[General] 100% Pass Quiz 2026 High-quality Fortinet NSE5_FNC_AD_7.6 Online Training
95
【General】 100% Pass Quiz 2026 High-quality Fortinet NSE5_FNC_AD_7.6 Online Training
Posted at 1/10/2026 22:45:27      View:162 | Replies:3        Print      Only Author   [Copy Link] 1#
There are many merits of our product on many aspects and we can guarantee the quality of our NSE5_FNC_AD_7.6 practice engine. Firstly, our experienced expert team compile them elaborately based on the real exam and our NSE5_FNC_AD_7.6 study materials can reflect the popular trend in the industry and the latest change in the theory and the practice. Secondly, both the language and the content of our NSE5_FNC_AD_7.6 Study Materials are simple,easy to be understood and suitable for any learners.
Fortinet NSE5_FNC_AD_7.6 Exam Syllabus Topics:
  • Integration: This domain addresses connecting FortiNAC-F with other systems using Syslog and SNMP traps, managing multiple instances through FortiNAC-F Manager, and integrating Mobile Device Management for extending access control to mobile devices.
  • Deployment and Provisioning: This domain focuses on configuring security automation for automatic event responses, implementing access control policies, setting up high availability for system redundancy, and creating security policies to enforce network security requirements.
  • Concepts and Initial Configuration: This domain covers organizing infrastructure devices within FortiNAC-F and understanding isolation networks for quarantining non-compliant devices. It includes using the configuration wizard for initial system setup and deployment.
  • Network Visibility and Monitoring: This domain covers managing guest and contractor access, utilizing logging options for tracking network events, configuring device profiling for automatic device identification and classification, and troubleshooting network device connection issues.
NSE5_FNC_AD_7.6 Free Test Questions, Frenquent NSE5_FNC_AD_7.6 UpdateWe have 24/7 Service Online Support services, and provide professional staff Remote Assistance. Besides, if you need an invoice of our NSE5_FNC_AD_7.6 practice materials please specify the invoice information and send us an email. And you can download the trial of our NSE5_FNC_AD_7.6 training engine for free before your purchase. This kind of service shows our self-confidence and actual strength about NSE5_FNC_AD_7.6 Study Materials in our company. Besides, our company's website purchase process holds security guarantee, so you needn’t be anxious about download and install our NSE5_FNC_AD_7.6 exam questions.
Fortinet NSE 5 - FortiNAC-F 7.6 Administrator Sample Questions (Q28-Q33):NEW QUESTION # 28
An administrator has created several device profiling rules and evaluated all existing devices in the database. Some of the devices appear in the profiled devices view because they matched a rule, but they remain unknown and the registration column in the profiled devices view shows "No".
What is the most likely cause?
  • A. The device profiling rule has registration set to manual.
  • B. The devices have persistent agents installed, and the point of connection has PA optimization enabled.
  • C. The devices match more than one device profiling rule.
  • D. The confirm device profiling rule option is not enabled.
In FortiNAC-F, Device Profiling Rules are used to automatically identify and categorize devices (such as IP cameras, printers, or IoT devices) based on fingerprints like DHCP fingerprints, OIDs, or MAC prefixes. When a device matches a rule, it appears in the Profiled Devices view.
However, matching a rule does not automatically register the device in the database unless the rule is configured to do so. If the devices appear in the view but remain "Unknown" and show "No" in the registration column, it indicates that the "Confirm" (or "Auto-register") action has not been triggered. In the Device Profiling Rule configuration, there is a setting called "Allow Auto-Approval" or "Confirm". If this is not enabled, the system identifies the device but waits for an administrator to manually approve the match before changing the host status from "Unknown" to "Registered".
This is a common "safety" configuration used during the initial deployment phase to ensure that the profiling rules are accurate before the system begins automatically granting network access based on those matches.
"If a device matches a rule but is not registered, check the rule configuration. The Confirm option (within the Method or Rule settings) determines if the system automatically registers the device upon a match. If Confirm is not enabled, the device will remain in the 'Profiled' state with a registration status of 'No' until an administrator manually promotes the device." - FortiNAC-F Administration Guide: Device Profiling Rules.
NEW QUESTION # 29
If a host is connected to a port in the Building 1 First Floor Ports group, what must also be true to match this user/host profile?
  • A. The host must have a role value of contractor or an installed persistent agent and a security access value of contractor, and be connected between 6 AM and 5 PM.
  • B. The host must have a role value of contractor, an installed persistent agent or a security access value of contractor, and be connected between 6 AM and 5 PM.
  • C. The host must have a role value of contractor or an installed persistent agent or a security access value of contractor, and be connected between 6 AM and 5 PM.
  • D. The host must have a role value of contractor or an installed persistent agent, a security access value of contractor, and be connected between 9 AM and 5 PM.
The User/Host Profile in FortiNAC-F is the fundamental logic engine used to categorize endpoints for policy assignment. As seen in the exhibit, the configuration uses a combination of Boolean logic operators (OR and AND) to define the "Who/What" attributes.
According to the FortiNAC-F Administrator Guide, attributes grouped together within the same bracket or connected by an OR operator require only one of those conditions to be met. In the exhibit, the first two attributes are "Host Role = Contractor" OR "Host Persistent Agent = Yes". This forms a single logical block. This block is then joined to the third attribute ("Host Security Access Value = Contractor") by an AND operator. Consequently, a host must satisfy at least one of the first two conditions AND satisfy the third condition to match the "Who/What" section.
Furthermore, the profile includes Location and When (time) constraints. The exhibit shows the location is restricted to the "Building 1 First Floor Ports" group. The "When" schedule is explicitly set to Mon-Fri 6:00 AM - 5:00 PM. For a profile to match, all enabled sections (Who/What, Locations, and When) must be satisfied simultaneously. Therefore, the host must meet the conditional contractor/agent criteria, possess the specific security access value, and connect during the defined 6 AM to 5 PM window.
"User/Host Profiles use a combination of attributes to identify a match. Attributes joined by OR require any one to be true, while attributes joined by AND must all be true. If a Schedule (When) is applied, the host must also connect within the specified timeframe for the profile to be considered a match. All criteria in the Who/What, Where, and When sections are cumulative." - FortiNAC-F Administration Guide: User/Host Profile Configuration.
NEW QUESTION # 30
A user was attempting to register their host through the registration captive portal. After successfully registering, the host remained in the registration VLAN. Which two conditions would cause this behavior? (Choose two.)
  • A. There is no agent installed on the host.
  • B. The port default VLAN is the same as the Registration VLAN.
  • C. There is another unregistered host on the same port
  • D. The wrong agent s installed.
The process of moving a host from a Registration VLAN to a Production VLAN (Access VLAN) is a fundamental part of the FortiNAC-F "VLAN steering" workflow. When a host successfully registers via the captive portal, FortiNAC-F evaluates its Network Access Policies to determine the correct VLAN. If the host remains stuck in the Registration VLAN despite a successful registration, it is typically due to port-level restrictions or the presence of other unregistered devices.
The two most common reasons for this behavior as per the documentation are:
The port default VLAN is the same as the Registration VLAN: If the "Default VLAN" field in the switch port's model configuration is set to the same ID as the Registration VLAN, the port will not change state because FortiNAC-F believes it is already in its "normal" or "forced" state.
There is another unregistered host on the same port: FortiNAC-F maintains the security posture of the physical port. If multiple hosts are connected to a single port (e.g., via a hub or unmanaged switch) and at least one host remains "Rogue" (unregistered), FortiNAC-F will generally keep the entire port in the isolation/registration VLAN to prevent the unregistered host from gaining unauthorized access to the production network.
Issues with agents (A, B) typically prevent a host from completing compliance or registration but do not usually result in a "stuck" status after registration has already been marked as successful in the system.
"If a port is identified as having Multiple Hosts, and those hosts require different levels of access, FortiNAC remains in the most restrictive state (Registration or Isolation) until all hosts on that port are authorized... Additionally, verify the Default VLAN setting for the port; if the Default VLAN and Registration VLAN match, the system will not trigger a VLAN change upon registration." - FortiNAC-F Administration Guide: Troubleshooting Host Management.
NEW QUESTION # 31
Which two requirements must be met to set up an N+1 HA cluster? (Choose two.)
  • A. At least two FortiNAC-F devices designated as primary
  • B. A FortiNAC-F manager
  • C. A FortiNAC-F device designated as a secondary
  • D. A dedicated VLAN for primary and secondary synchronization
The N+1 High Availability (HA) architecture was introduced in FortiNAC-F version 7.6 to provide a more scalable and flexible redundancy model compared to the traditional 1+1 active/passive setup. In an N+1 configuration, a single secondary (standby) appliance can provide coverage for multiple primary (active) Control and Application (CA) appliances.
To set up an N+1 HA cluster, there are two fundamental structural requirements:
A FortiNAC-F Manager (FortiNAC-M): Unlike standard 1+1 HA, which can be configured directly between two CAs, N+1 management is centralized. The FortiNAC-M acts as the orchestrator that manages the failover groups, monitors the health of the primaries, and coordinates the promotion of the secondary server if a primary fails.
A FortiNAC-F device designated as a Secondary: The cluster must have one appliance explicitly configured with the Secondary failover role. This device remains in a standby state, receiving database replications from all N primaries in its group until it is called upon to take over the functions of a failed unit.
While a cluster can support multiple primaries (D), it does not strictly require "at least two" to function as an N+1 group; it simply requires N primaries (where N ≥ 1). Additionally, N+1 is typically a Layer 3 managed solution via the Manager, meaning it does not mandate a "dedicated VLAN" for synchronization like some Layer 2 HA deployments.
"In FortiNAC-F 7.6, FortiNAC-M functions as a manager to manage the N+1 Failover Groups... enabling N+M high availability for CAs. To create an N+1 Failover group, you should add the secondary CA to the FortiNAC-M first, then add the primary CAs. The secondary CA is designed to take over the functionality of any single failed primary component." - FortiNAC-F 7.6.0 N+1 Failover Reference Manual.
NEW QUESTION # 32
When creating a user or host profile, which three criteria can you apply? (Choose three.)
  • A. Location
  • B. Host or user group memberships
  • C. An applied access policy
  • D. Host or user attributes
  • E. Adapter current VLAN
Answer: A,B,D
The User/Host Profile is the primary mechanism in FortiNAC-F for identifying and categorizing endpoints to determine their level of network access. According to the FortiNAC-F Administration Guide, a profile is built using a combination of criteria that define "Who" is connecting, "What" device they are using, and "Where" they are located on the network.
The three main categories of criteria available in the configuration are:
Host or User Attributes (B): This includes specific details such as the host's operating system, the user's role (e.g., Employee, Contractor), or custom attributes assigned to the record.
Host or User Group Memberships (A): Profiles can be configured to match endpoints that are members of specific internal FortiNAC groups or synchronized directory groups (like LDAP or Active Directory groups). This allows for broad policy application based on organizational structure.
Location (E): The "Where" component allows administrators to restrict a profile match to specific physical or logical areas of the network, such as a particular switch, a group of ports, or a specific SSID.
Criteria like an "applied access policy" (D) are the outcome of a profile match rather than a criterion used to define the profile itself. Similarly, the "Adapter current VLAN" (C) is a dynamic state that changes based on enforcement and is not a standard static identifier used for profile matching.
"User/Host Profiles are used to identify the hosts and users to which a policy will apply. Profiles are created by selecting various criteria in the Who/What (Attributes and Groups) and Where (Locations) sections. Attributes can include Host Role, User Role, and OS. Group memberships allow matching based on internal or directory-based groups. Location criteria allow for filtering based on the device or port where the host is connected." - FortiNAC-F Administration Guide: User/Host Profile Configuration.
NEW QUESTION # 33
At PassSureExam, we are aware that every applicant of the Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) examination is different. We know that everyone has a distinct learning style, situations, and set of goals, therefore we offer Fortinet NSE5_FNC_AD_7.6 updated exam preparation material in three easy-to-use formats to accommodate every exam applicant's needs. This article will go over the three formats of the Fortinet NSE 5 - FortiNAC-F 7.6 Administrator (NSE5_FNC_AD_7.6) practice material that we offer.
NSE5_FNC_AD_7.6 Free Test Questions: https://www.passsureexam.com/NSE5_FNC_AD_7.6-pass4sure-exam-dumps.html
Posted at 1/13/2026 03:33:48        Only Author  2#
I can’t thank you enough for your article, it really resonated with me. Free Certificate CWDP-305 exam test materials are available! Good luck!
Posted at 1/13/2026 22:58:02        Only Author  3#
Instant like, no questions asked. Sending positive vibes for the Practice PMI-CPMAI exam online exam – wish me luck!
Posted at 2/5/2026 19:14:31        Only Author  4#
I don’t even need to think—this content deserves a like. The KCNA most reliable questions resources are outstanding, and they come with no cost.
