[Linux] MaskRom Upgrade Mode failed
46
Linux MaskRom Upgrade Mode failed
Posted at 7/8/2022 21:53:49      View3214 | Replies6        Print      Only Author   [Copy Link] 1#
Hello,
im trying nake MaskRom Upgrade Mode for Linux for mb-jm3-rk3568 motherboard with core board Core-3568
I use this link 3. MaskRom mode
https://wiki.t-firefly.com/en/Core-3568J/04-maskrom_mode.html
And i used 4.3.2.1. The Method from Firefly
https://wiki.t-firefly.com/en/Co ... re_with_flash.html#
First time i successfully made firmware update using The Method from Firefly and my system loaded Ubuntu 18.04
But when i wanted update firmware using RKDevTool with RK356x_NorFlash2eMMC-Loader_xxx.img file again it ALWAYS stuck on upgrade:
Download Boot Fail
can you help me with that ?
Posted at 7/11/2022 10:04:16        Only Author  2#
Hiwhich RKDevTool  version do you use, is it v2.84?
Posted at 7/11/2022 10:16:02        Only Author  3#
if your board can boot into system normally
then just use LOADER mode to update firmware
Posted at 1/9/2026 15:39:47        Only Author  4#
Im inspired by the message in this article, thank you for sharing! Free access to GCIH Dumps Torrent materialsgood luck!
restricted members
Posted at 1/10/2026 15:31:42        Only Author  5#
Your article is absolutely outstanding, thank you for sharing it! The New D-AV-DY-23 test preparation material is very good, and its free to access.
Posted at 1/14/2026 22:07:12        Only Author  6#
What an incredible article, thank you for letting us read it. AP-205 exam study solutions test questions available for freeget ready for promotions and salary growth!
Posted at 2/21/2026 01:35:04        Only Author  7#
ExamFragen ist eine Website, die Bedrfnisse der Kunden abdecken kann. Diejenigen, die unsere Simulationssoftware zur BCS TM3 IT-Zertifizierungsprfung benutzt und die Prfung betanden haben, sind unsere Stammgäste geworden. ExamFragen stellt Ihnen die fortschrittliche Ausbildungstechnik zur Verfgung, die Ihnen beim Bestehen der BCS TM3 Zertifizierungsprfung hilft.
