Home Button not working
543
Posted at 2/28/2015 00:08:46        Only Author  1#
Hi
Can you please explain what framework files, kernel files etc. are responsible for
the status bar icons and responses.
When I flashed Firefly 290115 firmware for the first time all the statusbar icons were working.
Now the 'Home' button doesn't work, no response when clicking on it. It just shows the highlighting on the icon but no response.
I change firefly 290115 firmware with Openhour Chameleon 10-02-2015 firmware framework files and then compile system.img again.
Then back button works again. Power button doesn't work and also top notification menu doesn't work. That's why I want to keep firefly framework files but just have a 'fixed' home button.
It would be nice to find out what files are responsible for the status bar responses.
Then I can compare it to other device firmwares and see what changed to make it not work.
Posted at 4/22/2025 19:34:42        Only Author  2#
If your device's Home Button has suddenly stopped working, you're not alone. This common issue can affect both smartphones and tablets, particularly on older devices with physical buttons. Here's construction project help what could be causing the problem—and what you can do to fix it.
Posted at 9/3/2025 16:42:42        Only Author  3#
slope game does not need a plot to attract players. Instead, the game builds a “story” for each person through the journey to overcome challenges. Each fall down the cliff is an ending, but each play is a new beginning. It is this constant rebirth that makes the game iconic in the endless runner genre.
Posted at 11/27/2025 17:38:59        Only Author  4#
The games in nytimes crossword are very unique and attractive, take some time to experience them!
Posted at 11/29/2025 17:35:32        Only Author  5#
Smash Karts 76 rewards creativity, letting players use clever moves, drifting techniques, and sneaky weapon tricks to outsmart stronger competitors.
Posted at 12/2/2025 15:38:05        Only Author  6#
Rush downhill in Snow Rider 2, dodge a variety of unexpected obstacles and unlock more powerful sleds to set new high scores that break all limits.
Posted at 7 day before        Only Author  7#
Find the Java or XML files that deal with what happens when you press the home button. It might be in the framework-res or SystemUI folders papa's pizzeria. Look for any circumstances or listeners that could be stopping the home button from working properly.
