Free PDF Quiz Updated CDCS - Exam EXIN EPI Certified Data Centre Specialist Prep
Posted at 1/13/2026 01:44:45
BONUS!!! Download part of NewPassLeader CDCS dumps for free: https://drive.google.com/open?id=1FovL_1CTF3SqWfl4vGzfUe_mNACk8FmO
For a company with history more than ten years, our CDCS practice materials have developed into fully academic maturity. All content are arranged legibly. There are three kinds of CDCS exam braindumps for your reference: the PDF, the Software and the APP online. All these versions of our CDCS study questions are high-efficient. You can choose either one in accordance with your interests or habits.
EXIN CDCS Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Data Centre Environmental Considerations and Efficiency: This section evaluates the proficiency of data center professionals in addressing environmental factors and promoting efficiency within data center operations. The target audience, including data center managers and engineers, will be tested on their ability to identify and implement measures that enhance energy efficiency, cooling management, and sustainable practices.
| | Topic 2 | - Data Centre Life Cycle and Standards: This section of the exam measures the skills of data center professionals and covers the various stages involved in the life cycle of a data center, from planning and design to implementation and decommissioning.
| | Topic 3 | - Designing and Implementing a Data Centre: In this module, the exam assesses the knowledge of Exin data center professionals tasked with the design and implementation of data centers. Candidates will learn the key principles of creating an efficient data center layout, including considerations for scalability, redundancy, and security.
Accurate CDCS Test - Latest CDCS MaterialIt Contains a pool of real EXIN CDCS exam questions. This EXIN EPI Certified Data Centre Specialist (CDCS) practice test is compatible with every windows-based system. One downloaded does not require an active internet connection to operate. You can self-evaluate your mistakes after each CDCS Practice Exam attempt and work on the weak points that require more attention.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q54-Q59):NEW QUESTION # 54
Three data centers are benchmarked on facilities energy efficiency.
Data center A has achieved a PUE of 2.45.
Data center B has achieved a PUE of 1.20.
Data center C has achieved a PUE of 1.90.
Which of the data centers is operating at the highest facility efficiency?
- A. Data center C
- B. PUE does not indicate efficiency
- C. Data center A
- D. Data center B
A Power Usage Effectiveness (PUE) of 1.20 (achieved by Data Center B) indicates the highest facility efficiency among the three data centers. A lower PUE value signifies better energy efficiency, as it means that a greater proportion of the total energy consumed is used directly for IT equipment rather than for cooling, lighting, or other facility needs.
Detailed Explanation:
PUE is calculated as the ratio of total facility energy to IT equipment energy. A PUE close to 1.0 suggests that almost all the energy is dedicated to computing processes, with minimal overhead. With PUE values of 2.45, 1.20, and 1.90, Data Center B (1.20) operates most efficiently by devoting a higher percentage of its total energy to IT equipment.
EPI Data Center Specialist References:
The EPI curriculum emphasizes PUE as a key metric for data center efficiency, with lower values representing better performance. Achieving a PUE near 1.0 aligns with industry best practices for energy-efficient data center design and operation.
NEW QUESTION # 55
What mainly affects the cooling capacity of a raised floor tile?
- A. Type of ICT equipment, location of the air conditioner, pressure under the raised floor, allowable temperature in the hot aisle
- B. Percentage of the surface opening, airflow direction of the ICT equipment, temperature difference between the air intake and air exhaust of the ICT equipment, construction material of the tile
- C. Relative humidity in the computer room, temperature of the cold air, pressure under the raised floor, construction material of the tile
- D. Percentage of the surface opening, obstruction of the supporting construction, pressure under the raised floor, damper construction
The cooling capacity of a raised floor tile is primarily influenced by the percentage of surface opening, the obstruction caused by the supporting construction, the pressure under the raised floor, and the damper construction. These factors dictate how much airflow can pass through the tile and how effectively cool air is distributed to the equipment in the data center.
The percentage of surface opening on a floor tile affects how much air can flow through, with larger openings allowing more airflow. Supporting structures beneath the floor can obstruct airflow, reducing cooling efficiency. Pressure under the raised floor impacts the velocity and volume of air that moves through the tile. Additionally, if dampers are installed, they control the airflow rate, which can be adjusted to meet specific cooling needs for the area.
EPI guidance on airflow management under raised floors emphasizes these factors as critical for effective cooling, especially in high-density areas. Ensuring unobstructed and adequate airflow helps maintain consistent cooling across equipment.
NEW QUESTION # 56
What is the risk of high levels of hydrogen sulfide (H#S) in the computer room?
- A. H#S can cause corrosion which impacts reliability of equipment
- B. H#S impacts gas-based fire suppression system operation
- C. There is no risk
- D. H#S impacts the static properties of the floor
Hydrogen sulfide (H#S) is a corrosive gas that readily reacts with metals, especially copper and silver found in circuit boards, connectors, and power supply components. Even at concentrations below human detection thresholds, H#S can cause sulfidation corrosion leading to intermittent connections, failure of solder joints, and increased failure rates of electronic equipment.
ASHRAE Technical Committee 9.9 has documented multiple failures in data centers due to corrosive gases (notably sulfur-bearing compounds). Therefore, high humidity combined with H#S presence accelerates this risk.
H#S does not affect static flooring properties (B) or fire suppression agent chemistry (D). Option A is clearly incorrect as the risk is well-documented.
References: ASHRAE TC 9.9 " articulate and Gaseous Contamination Guidelines" (2011), IEC 60721-3 (Environmental Classification).
NEW QUESTION # 57
The location of a data center is just above the Arctic Circle (North Pole). The outside air temperature is never above 21°C/70°F.
Taking energy efficiency as the highest priority, which cooling system should you recommend?
- A. Waterside economizer
- B. Any cooling system can be efficient because the outside air temperature will not influence the temperature of the air intake of the ICT equipment
- C. Standard air conditioning units, as spares might not be readily available
- D. Airside economizer
In locations with consistently cold temperatures, such as above the Arctic Circle, an airside economizer is the most energy-efficient cooling solution. Airside economizers use cool outside air to lower indoor temperatures, reducing or even eliminating the need for mechanical cooling. Given the consistently low temperatures, this method maximizes energy efficiency by leveraging natural cooling.
Airside economizers are ideal in environments where outside temperatures are consistently low. By drawing in and filtering cold outdoor air, they directly cool the indoor environment, thereby reducing energy consumption significantly compared to traditional air conditioning. This cooling approach aligns with energy efficiency goals by minimizing mechanical cooling demands.
EPI recommends the use of airside economizers in cold climates to achieve high energy efficiency, as they allow data centers to capitalize on ambient conditions for cooling, aligning with sustainability and cost-saving practices.
NEW QUESTION # 58
A computer room needs to be fitted out with a gas-based fire suppression system. The computer room will be a high-density data center with about 30% of the racks being closed circuit cooling blade-center racks.
Should the supplier of the fire suppression system be informed on the design of the racks?
- A. Only when the racks might block access to the fire panel.
- B. No, cooling and design of racks have no influence on the fire suppression system design.
- C. Yes, the design of the racks has an influence on the fire suppression system design.
- D. Only when the rack height obstructs a potential fire suppression release point.
The design and configuration of racks, particularly high-density and closed-circuit cooling racks, directly impact the fire suppression system design. Closed-circuit cooling racks, like blade-center racks, can affect airflow and potentially trap heat, influencing how fire suppression agents are distributed within the space.
Therefore, it is essential to inform the fire suppression system supplier about the rack design to ensure effective coverage and proper agent distribution.
High-density racks can change how smoke and heat travel, which in turn affects fire detection and suppression. Closed racks with built-in cooling can isolate airflow, requiring adjustments in fire suppression design to ensure that suppression agents reach all necessary areas, including within enclosed spaces. The supplier may need to account for these factors to ensure proper protection coverage.
The EPI Data Center Specialist training underscores that fire suppression systems must be tailored to the specific environmental characteristics of the data center. The design of racks, particularly high-density configurations, should always be considered to ensure that suppression agents can effectively control a fire, even in contained rack spaces.
NEW QUESTION # 59
Our products are compiled by experts from various industries and they are based on the true problems of the past years and the development trend of the industry. What's more, according to the development of the time, we will send the updated materials of CDCS test prep to the customers soon if we update the products. Under the guidance of our study materials, you can gain unexpected knowledge. Finally, you will pass the exam and get a CDCS Certification. Customers can learn according to their actual situation and it is flexible. Next I will introduce the advantages of our CDCS test prep so that you can enjoy our products.
Accurate CDCS Test: https://www.newpassleader.com/EXIN/CDCS-exam-preparation-materials.html
- Get Excellent Scores in Exam with EXIN CDCS Questions 🏔 Open ✔ [url]www.dumpsquestion.com ️✔️ and search for ▷ CDCS ◁ to download exam materials for free 😫CDCS Dumps Download[/url]
- Quiz CDCS - Fantastic Exam EXIN EPI Certified Data Centre Specialist Preparation 🧈 Open ➥ [url]www.pdfvce.com 🡄 and search for ▶ CDCS ◀ to download exam materials for free ⏲CDCS Dumps Download[/url]
- Cost Effective CDCS Dumps 🦁 CDCS Latest Study Guide ☸ Valid CDCS Exam Testking 🙌 Easily obtain { CDCS } for free download through ▶ [url]www.vce4dumps.com ◀ 🌰Exam CDCS Study Guide[/url]
- Cost Effective CDCS Dumps 🤗 Valid CDCS Exam Testking 🌆 CDCS Exam Dump 💥 Search for 《 CDCS 》 and easily obtain a free download on ➠ [url]www.pdfvce.com 🠰 🙁
DF CDCS Download[/url] - EXIN CDCS Exam | Exam CDCS Preparation - Valuable Accurate Test for your CDCS Studying 🕙 Open ✔ [url]www.practicevce.com ️✔️ and search for 「 CDCS 」 to download exam materials for free 🏖
DF CDCS Download[/url] - Quiz CDCS - Fantastic Exam EXIN EPI Certified Data Centre Specialist Preparation 🤓 Simply search for ▛ CDCS ▟ for free download on ⏩ [url]www.pdfvce.com ⏪ 🔧Exam CDCS Simulator[/url]
- Exam Dumps CDCS Collection 🐜 CDCS Latest Real Exam 🏮 Exam Dumps CDCS Collection 👳 Open website ⏩ [url]www.exam4labs.com ⏪ and search for ( CDCS ) for free download 📆CDCS Dumps Torrent[/url]
- Unlock Your Potential With Real EXIN CDCS Exam Dumps 📣 Enter 「 [url]www.pdfvce.com 」 and search for ➥ CDCS 🡄 to download for free 🐴CDCS Latest Real Exam[/url]
- CDCS Reliable Exam Blueprint 🛳 Premium CDCS Files 🔰 CDCS Reliable Exam Blueprint ☸ The page for free download of ▷ CDCS ◁ on 「 [url]www.prepawayete.com 」 will open immediately 🌎CDCS Latest Real Exam[/url]
- New CDCS Exam Pdf 🧄 CDCS Reliable Exam Blueprint 🤗 Premium CDCS Files 😢 Open 《 [url]www.pdfvce.com 》 and search for 《 CDCS 》 to download exam materials for free 📸Exam CDCS Study Guide[/url]
- Valid CDCS exam training material - cost-effective CDCS PDF files 🤗 Search for ✔ CDCS ️✔️ and download exam materials for free through ▷ [url]www.dumpsquestion.com ◁ 📩
remium CDCS Files[/url] - myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, bbs.moliyly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, sb.gradxacademy.in, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, xm.wztc58.cn, bbs.3927dj.com, royalblue-training.co.uk, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
DOWNLOAD the newest NewPassLeader CDCS PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1FovL_1CTF3SqWfl4vGzfUe_mNACk8FmO
