[General] Latest and Real Analytics-Admn-201 Exam Questions in Three User-Friendly Formats
78
General Latest and Real Analytics-Admn-201 Exam Questions in Three User-Friendly Formats
Posted at 1/12/2026 10:07:10      View108 | Replies0        Print      Only Author   [Copy Link] 1#
Another significant challenge of undertaking a Salesforce Analytics-Admn-201 exam is defining clear goals. Many students get bogged down by the volume of material they need to learn and lose sight of their goals. Thus, our Salesforce Analytics-Admn-201 Real Exam Questions in three formats provide you with the clear cut Analytics-Admn-201 preparation materials and defined goals to comprehensively prepare in the shortest possible time.
Salesforce Analytics-Admn-201 Exam Syllabus Topics:
  • Troubleshooting: This section of the exam measures the skills of Support Specialists and covers resolving common Tableau Server issues. Candidates must know how to reset accounts, package logs, validate site resources, rebuild search indexes, and use analysis reports. It also includes understanding the role of browser cookies and creating support requests when needed.
  • Administration: This section of the exam measures the skills of Tableau Administrators and covers the day-to-day tasks of maintaining Tableau Server. Candidates should understand how to create and manage schedules, subscriptions, backups, and restores, as well as how to use tools such as TSM, Tabcmd, and REST API. It emphasizes monitoring, server analysis, log file usage, and embedding practices. It also includes managing projects, sites, and nested structures, while contrasting end-user and administrator abilities. Knowledge of publishing, web authoring, sharing views, caching, and data source certification is also tested.
  • Connecting to and Preparing Data: This section of the exam measures the skills of Tableau Administrators and covers the basic understanding of Tableau Servers interface, navigation, and overall topology. Candidates are expected to recognize both client and server components, understand how these interact, and know where to find information about versions, releases, and updates. It also focuses on system requirements, including hardware, operating systems, browsers, email configurations, cloud considerations, and licensing models. Additionally, it examines knowledge of server processes, data source types, network infrastructure, and ports needed for a stable deployment.
  • Migration & Upgrade: This section of the exam measures the skills of System Engineers and covers the process of upgrading and migrating Tableau Server environments. Candidates should understand how to carry out clean reinstalls, migrate servers to new hardware, and maintain backward compatibility during the process.
Topic 5
  • Installation and Configuration: This section of the exam measures the skills of Server Engineers and covers the process of installing Tableau Server, understanding installation paths, identity store options, SSO integrations, SSL setup, and silent installs. Candidates also need to demonstrate the ability to configure Tableau Server by setting cache, distributing processes, customizing sites, and configuring user quotas. It further includes adding users, managing their roles and permissions, and applying Tableaus security model at different levels from sites to workbooks.
Free PDF Pass-Sure Salesforce - Analytics-Admn-201 - Salesforce Certified Tableau Server Administrator Valid Exam ReviewWith all of these Analytics-Admn-201 study materials, your success is 100% guaranteed. Moreover, we have Demos as freebies. The free demos give you a prove-evident and educated guess about the content of our Analytics-Admn-201 practice materials. As long as you make up your mind on this exam, you can realize their profession is unquestionable. And their profession is expressed in our Analytics-Admn-201 training prep thoroughly. They are great help to pass the Analytics-Admn-201 exam and give you an unforgettable experience.
Salesforce Certified Tableau Server Administrator Sample Questions (Q17-Q22):NEW QUESTION # 17
What should you use to set a preferred active repository?
  • A. The TSM browser client's Maintenance page
  • B. A tabcmd set command
  • C. The TSM browser client's Configuration Topology page
  • D. A tsm configuration set command
Tableau Server uses a PostgreSQL database as its repository to store metadata, user information, and permissions. In a high-availability (HA) setup with multiple nodes, there are typically two repository instances: one active and one passive. The "preferred active repository" refers to designating which repository instance should take priority as the active one. This is managed through Tableau Services Manager (TSM).
The correct method to set the preferred active repository is by using the tsm configuration set command.
Specifically, you would use a command like:
tsm configuration set -k pgsql.preferred_host -v <hostname>
This command allows an administrator to specify the preferred host for the active repository, ensuring control over which node takes precedence in an HA environment.
Option B (tabcmd set command) is incorrect because tabcmd is a command-line utility primarily used for administrative tasks like managing users, groups, and content (e.g., publishing workbooks), not for configuring server topology or repository settings.
Option C (TSM browser client's Maintenance page) is incorrect because the Maintenance page in the TSM web interface is used for tasks like backups, restores, and cleanup, but it does not provide an option to set the preferred active repository.
Option D (TSM browser client's Configuration Topology page) is partially relevant since the Topology page displays the current configuration of services across nodes, including the repository. However, it does not allow direct modification of the preferred active repository; this must be done via the tsm command line.
Reference: Tableau Server Documentation - "Configure Tableau Server Repository" (https://help.tableau.com
/current/server/en-us/repository.htm) and "TSM Command Line Reference" (https://help.tableau.com/current
/server/en-us/cli_configuration_set.htm).
NEW QUESTION # 18
Which three data sources support Kerberos delegation with Tableau Server? (Choose three.)
  • A. SQL Server
  • B. SAP HANA
  • C. Teradata
  • D. PostgreSQL
Answer: A,B,C
Kerberos delegation allows Tableau Server to pass a user's Kerberos credentials to a data source for seamless authentication (SSO)-let's explore which sources support it:
* Kerberos Overview:
* Used with Active Directory (AD) for SSO in Windows environments.
* Tableau Server delegates the user's ticket to the data source, avoiding embedded credentials.
* Requires:
* Data source support for Kerberos.
* Proper configuration (e.g., SPN, constrained delegation).
* Supported Data Sources: Per Tableau's documentation:
* Option A (Teradata): Correct.
* Details: Supports Kerberos delegation-common in enterprise data warehouses.
* Config: Enable in TSM (tsm authentication kerberos configure) and set SPN for Teradata.
* Option C (SQL Server): Correct.
* Details: Fully supports Kerberos-widely used with AD-integrated SQL Server instances.
* Config: Requires AD setup and "Trustworthy" delegation in SQL Server.
* Option D (SAP HANA): Correct.
* Details: Supports Kerberos SSO via delegation-popular in SAP ecosystems.
* Config: Needs HANA Kerberos setup (e.g., keytab) and Tableau Server integration.
* Option B (PostgreSQL): Incorrect.
* Why: Supports Kerberos authentication natively, but Tableau Server doesn't enable delegation to PostgreSQL-users must embed credentials or use other methods (e.g., OAuth).
Why This Matters: Kerberos delegation enhances security by avoiding stored passwords-knowing supported sources ensures SSO feasibility.
Reference: Tableau Server Documentation - "Kerberos Delegation" (https://help.tableau.com/current/server
/en-us/kerberos_delegation.htm), "Supported Connectors" (https://help.tableau.com/current/server/en-us
/datasource.htm).
NEW QUESTION # 19
A user receives an error after attempting to run an extract refresh on the Tableau Server. What should you review to identify the cause of the problem?
  • A. The UNC path to the extract's data source
  • B. Whether the project permissions are set to Locked to the project
  • C. The Background Tasks for Extracts administrative view on the site status page
  • D. The status of the Backgrounder process, as shown by the tsm status -v command
When an extract refresh fails on Tableau Server, troubleshooting requires identifying the root cause-e.g., connectivity issues, resource constraints, or configuration errors. The Backgrounder process handles extract refreshes, so it's a key focus, but the best diagnostic tool depends on granularity and context. Let's explore this thoroughly:
* Extract Refresh Process:
* An extract refresh pulls data from a source (e.g., database, file) into a .hyper file stored on Tableau Server.
* The Backgrounder executes these tasks based on schedules or manual triggers.
* Errors could stem from: database connectivity, credentials, file access, resource overload, or task misconfiguration.
* Option B (Background Tasks for Extracts administrative view): Correct. This is the most direct and detailed method:
* Location: In the Tableau Server web UI, go to Server > Status > Background Tasks for Extracts (or site-specific under Site > Status).
* Details Provided:
* Task name, schedule, and workbook/data source.
* Start/end times and status (e.g., Failed, Success).
* Error messages (e.g., "Cannot connect to database," "Permission denied").
* Why It's Best: It pinpoints the exact failure (e.g., "timeout," "invalid credentials") for the specific refresh, offering actionable insights without needing to dig through logs manually. Server or site administrators can access this view to diagnose issues quickly.
* Example: If the error is "Database login failed," you'd check credentials in the data source settings next.
* Option A (Status of the Backgrounder process via tsm status -v): Partially useful but insufficient:
* What It Shows: Running/stopped status of all processes (e.g., "Backgrounder: RUNNING").
* Limitation: It confirms if Backgrounder is operational but doesn't reveal why a specific task failed-no error details or task-level granularity.
* Use Case: If Backgrounder is stopped or crashed, this might indicate a broader issue, but the question implies a single refresh error, not a server-wide failure.
* Option C (The UNC path to the extract's data source): Relevant but secondary:
* Context: If the data source is a file (e.g., CSV on a network share), the UNC path (e.g.,
\servershare ile.csv) must be accessible.
* Why Not First: The error could be unrelated (e.g., database issue, not file-based). The admin view (B) would reveal if it's a path issue first, guiding you to check the UNC path only if indicated (e.g., "File not found").
* Practical Note: Backgrounder needs share permissions and the Run As account must access it- checking this without context wastes time.
* Option D (Whether project permissions are set to Locked): Unlikely cause:
* Permissions Impact: Locked permissions restrict who can edit/view content, not whether an extract refresh runs-that's tied to the data source's connection settings and Backgrounder execution.
* Exception: If the refresh user lacks "Connect" permission to the data source, it might fail, but this is rare (owner/schedule typically has access). The admin view would flag this.
Why This Matters: The Background Tasks view is Tableau's purpose-built tool for extract diagnostics, saving time and reducing guesswork in production environments.
Reference: Tableau Server Documentation - "Administrative Views: Background Tasks for Extracts" (https://help.tableau.com/current ... ackground_tasks.htm).
NEW QUESTION # 20
You attempt to delete a user who owns content on a Tableau Server. What is the result of the delete action?
  • A. The user is deleted, and the user's content is reassigned to the server administrator
  • B. The user is switched to an Unlicensed site role and is NOT deleted
  • C. The user is deleted, and the user's content is reassigned to the project leader
  • D. The user and all of the user's content is deleted
Deleting a user in Tableau Server involves handling their owned content (workbooks, data sources)-let's analyze the process:
* Deletion Rules:
* Ownership Check: Tableau prevents deletion if the user owns content to avoid orphaning it.
* Action: Instead of deleting, the user's site role is set to Unlicensed, retaining their account and content ownership.
* Resolution: An admin must reassign ownership (e.g., via Users > Actions > Change Owner) before deletion.
* Option D (User switched to Unlicensed and NOT deleted): Correct.
* Details: Attempting deletion (e.g., Users > Select User > Actions > Delete) triggers a check. If content exists, the user becomes Unlicensed-still in the system but unable to log in.
* Why: Protects data integrity-content remains accessible for reassignment.
* Option A (Deleted, content to server admin): Incorrect.
* Why: No automatic reassignment to the server admin-manual action is required first.
* Option B (Deleted, content to project leader): Incorrect.
* Why: Project leaders don't automatically inherit content-no such mechanism exists.
* Option C (User and content deleted): Incorrect.
* Why: Tableau avoids deleting content with the user-too destructive without explicit intent.
Why This Matters: This safeguard prevents accidental data loss, ensuring admins manage ownership transitions deliberately.
Reference: Tableau Server Documentation - "Delete Users" (https://help.tableau.com/current/server/en-us
/users_delete.htm).
NEW QUESTION # 21
When you use trusted tickets in Tableau Server, users can:
  • A. Encrypt database connections
  • B. Access embedded views without being prompted for credentials
  • C. Embed database credentials
  • D. Save and edit workbooks
Trusted Tickets is an authentication method in Tableau Server for embedding views in external applications (e.g., portals) without requiring users to log in manually. Here's how it works:
* A trusted application (e.g., a web server) authenticates with Tableau Server using a trusted IP or username/password.
* Tableau Server issues a temporary ticket (a unique string).
* The ticket is embedded in a view URL (e.g., /trusted/<ticket>/views/...), granting access to the view for a short period (configurable, default 5 minutes).
* Option A (Access embedded views without being prompted for credentials): Correct. Trusted tickets enable SSO-like behavior for embedded content, bypassing the login prompt if the ticket is valid. This is ideal for seamless integration into external systems.
* Option B (Encrypt database connections): Incorrect. Encryption is handled by data source configurations (e.g., SSL), not trusted tickets, which focus on user authentication.
* Option C (Save and edit workbooks): Incorrect. Trusted tickets grant view access, not edit permissions-those depend on the user's site role and permissions.
* Option D (Embed database credentials): Incorrect. Trusted tickets authenticate users to Tableau Server, not databases-database credentials are managed separately in the data source.
Why This Matters: Trusted tickets simplify embedding Tableau content securely in custom applications, enhancing user experience.
Reference: Tableau Server Documentation - "Trusted Authentication" (https://help.tableau.com/current/server
/en-us/trusted_auth.htm).
NEW QUESTION # 22
We have a team of experts curating the real Analytics-Admn-201 questions and answers for the end users. We are always working on updating the latest Analytics-Admn-201 questions and providing the correct Analytics-Admn-201 answers to all of our users. We will provide free updates for 1 year from the date of purchase. You can benefit from the updates Analytics-Admn-201 Preparation material, and you will be able to pass the Analytics-Admn-201 exam in the first attempt.
Analytics-Admn-201 Pass Exam: https://www.itcertmagic.com/Salesforce/real-Analytics-Admn-201-exam-prep-dumps.html
