最新1Z0-1114-25題庫 - 1Z0-1114-25證照指南
Posted at 1/11/2026 03:41:01
Oracle的1Z0-1114-25考試認證,Fast2test是當前最新Oracle的1Z0-1114-25考試認證和考題準備問題提供認證的候選人中的佼佼者,我們資源不斷被修訂和更新,具有緊密的相關性和緊密性,今天你準備Oracle的1Z0-1114-25認證,你將要選擇你要開始的訓練,而且要通過你下一次的考題,由於我們大部分考題是每月更新一次,你將得到最好的資源與市場的新鮮品質和可靠性的保證。
Oracle 1Z0-1114-25 考試大綱:| 主題 | 簡介 | | 主題 1 | - Configuring Oracle Fusion Cloud Extensions with Visual Builder Studio: This section evaluates the expertise of Fusion Application Developers and Cloud Extension Specialists in using Oracle Visual Builder Studio (VBS) as a development platform for creating and modifying Oracle SaaS applications. It covers extending existing SaaS pages, creating new Redwood pages or apps for SaaS data, and building mashup applications that integrate SaaS and external data sources.
| | 主題 2 | - Designing and Developing Redwood Applications: This section measures the skills of Redwood Application Developers and Product Designers in designing and developing applications using Redwood patterns, templates, and components. It focuses on utilizing Redwood page templates, exploring specifications through the Redwood Reference Application, and building applications that align with Oracle's Redwood design system.
| | 主題 3 | - Developing Fusion Apps with Visual Builder Studio: This section tests the knowledge of Fusion App Developers and Development Operations Engineers in leveraging Visual Builder Studio features. It includes configuring service connections, managing code with Git repositories, handling branches and merge requests, and managing builds, pipelines, and deployments to streamline application development workflows.
| | 主題 4 | - The Redwood Experience: This section of the exam measures the skills of UX Designers and Application Developers in understanding the need for a modern applications platform. It explains the building blocks of Oracle's Redwood design system, focusing on its role in delivering a consistent and intuitive user experience across applications.
最新1Z0-1114-25題庫:Oracle Redwood Application 2025 Developer Associate可靠的認證資源對於1Z0-1114-25認證考試,你是怎麼想的呢?作為非常有人氣的Oracle認證考試之一,這個考試也是非常重要的。但是,當你為了更好地準備考試而尋找參考資料的時候,你會發現找到一本非常優秀的參考書是很難的。那麼,應該怎麼辦才好呢?沒關係。Fast2test很好地體察到了你們的願望,並且為了滿足廣大考生的要求,向你們提供最好的考試考古題。
最新的 Oracle Cloud Infrastructure 1Z0-1114-25 免費考試真題 (Q10-Q15):問題 #10
How does Oracle Fusion Cloud Extensions contribute to business agility?
- A. By enforcing rigid and unchangeable processes
- B. By allowing businesses to quickly adapt and extend their cloud applications
- C. By slowing down business processes
- D. By increasing the complexity of existing applications
答案:B
解題說明:
Full Detailed in Depth Explanatio n:
Fusion Cloud Extensions, built with VBS, enable rapid customization of applications (C), enhancing agility. They don't slow processes (A), add complexity (B), or enforce rigidity (D).
問題 #11
In which three cases would you need a Visual Builder service instance to deploy your app to? (Choose three.)
- A. For gaining access to Oracle Fusion Apps REST services
- B. For enabling the app to be integrated into the Fusion Cloud Apps menu
- C. When there is an application that is accessible from a vanity URL (custom domain)
- D. When the app needs to be accessed by users who do not have Fusion Apps access
- E. For gaining access to an external database through a REST service requiring basic auth
答案:C,D,E
解題說明:
A Visual Builder (VB) service instance is a stand-alone runtime environment separate from Fusion Apps. Option A is correct because external users without Fusion access require a VB instance to host the app. Option B is valid as VB instances support REST integrations with external databases using basic authentication. Option C is accurate because vanity URLs are supported by VB instances for custom domains. Option D is incorrect because Fusion Apps REST services are typically accessed via AppUI extensions within Fusion, not a separate VB instance. Option E is wrong as integration into Fusion menus relies on AppUI extensions, not a stand-alone VB instance.
問題 #12
You are planning to use the Dashboard Landing Page template for Key Performance Indicators (KPIs), and a dashboard grid with information visualizations that highlight and explain business performance. Which is a required property of oj-sp-dashboard-landing-page?
- A. Page Title
- B. Primary Action
- C. Page Subtitle
- D. In Flow Back
答案:A
解題說明:
The oj-sp-dashboard-landing-page is a Redwood component used to create dashboard-style pages in Oracle applications. According to the Redwood Pattern Book and component documentation, the Page Title (Option A) is a required property to define the dashboard's identity and purpose, ensuring clarity for users. Options B (Page Subtitle), C (In Flow Back), and D (Primary Action) are optional: subtitles enhance context but aren't mandatory, "In Flow Back" relates to navigation flows (not required), and primary actions are configurable but not essential for the component's basic functionality.
問題 #13
You are designing the UI to display information about a product and are asked to use the card layout, such that:
* The card layout summarizes the available information about a product in a visually compact manner.
* The card layout is used as an entry point from where users can access additional details.
Which card layout is suitable for the above requirements?
- A. Object Card
- B. Image Card
- C. Scoreboard
- D. Mini Card
答案:A
解題說明:
Redwood offers various card layouts, each with specific use cases. The Object Card (Option A) is designed to summarize key information about an entity (e.g., a product) in a compact, visually appealing way while serving as an entry point to detailed views-perfectly matching the requirements. Mini Card (B) is too minimal for summarization, focusing on quick glances. Image Card (C) prioritizes visuals over data summary, and Scoreboard (D) is for metrics/KPIs, not product details.
問題 #14
Which two tools allow UI/UX Designers to reuse Redwood's shared libraries and templates for projects and products?
- A. PowerPoint
- B. Adobe XD
- C. Figma
- D. Marvel
- E. UXPin
答案:B,C
解題說明:
Redwood supports Adobe XD (B) and Figma (C) with shared libraries for design consistency. UXPin (A), Marvel (D), and PowerPoint (E) aren't integrated.
問題 #15
獲得 Oracle Oracle 認證對於考生而言有很多好處,相對于考生尋找工作而言,一張 Oracle 的 1Z0-1114-25 認證會讓你倍受青睞的企業信任狀,帶來更好的工作機會。要想通過此認證學習過程中要注意方法,最重要的是需要毅力,如果有相關的工作經驗,學起來可能輕鬆一點,否則的話,你需要付出更多的勞動。Oracle 的 1Z0-1114-25 證照作為全球IT領域專家 Oracle 證照之一,是許多大中IT企業選擇人才標準的必備條件。
1Z0-1114-25證照指南: https://tw.fast2test.com/1Z0-1114-25-premium-file.html
- 1Z0-1114-25權威考題 🧅 1Z0-1114-25最新試題 👱 1Z0-1114-25認證考試 🦐 立即打開《 [url]www.pdfexamdumps.com 》並搜索{ 1Z0-1114-25 }以獲取免費下載1Z0-1114-25證照信息[/url]
- 最新的1Z0-1114-25認證考試資料 😁 在⮆ [url]www.newdumpspdf.com ⮄上搜索⏩ 1Z0-1114-25 ⏪並獲取免費下載1Z0-1114-25考古题推薦[/url]
- 一流的最新1Z0-1114-25題庫 |第一次嘗試輕鬆學習並通過考試&頂級的Oracle Oracle Redwood Application 2025 Developer Associate 🎎 打開網站⮆ [url]www.newdumpspdf.com ⮄搜索✔ 1Z0-1114-25 ️✔️免費下載1Z0-1114-25考試備考經驗[/url]
- 1Z0-1114-25考古题推薦 📫 1Z0-1114-25測試引擎 🤪 1Z0-1114-25測試引擎 🚦 在( [url]www.newdumpspdf.com )搜索最新的( 1Z0-1114-25 )題庫1Z0-1114-25證照信息[/url]
- 高效的最新1Z0-1114-25題庫和認證考試的領導者材料和權威的1Z0-1114-25證照指南 😅 到➡ [url]www.pdfexamdumps.com ️⬅️搜尋[ 1Z0-1114-25 ]以獲取免費下載考試資料1Z0-1114-25考古題更新[/url]
- 1Z0-1114-25權威考題 🦏 1Z0-1114-25最新考古題 💱 1Z0-1114-25通過考試 ☁ 免費下載▷ 1Z0-1114-25 ◁只需在“ [url]www.newdumpspdf.com ”上搜索1Z0-1114-25權威考題[/url]
- 最新的1Z0-1114-25認證考試資料 📷 立即到▶ [url]www.pdfexamdumps.com ◀上搜索▶ 1Z0-1114-25 ◀以獲取免費下載新版1Z0-1114-25考古題[/url]
- 熱門的最新1Z0-1114-25題庫&認證考試的領導者材料和快速下載1Z0-1114-25證照指南 🏝 ➡ [url]www.newdumpspdf.com ️⬅️是獲取{ 1Z0-1114-25 }免費下載的最佳網站免費下載1Z0-1114-25考題[/url]
- 有用的最新1Z0-1114-25題庫和資格考試中的主要供應商&真實的Oracle Oracle Redwood Application 2025 Developer Associate 🐘 ⏩ [url]www.vcesoft.com ⏪最新「 1Z0-1114-25 」問題集合最新1Z0-1114-25考證[/url]
- 最新1Z0-1114-25考古題 🧍 1Z0-1114-25認證考試 🤛 新版1Z0-1114-25題庫 🥠 複製網址▶ [url]www.newdumpspdf.com ◀打開並搜索「 1Z0-1114-25 」免費下載最新1Z0-1114-25考古題[/url]
- Oracle 1Z0-1114-25認證考試學習指南 🕳 在➽ [url]www.vcesoft.com 🢪網站上免費搜索▶ 1Z0-1114-25 ◀題庫1Z0-1114-25考古题推薦[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dl.instructure.com, www.meilichina.com, bbs.t-firefly.com, estar.jp, pianowithknight.com, iqedition.com, yu856.com, Disposable vapes
