Question about system partiation size and system.img size
2
Posted at 2/14/2015 06:19:01        Only Author  1#
From the wiki, I seem to gather that if the system.img partition is set to 768 MiB, that I can put a full 768MiB in there.
Is that correct, or did I misinterpret anything? There is no need to leave any empty space at either end of the partition?
Posted at 2/14/2015 11:51:39        Only Author  2#
Re: Question about system partiation size and system.img size
Yes, you can set it up to 768MB in Windows and use the full space.
In Linux, you can make it any size you want, eg. 1GB to have even more space.
Just remember to also change the parameter file to reflect the change in size of the partitions.
Posted at 2/16/2015 04:00:57        Only Author  3#
Of course.
I just wanted to make sure I didn't leave to any empty space at either end for anything reserved. I had already made an image of 1 GiB with the associated partition change in the parameter file, and it was working. I just wanted to not clobber anything in the next partition accidentally.
Thanks.
Posted at 2/16/2015 05:52:58        Only Author  4#
please make sure "offset + size = offset of next partition".
Posted at 2/16/2015 15:51:39        Only Author  5#
Oh, I'm good. I made a parameter.txt partition generator spreadsheet to avoid having to make silly calculation mistakes. Thanks for the concern though.
0x00200000@0x00092000(system)
0x00002000@0x00292000(metadata)
0x00C00000@0x00294000(userdata)
Edit: In case anyone wants to use my partition table maker, here's the base: https://mega.co.nz/#!RZsziYja!Te6f3c2gK ... sYbHXShKsY
Posted at 1/10/2026 18:48:58        Only Author  6#
Your article was truly remarkable, thank you for sharing it. Thanks to the CSDB new practice questions ebook, I got promoted and received a salary boost. It’s free now. Wishing you all a successful career advancement!
Posted at 1/25/2026 18:17:26        Only Author  7#
I’m absolutely amazed by your article, thank you for sharing it with me! Improve your IT abilities—free Exam sample INSTC_V8 questions now available! Good luck!
Posted at 5 hour before        Only Author  8#
The article was so wonderful; it was truly astonishing! The Reliable C_THR82_2505 exam syllabus content is highly informative, and it's offered at no cost.
