100% Pass Quiz 2026 Newest Oracle 1z1-809: Java SE 8 Programmer II Book Pdf
Posted at 1/13/2026 04:03:03
P.S. Free & New 1z1-809 dumps are available on Google Drive shared by PrepAwayTest: https://drive.google.com/open?id=1q9SZX92N9IA6Cfe6SG2_rFXnK6xmYXkc
With the high employment pressure, more and more people want to ease the employment tension and get a better job. The best way for them to solve the problem is to get the 1z1-809 certification. Because the certification is the main symbol of their working ability, if they can own the 1z1-809 certification, they will gain a competitive advantage when they are looking for a job. An increasing number of people have become aware of that it is very important for us to gain the 1z1-809 Exam Questions in a short time. And our 1z1-809 exam questions can help you get the dreamng certification.
Oracle 1z0-809 certification is recognized worldwide as a benchmark for Java SE 8 proficiency, and passing the exam validates a candidate's ability to develop complex Java applications using advanced programming techniques. Java SE 8 Programmer II certification can help Java developers advance their careers and increase their earning potential, and it is highly valued by employers seeking to hire skilled Java developers.
1z1-809 Pass4sure - 1z1-809 Exam PriceYou are so busy that you have to save your time on the exam. Using our 1z1-809 study torrent, you will find you can learn about the knowledge of your 1z1-809 exam in a short time. Because you just need to spend twenty to thirty hours on the 1z1-809 practice exams, our 1z1-809 Study Materials will help you learn about all knowledge, you will successfully pass the 1z1-809 exam and get your certificate. So if you think time is very important for you, please try to use our 1z1-809 study materials, it will help you save your time.
Oracle 1z1-809 (Java SE 8 Programmer II) Exam is a certification exam designed for experienced Java programmers who want to demonstrate their expertise in Java SE 8 programming. 1z1-809 exam is a prerequisite for obtaining the Oracle Certified Professional, Java SE 8 Programmer certification. Candidates who Pass 1z1-809 Exam demonstrate their advanced knowledge of Java programming concepts and the ability to apply them to real-world programming tasks.
Oracle Java SE 8 Programmer II Sample Questions (Q82-Q87):NEW QUESTION # 82
Given the code fragments:
class Employee {
Optional<Address> address;
Employee (Optional<Address> address) {
this.address = address;
public Optional<Address> getAddress() { return address; }
class Address {
String city = "New York";
public String getCity { return city: }
public String toString() {
return city;
and
Address address = new Address;
Optional<Address> addrs1 = Optional.ofNullable (address);
Employee e1 = new Employee (addrs1);
String eAddress = (addrs1.isPresent()) ? addrs1.get().getCity() : "City Not available"; System.out.println(eAddress); What is the result?
- A. City Not available
- B. New York
- C. A NoSuchElementException is thrown at run time.
- D. null
NEW QUESTION # 83
4.void doStuff() throws ArithmeticException, NumberFormatException, Exception {
5.if (Math.random() >-1 throw new Exception ("Try again");
6.} and
24.
try {
25.
doStuff ( ):
26.
} catch (ArithmeticException | NumberFormatException | Exception e) {
27.
System.out.println (e.getMessage()); }
28.
catch (Exception e) {
29.
30.
Which modification enables the code to print Try again?
- A. Comment the lines 28, 29 and 30.
- B. Replace line 27 with:
throw e; - C. Replace line 26 with:
} catch (ArithmeticException | NumberFormatException e) { - D. Replace line 26 with:
} catch (Exception | ArithmeticException | NumberFormatException e) {
NEW QUESTION # 84
Given:
final class Folder { //line n1
/ /line n2
public void open () {
System.out.print("Open");
public class Test {
public static void main (String [] args) throws Exception {
try (Folder f = new Folder()) {
f.open();
Which two modifications enable the code to print Open Close?
- A. At line n2, insert:
final void close () {
System.out.print("Close");
} - B. Replace line n1 with:
class Folder extends Closeable { - C. Replace line n1 with:
class Folder implements AutoCloseable { - D. At line n2, insert:
public void close () throws IOException {
} - E. Replace line n1 with:
class Folder extends Exception {
Answer: C,E
NEW QUESTION # 85
Given the code fragment:
public void recDelete (String dirName) throws IOException {
File [ ] listOfFiles = new File (dirName) .listFiles();
if (listOfFiles ! = null && listOfFiles.length >0) {
for (File aFile : listOfFiles) {
if (!aFile.isDirectory ()) {
if (aFile.getName ().endsWith (".class"))
aFile.delete ();
Assume that Projects contains subdirectories that contain .class files and is passed as an argument to the recDelete () method when it is invoked.
What is the result?
- A. The method executes and does not make any changes to the Projects directory.
- B. The method deletes the .class files of the Projects directory only.
- C. The method throws an IOException.
- D. The method deletes all the .class files in the Projects directory and its subdirectories.
NEW QUESTION # 86
UnaryOperator<Integer> uo1 = s -> s*2; line n1
List<Double> loanValues = Arrays.asList(1000.0, 2000.0);
loanValues.stream()
.filter(lv -> lv >= 1500)
.map(lv -> uo1.apply(lv))
.forEach(s -> System.out.print(s + " "));
What is the result?
- A. A compilation error occurs at line n1.
- B. 0
- C. 4000.0
- D. A compilation error occurs at line n2.
Explanation/Reference:
NEW QUESTION # 87
1z1-809 Pass4sure: https://www.prepawaytest.com/Oracle/1z1-809-practice-exam-dumps.html
- Free PDF Quiz 2026 1z1-809: Java SE 8 Programmer II – Reliable Book Pdf 🕚 [ [url]www.prepawaypdf.com ] is best website to obtain 「 1z1-809 」 for free download 🕛1z1-809 Authentic Exam Hub[/url]
- Oracle 1z1-809 Practice Exam (Desktop - Web-Based) 🍘 Enter ➠ [url]www.pdfvce.com 🠰 and search for ☀ 1z1-809 ️☀️ to download for free 🍊1z1-809 Reliable Exam Simulator[/url]
- Latest 1z1-809 Exam Question 💓 Latest 1z1-809 Exam Fee 📞 1z1-809 Reliable Exam Simulator 🍩 Easily obtain 【 1z1-809 】 for free download through 「 [url]www.prepawayete.com 」 ✌1z1-809 Online Training Materials[/url]
- 100% Pass Quiz 2026 Oracle High Pass-Rate 1z1-809 Book Pdf 🕋 Search for 「 1z1-809 」 and obtain a free download on ▷ [url]www.pdfvce.com ◁ 🐠1z1-809 Exam Blueprint[/url]
- Popular 1z1-809 Study Materials Give You Excellent Exam Braindumps - [url]www.practicevce.com 🎭 The page for free download of 《 1z1-809 》 on 【 www.practicevce.com 】 will open immediately 📊Latest 1z1-809 Exam Question[/url]
- Popular 1z1-809 Study Materials Give You Excellent Exam Braindumps - Pdfvce 🦢 Search for “ 1z1-809 ” and download it for free on ⏩ [url]www.pdfvce.com ⏪ website 🌷1z1-809 Valid Braindumps Ppt[/url]
- Valid 1z1-809 Test Cram 💧 Valid 1z1-809 Exam Simulator 🥐 New 1z1-809 Exam Answers 🏣 Open ▶ [url]www.troytecdumps.com ◀ enter ( 1z1-809 ) and obtain a free download ❤1z1-809 Exam Blueprint[/url]
- 100% Pass Quiz 2026 Oracle High Pass-Rate 1z1-809 Book Pdf 🐠 Open 「 [url]www.pdfvce.com 」 and search for ( 1z1-809 ) to download exam materials for free 🧮New 1z1-809 Exam Answers[/url]
- Popular 1z1-809 Study Materials Give You Excellent Exam Braindumps - [url]www.practicevce.com ⏲ Search for ➤ 1z1-809 ⮘ and easily obtain a free download on ⮆ www.practicevce.com ⮄ 🔐New 1z1-809 Exam Answers[/url]
- Latest Braindumps 1z1-809 Ebook 🙄 Latest 1z1-809 Exam Fee 🍟 Detailed 1z1-809 Study Plan 💦 Open ▛ [url]www.pdfvce.com ▟ enter 【 1z1-809 】 and obtain a free download 🌎1z1-809 Valid Braindumps Ppt[/url]
- Dumps 1z1-809 Cost 🏪 1z1-809 Reliable Exam Simulator 👰 1z1-809 New Test Bootcamp 🎋 Search for ⏩ 1z1-809 ⏪ and download it for free on ▶ [url]www.vce4dumps.com ◀ website 🔑1z1-809 Authentic Exam Hub[/url]
- www.peiyuege.com, www.wenyixia.vip, stackblitz.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, github.com, shaxianxiaochi.gogreen.top, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, yiwnhua.com, Disposable vapes
BTW, DOWNLOAD part of PrepAwayTest 1z1-809 dumps from Cloud Storage: https://drive.google.com/open?id=1q9SZX92N9IA6Cfe6SG2_rFXnK6xmYXkc
