[Hardware] OmniStudio-Developer Valid Practice Questions - Valid OmniStudio-Developer Vce D
93
【Hardware】 OmniStudio-Developer Valid Practice Questions - Valid OmniStudio-Developer Vce D
Posted at 1/12/2026 06:11:07      View:152 | Replies:3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest DumpsKing OmniStudio-Developer PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=19B0ACiWwZawpFy3cJ5_aRKx-yudSiWYg
Have you ever noticed that people who prepare themselves for Salesforce OmniStudio-Developer certification exam do not need to negotiate their salaries for a higher level, they just get it after they are Salesforce OmniStudio-Developer Certified? The reason behind this fact is that they are considered the most deserving candidates for that particular job.
OmniStudio is a powerful low-code development platform that enables businesses to build and customize applications quickly and easily. The platform offers a variety of tools and features that allow developers to create complex applications without writing much code. The Salesforce OmniStudio-Developer Certification Exam is designed to test developers' knowledge of the platform and their ability to leverage its features to create custom applications.
OmniStudio-Developer – 100% Free Valid Practice Questions | Reliable Valid Salesforce Certified OmniStudio Developer Vce DumpsWe are a group of IT experts to provide professional study materials to people preparing Salesforce certification exam. There are free demo you can download to check the accuracy of our OmniStudio-Developer Braindumps. It just needs to take one or two days to practice DumpsKing OmniStudio-Developer dumps torrent and review the key points of our pass guide. Clearing exam is 100% guaranteed.
Salesforce OmniStudio-Developer certification is a valuable asset for Salesforce professionals looking to advance their career in development. Salesforce Certified OmniStudio Developer certification ensures that developers have the knowledge and skills necessary to design and develop effective solutions that are adaptive, scalable, and efficient. With the increasing demand for Salesforce development skills, the Salesforce OmniStudio-Developer Certification is an excellent way to demonstrate your expertise and stand out in the industry.
Salesforce Certified OmniStudio Developer Sample Questions (Q101-Q106):NEW QUESTION # 101
A healthcare company wants to enable its subscribers to add, edit, or delete dependents related to their policy Community portal. The developer on the project decides to use an MniScript.
How should the developer configure the OmniScript to providethis functionality?
  • A. Use an Edit Block element configured with Remote Actions.
  • B. Use a Text Block element and a Remote Action element.
  • C. Use an Edit Block element configured with SOQL statements.
  • D. Use an Input Block element and a DataRaptor Post Action element.
An Edit Block element configured with Remote Actions allows the developer to create a dynamic table that can display, add, edit, or delete records from a Salesforce object. The Remote Actions can be configured to perform CRUD operations on the object using SOQL or Apex.
NEW QUESTION # 102
Users receive an APEC CPU limit Exceeded error when running an OmniScript in a Salesfoce Community.
The OmniScript includes an Integration Procedure that contains two DataRaptors.
Which two Location should the developer check to troubleshoot the issue?
Choose 2 answers
  • A. Action Debugger
  • B. Community logs
  • C. DataRaptor configuration
  • D. Script configuration
According to the Troubleshoot Flow Errors page, one way to troubleshoot errors is to "check the debug logs for the community". Another way is to use the Action Debugger tool, which "lets you test and debug actions in OmniStudio".
NEW QUESTION # 103
A developer has an existing DataRaptorLoad that insert Contact records with inputs as LastName and firstName. The DataRaptor works as expected when previewed.
The developer creates an integration Procedure to test the DataRaptor and is using a SetValues element in the Integration Procedure toset the first name and last name for the contact record. The DataRaptor and Integration Procedure are set up as shown in the exhibit below.
When the developer executes the Integration procedure in preview, the following error message displays:
Required fields are missing: [last Name]'',
How should the developer address this issue?
  • A. The valid field names should be added in the Domain object field in theDataRaptor
  • B. The Set values Action Keys should include the DataRaptor Post Action element name path, e,g LoadContactDetails, lastname
  • C. The DataRaptor Post Action in the integration procedure should have been executed before the Set Values Action
  • D. SetValuesContactDetails should have been added to Additional input of DataRaptor Post Action in Integration Procedure
According to the Integration Procedure Actions page, "To pass data from a Set Values action to a DataRaptor action, add the Set Values action name to the Additional Input field of the DataRaptor action."
NEW QUESTION # 104
Why would a developer clone an Integration Procedure instead of versioning it?
  • A. The new Integration Procedure it replacing stub data.
  • B. The new Integration Procedure uses a Cache Block.
  • C. The new Integration Procedure is Chainable.
  • D. The new Integration Procedure will be used independently
NEW QUESTION # 105
In which two fields in an Integration Procedure or DataRaptor can you use a function like CONCAT or DATEDIFF? Choose 2 answers
  • A. In a DataRaptor in an Output Tab Output JSON Path.
  • B. In a Remote Action in an Additional Output value field.
  • C. In a DataRaptor Action in an Input Parameters value field.
  • D. In a Set Values Action in a Value field.
NEW QUESTION # 106
Valid OmniStudio-Developer Vce Dumps: https://www.dumpsking.com/OmniStudio-Developer-testking-dumps.html
P.S. Free 2026 Salesforce OmniStudio-Developer dumps are available on Google Drive shared by DumpsKing: https://drive.google.com/open?id=19B0ACiWwZawpFy3cJ5_aRKx-yudSiWYg
Posted at 1/18/2026 09:18:24        Only Author  2#
Your article is truly outstanding, thank you for sharing it with us! Get the Valid exam CIPT objectives pdf questions that helped me succeed in my career—for free today!
Posted at 1/21/2026 03:25:56        Only Author  3#
That article was a huge benefit to me. Free New DS0-001 learning materials test materials are available! Good luck!
Posted at 1/24/2026 17:04:52        Only Author  4#
The content of this article really inspired me, thank you for sharing! I achieved my promotion and salary raise with this Advanced-Administrator latest guide files. Now it’s free for all. Hope you get promoted soon!
