Test DP-300 Practice, DP-300 Latest Exam
90
Posted at 1/10/2026 21:33:47      View154 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New DP-300 dumps are available on Google Drive shared by PDF4Test: https://drive.google.com/open?id=1VWqHebWNqwzdNbF5CgEEbr1MHhnDtOUz
In the PDF version, PDF4Test have included real DP-300 exam questions. All the Selling Administering Relational Databases on Microsoft Azure (DP-300) exam questionnaires are readable via laptops, tablets, and smartphones. Microsoft DP-300 exam questions in this document are printable as well. You can carry this file of Microsoft DP-300 PDF Questions anywhere you want. In the same way, PDF4Test update its Selling Administering Relational Databases on Microsoft Azure (DP-300) exam questions bank in the PDF version so users get the latest material for DP-300 exam preparation.
The Microsoft DP-300: Administering Relational Databases on Microsoft Azure exam is a qualifying test that the individuals must pass to obtain the Microsoft Certified: Azure Database Administrator Associate certification. The intended candidates for this exam are the specialists in data management and database administrators. They manage and implement the operational components of hybrid and Cloud-native data platform solution options that are created on SQL Server and Azure Data Services. These professionals use different tools and methods to carry out their daily business operations. These include the application of knowledge of the use of T-SQL for different purposes, including administrative management.
In addition to demonstrating your knowledge and expertise, passing the DP-300 Exam can also open up new career opportunities and increase your earning potential. With the growing demand for skilled database administrators who can work with Azure-based databases, achieving this certification can help you stand out from the competition and advance your career.
The DP-300 exam consists of various types of questions, including multiple-choice, drag and drop, and scenario-based questions. Candidates are required to demonstrate their ability to apply their knowledge to real-world scenarios and provide solutions that meet the requirements of the organization. DP-300 exam is approximately 150 minutes long, and candidates must achieve a passing score of 700 out of 1000 to earn the certification.
Free PDF Perfect Microsoft - Test DP-300 PracticeWith our professional experts' unremitting efforts on the reform of our Microsoft DP-300 guide materials, we can make sure that you can be focused and well-targeted in the shortest time when you are preparing a test, simplify complex and ambiguous contents. With the assistance of our Microsoft DP-300 Study Guide you will be more distinctive than your fellow workers.
Microsoft Administering Relational Databases on Microsoft Azure Sample Questions (Q100-Q105):NEW QUESTION # 100
You configure a long-term retention policy for an Azure SQL database as shown in the exhibit. (Click the Exhibit tab.)
The first weekly backup occurred on January 4, 2020. The dates for the first 10 weekly backups are:
January 4, 2020
January 11, 2020
January 18, 2020
January 25, 2020
February 1, 2020
February 8, 2020
February 15, 2020
February 22, 2020
February 29, 2020
March 7, 2020
Use the drop-down menus to select the answer choice that completes each statement based on the information presented in the graphic.
NEW QUESTION # 101
You have an Azure Active Directory (Azure AD) tenant named contoso.com that contains a user named user1@contoso.com and an Azure SQL managed instance named SQLMI1.
You need to ensure that user1@contoso.com can create logins in SQLMI1 that map to Azure AD service principals.
https://docs.microsoft.com/en-us ... -configure-tutorial
NEW QUESTION # 102
You configure version control for an Azure Data Factory instance as shown in the following exhibit.
https://docs.microsoft.com/en-us ... tory/source-control
NEW QUESTION # 103
You have an Azure SQL database.
You identify a long running query.
You need to identify which operation in the query is causing the performance issue.
What should you use to display the query execution plan in Microsoft SQL Server Management Studio (SSMS)?
  • A. Client Statistics
  • B. an actual execution plan
  • C. Live Query Statistics
  • D. an estimated execution plan
NEW QUESTION # 104
You have an Azure virtual machine named VM1 on a virtual network named VNet1. Outbound traffic from VM1 to the internet is blocked.
You have an Azure SQL database named SqlDb1 on a logical server named SqlSrv1.
You need to implement connectivity between VM1 and SqlDb1 to meet the following requirements:
- Ensure that all traffic to the public endpoint of SqlSrv1 is blocked.
- Minimize the possibility of VM1 exfiltrating data stored in SqlDb1.
What should you create on VNet1?
  • A. a service endpoint
  • B. a private link
  • C. an ExpressRoute gateway
  • D. a VPN gateway
Azure Private Link enables you to access Azure PaaS Services (for example, Azure Storage and SQL Database) and Azure hosted customer-owned/partner services over a private endpoint in your virtual network.
Traffic between your virtual network and the service travels the Microsoft backbone network.
Exposing your service to the public internet is no longer necessary.
https://docs.microsoft.com/en-us ... ivate-link-overview
NEW QUESTION # 105
It is common in modern society that many people who are more knowledgeable and capable than others finally lost some good opportunities for development because they didnt obtain the DP-300 certification. The prerequisite for obtaining the DP-300 Certification is to pass the exam, but not everyone has the ability to pass it at one time. But our DP-300 exam questions will help you pass the exam by just one go for we have the pass rate high as 98% to 100%.
DP-300 Latest Exam: https://www.pdf4test.com/DP-300-dump-torrent.html
What's more, part of that PDF4Test DP-300 dumps now are free: https://drive.google.com/open?id=1VWqHebWNqwzdNbF5CgEEbr1MHhnDtOUz
Posted at 1/11/2026 02:34:25        Only Author  2#
Im so grateful I read that article. Getting ready for the Valid study guide Information-Technology-Management pdf exam C wish me luck!
Posted at 1/23/2026 04:10:02        Only Author  3#
This article really inspired me, thanks for sharing! Thanks to the Valid exam C_BCSBN_2502 collection materials, I earned a promotion and a pay raise. Now, Im sharing it for free. Wishing you all success in your career paths!
