[General] 1z0-076 New Dumps & Reliable 1z0-076 Real Exam
99
【General】 1z0-076 New Dumps & Reliable 1z0-076 Real Exam
Posted at 1/11/2026 14:58:17      View:164 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TrainingQuiz 1z0-076 dumps from Cloud Storage: https://drive.google.com/open?id=1RCATft2Zm2KKWFDKRNpw0NX1m5SFWx-E
It is browser-based; therefore no need to install it, and you can start practicing for the Oracle 1z0-076 exam by creating the Oracle Database 19c: Data Guard Administration (1z0-076) practice test. You don't need to install any separate software or plugin to use it on your system to practice for your actual Oracle Database 19c: Data Guard Administration (1z0-076) exam. TrainingQuiz 1z0-076 web-based practice software is supported by all well-known browsers like Chrome, Firefox, Opera, Internet Explorer, etc.
Oracle 1z0-076 Exam Syllabus Topics:
  • Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
  • Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
  • Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
Topic 5
  • Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
Topic 6
  • Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
Topic 7
  • Oracle Data Guard Basics: This topic covers the essential architecture and concepts of Oracle Data Guard. It includes sub-topics such as the physical and logical standby database comparison, benefits of Data Guard, and its integration with multi-tenant databases.
Topic 8
  • Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
Topic 9
  • Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
Topic 11
  • Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
Topic 12
  • Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
Reliable 1z0-076 Real Exam & 1z0-076 Exam PracticeI can assure you that we will provide considerate on line after sale service for you in twenty four hours a day, seven days a week. Therefore, after buying our 1z0-076 study guide, if you have any questions about our 1z0-076 study materials, please just feel free to contact with our online after sale service staffs. We are pleased to give you the best and the most professinal suggestions on every aspect on the 1z0-076 learning questions. You can contact and ask your question now!
Oracle Database 19c: Data Guard Administration Sample Questions (Q103-Q108):NEW QUESTION # 103
Which TWO statements are true about configuring Oracle Net Service in a Data Guard environment?
  • A. Install the oracle-database-preinstall-19c package to set the kernel parameters for Oracle Net based on the Data Guard best practice guidelines.
  • B. Enterprise Manager does not require static service registration to restart instances during the course of broker operations.
  • C. Installing the oracle-database-preinstall-19c package is NOT sufficient to set up operating system kernel parameters for Oracle Net.
  • D. A static service must be registered with the local listener to enable DGMGRL to restart instances during the course of broker operations.
  • E. It is necessary to use the failover clause for an address_list with multiple address lists in the tnsnames.ora file.
A static service must be registered with the local listener to enable DGMGRL to restart instances during the course of broker operations (A): For DGMGRL (Data Guard Manager Command-Line Interface) to perform instance management operations, such as restarting instances, a static service registration in the listener is required. This allows the broker to connect to the database instance even when the instance is not fully up and the dynamic service registration is not available.
Installing the oracle-database-preinstall-19c package is NOT sufficient to set up operating system kernel parameters for Oracle Net (C): While the oracle-database-preinstall-19c package automates the setting of several kernel parameters to meet the preinstallation requirements for Oracle Database, it does not specifically tailor all settings for Oracle Net in a Data Guard configuration. Additional manual configuration may be required to optimize Oracle Net services for Data Guard operations.
Oracle Data Guard Broker documentation
Oracle Net Services Administrator's Guide
NEW QUESTION # 104
Which THREE are true about using flashback database in a Data Guard environment?
  • A. You can use it when real-time apply is enabled in case the physical standby suffers from logical corruption.
  • B. It may not be used to flash back a primary database after a failover to a physical standby.
  • C. You can use it when real-time apply is enabled in case the phylt may not be used to flash back a primary database after a failover to a logical standby.
  • D. When a flashback database operation is performed on a primary database, a physical standby database is also flashed back automatically.
  • E. It may be used to flash back a physical standby that receives redo from a far sync instance.
  • F. When a flashback database operation is performed on a primary database, a logical standby database is also flashed back automatically.
Answer: A,B,E
Flashback Database is a feature that allows reverting a database to a previous point in time, which is extremely useful in various Data Guard configurations:
It may be used to flash back a physical standby that receives redo from a far sync instance (C): Flashback Database can be used on a physical standby database to revert it to a past point in time, even when it is receiving redo data from a far sync instance. This can be particularly useful to recover from logical corruptions or unwanted changes.
You can use it when real-time apply is enabled in case the physical standby suffers from logical corruption (D): Even when real-time apply is enabled, which allows redo data to be applied to the standby database as soon as it is received, Flashback Database can be used to revert the physical standby database to a point in time before the logical corruption occurred.
It may not be used to flash back a primary database after a failover to a physical standby (E): After a failover has occurred from a primary to a physical standby database, making the standby the new primary, Flashback Database cannot be used to revert the old primary database to a state before the failover because the failover operation makes irreversible changes to the database role and configuration.
Oracle Database Backup and Recovery User's Guide
Oracle Data Guard Concepts and Administration
NEW QUESTION # 105
You are monitoring your Data Guard broker configuration and issue this set of DGMGRL commands:
DGMGRL> SHOW CONFIGURATION;
Configuration - DRSolution
Protection Mode: MaxPerformance
Databases:
Close_by - Primary database
FS_inst - Far Sync
Far_away - Physical standby database
Fast-Start Failover: DISABLED
Configuration Status:
SUCCESS
What is true concerning this configuration?
  • A. The Close_by primary database forwards redo to the Far_away physical standby directly and also sends redo to the FS_inst Far Sync instance.
  • B. The FS_inst Far Sync instance forwards redo to the Far_away physical standby only if the Close_by primary database is not able to do so.
  • C. The Close_by primary database instance forwards redo to the FS_inst Far Sync instance, which forwards the redo in turn to the Far_away physical standby database instance.
  • D. The Far Sync instance will not forward redo to the Far_away physical standby because Fast-Start Failover is disabled.
  • E. The Far Sync instance will not forward redo to the Far_away physical standby because the Protection mode is not MaxProtection.
NEW QUESTION # 106
Examine this query and its output:
Which two statements are true?
  • A. The master observer is connected to the database on which the query was executed.
  • B. The master observer is not running, but should run on ol7.example.com.
  • C. The master observer is currently running on ol7.example.com.
  • D. The master observer is not connected to the database on which the query was executed.
  • E. Cats is a bystander database.
Answer: D,E
D: The database role indicated by FS_FAILOVER_STATUS as BYSTANDER implies that the database is a standby database in the Data Guard configuration. This means the database is neither a primary database nor an active failover target.
E: Since the FS_FAILOVER_OBSERVER_HOST column shows cats, it suggests that this is the host on which the observer would run. However, because the FS_FAILOVER_OBSERVER_PRESENT column is not shown, we cannot definitively state if the observer is currently connected or not. If FS_FAILOVER_OBSERVER_PRESENT is 'YES', the observer is connected, if 'NO', then it's not. In the absence of this column's output, the best assumption based on the available data is that the observer is not connected.
The output shows that the FS_FAILOVER_STATUS is BYSTANDER, which indicates that the database in question is not actively involved in a fast-start failover configuration as a primary or standby. It is in a bystander role, meaning that while it is part of a Data Guard configuration, it is neither a target for failover nor actively participating in failover operations. Additionally, FS_FAILOVER_OBSERVER_HOST shows
'cats', which indicates the host where the observer process is expected to run. However, since there is no information about the observer being present, we can infer that although 'cats' is designated for the observer to run, the observer is not currently connected to this database.
ReferencesOracle documentation on Data Guard configurations and the V$DATABASE view which provides information about the fast-start failover status and observer host.
NEW QUESTION # 107
You must configure flashback database for your Oracle 19c databases that will be part of a Data Guard Broker configuration.
The databases are all in ARCHIVELOG mode.
You will execute the SQL statement:
ALTER DATABASE FLASHBACK ON;
Which three are true concerning this command?
  • A. It will execute successfully on an Oracle 19c logical standby database while SQL apply is active.
  • B. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all logical standby databases that are part of the configuration.
  • C. It will execute successfully on an Oracle 19c physical standby database while Real Time Query is active.
  • D. It will execute successfully while an Oracle 19c primary database is open.
  • E. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all physical standby databases that are part of the configuration.
  • F. It will execute successfully while an Oracle 19c primary database is mounted.
Answer: A,D,F
The command ALTER DATABASE FLASHBACK ON; enables the Flashback Database feature, which provides a way to quickly revert an entire Oracle database back to a previous point in time. This command can be executed while an Oracle 19c primary database is either open (option A) or mounted (option B). It is also applicable to an Oracle 19c logical standby database while SQL Apply is active (option E). However, it's important to note that enabling Flashback Database on the primary does not automatically enable it on all associated standby databases, whether they are physical or logical. Each database in a Data Guard configuration must have Flashback Database explicitly enabled if desired. Real Time Query being active on a physical standby does not directly relate to the ability to execute this command on the standby. Reference: The explanation is based on Oracle's concepts for Flashback Technology and Data Guard configurations as detailed in the Oracle Database Backup and Recovery User's Guide and the Oracle Data Guard Concepts and Administration guide.
NEW QUESTION # 108
You may be busy in your jobs, learning or family lives and can’t get around to preparing and takes the certificate exams but on the other side you urgently need some useful 1z0-076 certificates to improve your abilities in some areas. So is there a solution which can kill two birds with one stone to both make you get the certificate and spend little time and energy to prepare for the exam? Our 1z0-076study materials provide a variety of functions to help the clients improve their learning. For example, the function to stimulate the exam helps the clients test their learning results of the 1z0-076 study materials in an environment which is highly similar to the real exam.
Reliable 1z0-076 Real Exam: https://www.trainingquiz.com/1z0-076-practice-quiz.html
DOWNLOAD the newest TrainingQuiz 1z0-076 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1RCATft2Zm2KKWFDKRNpw0NX1m5SFWx-E
Posted at 1/21/2026 17:34:05        Only Author  2#
The article gave me so much to think about. The Valid CAPM exam dumps pdf helped me secure a promotion and raise. It’s now free to all. Wishing you success in your promotion journey!
Posted at 2/14/2026 20:21:02        Only Author  3#
I truly appreciate your article; the content is truly amazing! Get the Latest 250-583 exam dumps questions for free—the key to earning a promotion and higher salary!
