[General] Valid JN0-336 Test Notes - JN0-336 Practice Questions
80
General Valid JN0-336 Test Notes - JN0-336 Practice Questions
Posted at 1/10/2026 11:49:23      View151 | Replies2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Itcertkey JN0-336 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Pqr_YOarLQP2wjJDN3wdxkhXC-h5B5j8
You can acquire a sense of the JN0-336 software by downloading a free trial version before deciding whether to buy it. This Juniper JN0-336 practice exam software lets you identify your strengths and shortcomings, allowing you to concentrate on those aspects of your Security, Specialist (JNCIS-SEC) (JN0-336) test preparation that could use some work.
Itcertkey has designed JN0-336 pdf dumps format that is easy to use. Anyone can download Juniper JN0-336 pdf questions file and use it from any location or at any time. Juniper PDF Questions files can be used on laptops, tablets, and smartphones. Moreover, you will get actual Juniper JN0-336 Exam Questions in this Juniper JN0-336 pdf dumps file.
JN0-336 Practice Questions | Reliable JN0-336 Exam PracticeBecause our Juniper JN0-336 practice test is a web-based mock test, there is no need for software installation as it works with all of the popular web browsers, including Internet Explorer, MS Edge, Firefox, Chrome, Opera, and Safari. Your preparation for the JN0-336 Certification Exam will go more smoothly because our Juniper JN0-336 online practice exam precisely replicates the environment of the actual exam.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q18-Q23):NEW QUESTION # 18
You have deployed an SRX300 Series device and determined that files have stopped being scanned.
In this scenario, what is a reason for this problem?
  • A. You have exceeded the maximum files submission for your SRX platform size.
  • B. The infected host communicated with a command-and-control server, but it did not download malware.
  • C. The software license is a free model and only scans executable type files.
  • D. The file is too small to have a virus.
You have exceeded the maximum files submission for your SRX platform size: This statement is correct because file scanning on SRX300 Series device has a limit on the number of files that can be submitted per minute based on the platform size3. For example, SRX320 has a limit of 10 files per minute3.
NEW QUESTION # 19
Exhibit
Referring to the exhibit, which two statements describe the type of proxy used? (Choose two.)
  • A. reverse proxy
  • B. forward proxy
  • C. client protection proxy
  • D. server protection proxy
In the exhibit, the SRX Firewall could be acting as a forward proxy, managing outbound internet requests from internal users or clients within a private network to the internet. Forward proxies are commonly used to control and monitor outbound traffic, provide content caching to improve load times, and enforce company policies.
The scenario can also imply a reverse proxy setup where the SRX Firewall might be configured to direct incoming requests from the internet to the web application. Reverse proxies are used to balance load, enhance security, manage SSL encryption, and provide additional caching functionalities for inbound traffic to servers.
NEW QUESTION # 20
Click the Exhibit button.
You are asked to create a security policy that will automatically add infected hosts to the infected hosts feed and block further communication through the SRX Series device.
What needs to be added to this configuration to complete this task?
  • A. Add a match rule to the security policy with an appropriate threat level.
  • B. Add an action to the permit portion of the security policy.
  • C. Add a security intelligence policy to the permit portion of the security policy.
  • D. Add logging to the permit portion of the security policy.
To create a security policy that will automatically add infected hosts to the infected hosts feed and block further communication through the SRX Series device, you need to add a security intelligence policy to the permit portion of the security policy. A security intelligence policy is a policy that allows you to block or monitor traffic from malicious sources based on threat intelligence feeds from Juniper ATP Cloud or other providers. One of the feeds that you can use is the Infected-Hosts feed, which contains IP addresses of hosts that are infected with malware and communicate with command-and-control servers.
You can create a profile and a rule for the Infected-Hosts feed and specify the threat level and the action to take for the infected hosts. Then, you can link the security intelligence policy with the firewall policy and apply it to the traffic that you want to protect. Reference: = Security Intelligence Overview, Configuring Security Intelligence Policy, Configure the Security Intelligence Policy on the SRX Series Device
NEW QUESTION # 21
Exhibit
Referring to the SRX Series flow module diagram shown in the exhibit, where is application security processed?
  • A. Security Policy
  • B. Forwarding Lookup
  • C. Services ALGs
  • D. Screens
NEW QUESTION # 22
You are troubleshooting unexpected issues on your JIMS server due to out of order event log timestamps.
Which action should you take to solve this issue?
  • A. Enable time synchronization on the JIMS server.
  • B. Enable time synchronization on the domain controllers.
  • C. Enable time synchronization on the client devices.
  • D. Enable time synchronization on the SRX Series devices.
To solve the issue of out of order event log timestamps on your JIMS server, you should enable time synchronization on the domain controllers. JIMS (Juniper Identity Management Service) is a Windows service that collects user, device, and group information from Active Directory domains or syslog sources and provides it to SRX Series devices and CSO for identity-based security policies. JIMS relies on the timestamps of the event logs generated by the domain controllers to track user logins, logouts, and IP address changes. If the domain controllers have different or inaccurate clocks, the event logs may have out of order or incorrect timestamps, which can cause JIMS to miss or misinterpret some events and affect its accuracy and performance. Therefore, you should ensure that all the domain controllers in your network are synchronized with a reliable time source, such as an NTP server or a Windows Time service. Reference: = Juniper Identity Management Service User Guide, Juniper Identity Management Service Feature Guide, Configure JIMS Collector to Get Microsoft Event Logs, Considerations for timestamps in centralized logging platforms
NEW QUESTION # 23
Maybe you have desired the JN0-336 certification for a long time but don't have time or good methods to study. Maybe you always thought study was too boring for you. Our JN0-336 study materials will change your mind. With our products, you will soon feel the happiness of study. Thanks to our diligent experts, wonderful study tools are invented for you to pass the JN0-336 Exam. You can try the demos first and find that you just can't stop studying if you use our JN0-336 training guide.
JN0-336 Practice Questions: https://www.itcertkey.com/JN0-336_braindumps.html
Juniper Valid JN0-336 Test Notes The irreplaceable products get amazing feedback, The Juniper JN0-336 exam practice test questions have already helped many Juniper JN0-336 exam candidates in their preparation and success, Besides, rather than waiting for the gain of our JN0-336 practice engine, you can download them immediately after paying for it, so just begin your journey toward success now, In short, our JN0-336 exam questions are the most convenient learning tool for diligent people.
Now JN0-336 Security, Specialist (JNCIS-SEC) exam are very popular for IT exam candidates, Review of Basic Security Mechanisms, The irreplaceable products get amazing feedback, The Juniper JN0-336 Exam Practice test questions have already helped many Juniper JN0-336 exam candidates in their preparation and success.
JN0-336 - Trustable Valid Security, Specialist (JNCIS-SEC) Test NotesBesides, rather than waiting for the gain of our JN0-336 practice engine, you can download them immediately after paying for it, so just begin your journey toward success now.
In short, our JN0-336 exam questions are the most convenient learning tool for diligent people, It passed the test of practice, and with the best quality.
BONUS!!! Download part of Itcertkey JN0-336 dumps for free: https://drive.google.com/open?id=1Pqr_YOarLQP2wjJDN3wdxkhXC-h5B5j8
Posted at 1/12/2026 08:57:26        Only Author  2#
The article changed the way I think. Free C-THR86-2505 study plan available for boosting your IT skills. Wishing you success!
Posted at 2/8/2026 14:07:07        Only Author  3#
Im giving this a like without a second thought. Valid practice FCP_FAZ_AD-7.4 exam online offers detailed content free of charge to help you in your learning journey.
