing Access Using Identity Stores and Disabling the Primary Site Administrator Account
NEW QUESTION # 21
A user must create groups, edit features, and create web apps. This user will also create print layouts, charts, and animations using ArcGIS Pro. The organization has noadditional add-on licenses.
Which user type should be configured for this user?
  • A. Creator
  • B. Editor
  • C. GIS Professional
TheGIS Professionaluser type includes access toArcGIS Pro, which is required for creating print layouts, charts, animations, and conducting advanced analysis. It also includes capabilities such as creating groups, editing features, and creating web apps within the ArcGIS Enterprise portal-without needing additional add- on licenses.
TheCreatoruser type supports most web GIS tasks butdoes not include ArcGIS Prounless an add-on license is assigned. TheEditoruser type is the most limited and is intended for editing existing content only, not for creating or managing groups or web applications.
Reference Source:ArcGIS Enterprise documentation - User types, capabilities, and included applications
NEW QUESTION # 22
An ArcGIS analyst is curating a series of basemaps for field crews editing utility infrastructure in the field.
The analyst must ensure optimal performance.
Which type of service should be published?
  • A. Vector tile service
  • B. Dynamic map service
  • C. Cached map service
For field operations, Vector Tile Services are highly efficient and suitable for basemaps. They offer fast rendering, smaller file sizes, and are easily scalable across various devices, including those with limited bandwidth or processing capabilities. Vector tiles also support dynamic styling and are ideal for offline use, which is often necessary for field crews working in areas with limited connectivity.
Cached map services (Option A) are raster-based and can be larger in size, making them less optimal for mobile use. Dynamic map services (Option C) require real-time data rendering, which can be resource- intensive and may not perform well in field conditions with limited connectivity.
Reference Source: ArcGIS Enterprise documentation on customizing basemaps
NEW QUESTION # 23
An ArcGIS Pro user receives the following error when trying to publish to ArcGIS Enterprise:
"Unable to publish to ArcGIS Server, error 001369: failed to create service" The ArcGIS Server logs reveal:
* Failed to create service
* Internal server error
* Unable to instantiate class for XML schema type
* Invalid XML registry file
* 390 ArcSOC processes running
* Server uses only half of available RAM
  • A. Increase the non-interactive desktop heap size
  • B. Use more dedicated instances instead of shared
  • C. Scale up the ArcGIS Server machine resources
This issue is consistent with desktop heap exhaustion, especially when a high number of ArcSOC processes (e.g., 390) are running on Windows. Desktop heap is a limited memory resource used for GUI and system object management. When it runs out, services can fail to start and produce XML-related errors.
Increasing the non-interactive desktop heap size in the Windows registry resolves this.
From Esri documentation:
"If the Windows desktop heap size is too low, ArcGIS Server may be unable to create new processes (ArcSOC), causing service failures and related internal server errors."
* Option B is a generic fix and won't address the specific heap exhaustion issue.
* Option C doesn't help if the root issue is OS-level heap size limits.
Reference:ArcGIS Enterprise - ArcSOC process limits and Windows desktop heap size
NEW QUESTION # 24
The Enterprise Administration Professional 2201 (EAEP2201) certification has become a basic requirement to advance rapidly in the information technology sector. Since Esri EAEP2201 actual dumps are vital to prepare quickly for the examination. Therefore, you will need them if you desire to ace the Enterprise Administration Professional 2201 (EAEP2201) exam in a short time.
EAEP2201 Reliable Test Answers: https://www.dumpsking.com/EAEP2201-testking-dumps.html
Our EAEP2201 exam prep training is considered as one of the most useful and cost-efficient applications for those who are desired to get the EAEP2201 exam certification, In the PDF version, the Enterprise Administration Professional 2201 (EAEP2201) exam questions are printable and portable, EAEP2201 exam preparation product is the best product that leads you to get 100% result, You will get the EAEP2201 training materials which have the highest quality.
As you read this book, you'll master the thought processes necessary EAEP2201 for effective programming and learn how to generalize narrowly conceived algorithms to widen their usefulness without losing efficiency.
Free PDF Quiz Esri - EAEP2201 - Marvelous Enterprise Administration Professional 2201 New Study MaterialsExcluding System Files, Our EAEP2201 Exam Prep training is considered as one of the most useful and cost-efficient applications for those who are desired to get the EAEP2201 exam certification.
In the PDF version, the Enterprise Administration Professional 2201 (EAEP2201) exam questions are printable and portable, EAEP2201 exam preparation product is the best product that leads you to get 100% result.
You will get the EAEP2201 training materials which have the highest quality, Besides, you can enjoy free updates for one year as long as you buy our exam dumps.
P.S. Free 2026 Esri EAEP2201 dumps are available on Google Drive shared by DumpsKing: https://drive.google.com/open?id=1HBi6JgkyRJNs_C3ngREBVN6Z51Rn9Qqn
Posted at 1/11/2026 23:15:33        Only Author  2#
This is top-tier content, I’m liking it immediately. I’m sharing the New CSSBB exam study guide questions that made my promotion and raise possible—get them for free!
Posted at 1/15/2026 10:27:45        Only Author  3#
Such great content, no hesitation at all in liking it. It’s nearly time for my Latest AP-208 test format exam – wish me all the best!
Posted at 1/27/2026 11:14:17        Only Author  4#
I’m truly grateful for your article, it left an indelible mark. Unlock your career growth with free XSIAM-Engineer Passing Score materials—promotion and salary increase!
