CEM Certification Sample Questions & Test CEM Centres
Posted at 1/10/2026 02:35:13      View:106 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that ExamDiscuss CEM dumps now are free: https://drive.google.com/open?id=1IDBKHIVkVYaI-RonwP9BAO4wNCh11HNQ
Every detail of our CEM exam guide is going through professional evaluation and test. Other workers are also dedicated to their jobs. Even the proofreading works of the CEM study materials are complex and difficult. They still attentively accomplish their tasks. Please have a try and give us an opportunity. Our CEM Preparation quide will totally amaze you and bring you good luck. And it deserves you to have a try!
If you free download the demos of the CEM exam questions, I believe you have a deeper understanding of our products, and we must also trust our CEM learning quiz. Our products can provide you with the high efficiency and high quality you need. Selecting our study materials is your rightful assistant with internationally recognized CEM Certification. What are you waiting for? Quickly use our CEM study materials.
Passing CEM Exam Prep Materials - CEM Valid Braindumps - ExamDiscussWe have free demo of our CEM exam questions offering the latest catalogue and brief contents for your information on the website, if you do not have thorough understanding of our CEM study materials. Many exam candidates build long-term relation with our company on the basis of our high quality CEM Guide engine. And our CEM training braindumps have became their best assistant on the way to pass the exam.
AEE Certified Energy Manager (CEM) Sample Questions (Q21-Q26):NEW QUESTION # 21
When should commissioning be included in the design and construction of a facility?
  • A. When the occupancy permit is accepted
  • B. When construction is finalized
  • C. When the planning process begins
  • D. When installation of the energy systems begins
  • E. When the design is finalized
NEW QUESTION # 22
Air is heated from 10°C (dry bulb temperature) and 80% relative humidity to 32°C (dry bulb temperature).
What is the new relative humidity?
  • A. 20%
  • B. 60%
  • C. 40%
  • D. 80%
  • E. 30%
NEW QUESTION # 23
Electricity costs SO. 10 per kWh. if an electric water heater has an efficiency of 95*6. what is the equivalent price of natural gas per Gigajoule for a natural gas water heater? The natural gas water heater has an efficiency of 95*t based on lower-heating value.
[Natural gas has an energy content of 36.400 K|/m3 (higher-heating value) and 32-760 K/m3 (lower-heating value).] SELECT THE CORRECT ANSWER
  • A. $21 / GJ
  • B. $25 / GJ
  • C. $15/GJ
  • D. $33 / GJ
To determine the equivalent price of natural gas per gigajoule (GJ) for a natural gas water heater, we compare the cost of electricity and natural gas on an energy-equivalent basis.
Step 1: Convert Electricity Cost to Cost per GJ
* Electricity cost: $0.10/kWh
* 1 GJ = 277.8 kWh
NEW QUESTION # 24
The set point for the chiller supply water temperature is varied as a function of the thermal demand for space cooling. What do you call this control strategy?
  • A. Condenser-water temperature reset
  • B. Chilled-water temperature reset
  • C. Reheat coil reset
  • D. Night setback
NEW QUESTION # 25
A 50-Hz alternating current (AC) induction motor has 3 pole pairs (6 poles). What is the synchronous speed of the motor?
  • A. 1,000 rpm
  • B. 750 rpm
  • C. 1,500 rpm
  • D. 600 rpm
NEW QUESTION # 26
As the constant increasing of difficulty index of the CEM training materials, passing rate is very important when you choose the study materials. Our study materials can guarantee you to pass the CEM exam for the first time. After all, all of our questions are the same with the real exam questions. It will cost too much time if you still learn by yourself and memorize the boring knowledge of your reference books, you should purchase our CEM practice quiz to help you pass the exam soon.
Test CEM Centres: https://www.examdiscuss.com/AEE/exam/CEM/
At the same time, the contents of the CEM updated pdf is compiled by our professional experts, AEE CEM Certification Sample Questions Finally, our company and customer both benefit from each other, AEE CEM Certification Sample Questions We trust No Help No Pay, The 99% pass rate of CEM latest vce dumps can ensure you get high scores in the actual test, Our exam dumps can not only help you reduce your pressure from CEM exam preparation, but also eliminate your worry about money waste.
Starting `nano` and Dabbling with It, If you're working on a CEM project that has more of a script convention, naming media clips using scenes, takes, and camera angles might make sense.
At the same time, the contents of the CEM updated pdf is compiled by our professional experts, Finally, our company and customer both benefit from each other.
Pass Guaranteed 2026 AEE Pass-Sure CEM Certification Sample QuestionsWe trust No Help No Pay, The 99% pass rate of CEM latest vce dumps can ensure you get high scores in the actual test, Our exam dumps can not only help you reduce your pressure from CEM exam preparation, but also eliminate your worry about money waste.
DOWNLOAD the newest ExamDiscuss CEM PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1IDBKHIVkVYaI-RonwP9BAO4wNCh11HNQ
