[General] New AZ-700 Test Blueprint & Real AZ-700 Torrent
82
【General】 New AZ-700 Test Blueprint & Real AZ-700 Torrent
Posted at 1/13/2026 04:04:52      View:205 | Replies:5        Print      Only Author   [Copy Link] 1#
2026 Latest ActualTestsIT AZ-700 PDF Dumps and AZ-700 Exam Engine Free Share: https://drive.google.com/open?id=19lGWYKxNMTjwR5j6kIg7vk4Ym2nmrgKj
If you want to clear Microsoft real exams but doubt to us, you can download the free demo of AZ-700 dumps pdf to check. We will provide the one-year free update once you purchase our AZ-700 Practice Questions. I will give you my support if you have any problems and doubts when you learn the Microsoft Certified: Azure Network Engineer Associate study materials.
As is known to all, before purchasing the AZ-700 Study Guide, we need to know the features of it. We offer you free demo to have a try, so that you can know the characteristics of AZ-700 exam dumps. Beside we have three versions, each version have its own advantages, and they can meet all of your demands. And we have free update for 365 days after buying, the latest version will send to you email box automatically.
100% Pass 2026 New AZ-700 Test Blueprint - Realistic Real Designing and Implementing Microsoft Azure Networking Solutions TorrentThe accuracy rate of AZ-700 test training materials of ActualTestsIT is high with wide coverage. It will be the most suitable AZ-700 test training materials and the one you need most to pass AZ-700 exam. We promise that we will provide renewal service freely as long as one year after you purchase our AZ-700 Dumps; if you fail AZ-700 test or there are any quality problem of our AZ-700 exam dumps and training materials, we will give a full refund immediately.
Microsoft Designing and Implementing Microsoft Azure Networking Solutions Sample Questions (Q52-Q57):NEW QUESTION # 52
Case Study 1 - Litware. Inc
Overview
Litware. Inc. is a financial company that has a main datacenter in Boston and 20 branch offices across the United States. Users have Android, iOS, and Windows 10 devices.
Existing Environment:
Hybrid Environment
The on-prernises network contains an Active Directory forest named litwareinc.com that syncs to an Azure Active Directory (Azure AD) tenant named litwareinc.com by usinq Azure AD Connect.
All the offices connect to a virtual network named Vnetl by using a Site-to-Site VPN connection.
Azure Environment
Litware has an Azure subscription named Sub1 that is linked to the litwareinc.com Azure AD tenant. Sub1 contains resources in the East US Azure region as shown in the following table.
A diagram of the resource in the East US Azure region is shown in the Network Diagram exhibit.
There is bidirectional peering between Vnet1 and Vnet2. There is bidirectional peering between Vnet1 and Vnet3. Currently, Vnet2 and Vnet3 cannot communicate directly.
Azure Environment Diagram
Requirements:
Business Requirements
Litware wants to minimize costs whenever possible, as long as all other requirements are met.
Virtual Networking Requirements
Litware identifies the following virtual networking requirements:
- Direct the default route of 0.0.0.0/0 on Vnet2 and Vnet3 to the
Boston datacenter over an ExpressRoute circuit.
- Ensure that the records in the cloud.litwareinc.com zone can be
resolved from the on-premises locations.
- Automatically register the DNS names of Azure virtual machines to the cloud.litwareinc.com zone.
- Minimize the size of the subnets allocated to platform-managed
services.
- Allow traffic from VMScaleSet1 to VMScaleSet2 on the TCP port 443
only.
Hybrid Networking Requirements
Litware identifies the following hybrid networking requirements:
- Users must be able to connect to Vnet1 by using a Point-to-Site (P2S) VPN when working remotely. Connections must be authenticated by Azure AD.
- Latency of the traffic between the Boston datacenter and all the
virtual networks must be minimized.
- The Boston datacenter must connect to the Azure virtual networks by
using an ExpressRoute FastPath connection.
- Traffic between Vnet2 and Vnet3 must be routed through Vnet1.
PaaS Networking Requirements
Litware identifies the following networking requirements for platform as a service (PaaS):
- The storage1 account must be accessible from all on-premises
locations without exposing the public endpoint of storage1.
- The storage2 account must be accessible from Vnet2 and Vnet3 without
exposing the public endpoint of storage2.
You need to connect Vnet2 and Vnet3. The solution must meet the virtual networking requirements and the business requirements.
Which two actions should you include in the solution? Each correct answer presents part of the solution.
  • A. On the peering from Vnet1, select Allow forwarded traffic.
  • B. On the peering from Vnet1, select Use remote gateways.
  • C. On the peerings from Vnet2 and Vnet3, select Use remote gateways.
  • D. On the peering from Vnet1, select Allow gateway transit.
  • E. On the peerings from Vnet2 and Vnet3, select Allow gateway transit.
Virtual network peering seamlessly connects two Azure virtual networks, merging the two virtual networks into one for connectivity purposes. Gateway transit is a peering property that lets one virtual network use the VPN gateway in the peered virtual network for cross-premises or VNet-to- VNet connectivity. The following diagram shows how gateway transit works with virtual network peering.
In the diagram, gateway transit allows the peered virtual networks to use the Azure VPN gateway in Hub-RM. Connectivity available on the VPN gateway, including S2S, P2S, and VNet-to-VNet connections, Reference:
https://docs.microsoft.com/en-us ... ing-gateway-transit
NEW QUESTION # 53
You have two Azure App Service instances that host the web apps shown the following table.
You deploy an Azure application gateway that has one public frontend IP address and two backend pools.
You need to publish all the web apps to the application gateway. Requests must be routed based on the HTTP host headers.
What is the minimum number of listeners and routing rules you should configure? To answer, select the appropriate options in the answer area.
See in explanation
NEW QUESTION # 54
You have the Azure virtual networks shown in the following table.
You deploy Azure Firewall to Vnet3.
You need to ensure that the traffic from Subnet1-1 to Subnet2-1 passes through the firewall. What should you configure?
  • A. a route table associated to AzureFitewallSubnet
  • B. an Azure private DNS zone
  • C. a route table associated to Subnet1 -1 and Subnet2-1
  • D. peering links between Vnet1 and Vnet2
NEW QUESTION # 55
You have three on-premises sites. Each site has a third-party VPN device.
You have an Azure virtual WAN named VWAN1 that has a hub named Hub1. Hub1 connects two of the three on-premises sites by using a Site-to-Site VPN connection.
You need to connect the third site to the other two sites by using Hub1.
Which four actions should you perform in sequence? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
Table Description automatically generated
https://docs.microsoft.com/en-us ... site-to-site-portal
NEW QUESTION # 56
You have two Azure virtual networks named Vnet1 and Vnet2.
You have a Windows 10 device named Client1 that connects to Vnet1 by using a Point-to-Site (P2S) IKEv2 VPN.
You implement virtual network peering between Vnet1 and Vnet2. Vnet1 allows gateway transit. Vnet2 can use the remote gateway.
You discover that Client1 cannot communicate with Vnet2.
You need to ensure that Client1 can communicate with Vnet2.
Solution: You download and reinstall the VPN client configuration.
Does this meet the goal?
  • A. No
  • B. Yes
The VPN client must be downloaded again if any changes are made to VNet peering or the network topology.
https://docs.microsoft.com/en-us ... int-to-site-routing
NEW QUESTION # 57
The best news is that during the whole year after purchasing our AZ-700 study materials , you will get the latest version of our AZ-700 exam prep for free, since as soon as we have compiled a new versions of the AZ-700 learning quiz, our company will send the latest one of our AZ-700 training engine to your email immediately. It will be quite fast and convenient to process and our systemw will auto inform you to free download as long as we update our exam dumps.
Real AZ-700 Torrent: https://www.actualtestsit.com/Microsoft/AZ-700-exam-prep-dumps.html
You can easily face any changes for AZ-700 Designing and Implementing Microsoft Azure Networking Solutions exam, Microsoft New AZ-700 Test Blueprint The updates are provided free for 120 days, Having a good command of professional knowledge for customers related to this AZ-700 exam is of superior condition, The students are making up their minds for the Microsoft AZ-700 test but they are mostly confused about where to prepare for it successfully on the first try, Microsoft AZ-700 practice test helps you to assess yourself as its tracker records all your results for future use.
later, I copy that information to other photos shot in the same place, Using Adobe Flash Builder, You can easily face any changes for AZ-700 Designing and Implementing Microsoft Azure Networking Solutions exam.
The updates are provided free for 120 days, Having a good command of professional knowledge for customers related to this AZ-700 exam is of superior condition.
100% Pass Efficient Microsoft - AZ-700 - New Designing and Implementing Microsoft Azure Networking Solutions Test BlueprintThe students are making up their minds for the Microsoft AZ-700 test but they are mostly confused about where to prepare for it successfully on the first try.
DOWNLOAD the newest ActualTestsIT AZ-700 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=19lGWYKxNMTjwR5j6kIg7vk4Ym2nmrgKj
Posted at 1/23/2026 11:40:28        Only Author  2#
I took away so much from reading that article. The AP-203 latest exam lab questions exam questions are available for free—unlock your promotion and salary increase!
Posted at 1/25/2026 09:17:27        Only Author  3#
I walked away from that article with a deeper understanding. Workday-Pro-Integrations reliable exam collection file offers premium content, and it's free of cost.
Posted at 1/27/2026 03:53:03        Only Author  4#
Thank you for sharing this inspiring piece of writing! I used the New D-VXR-DY-23 test pass4sure to secure a promotion and raise. Now, I’m offering it for free. Wishing you all success in your careers!
Posted at 1/29/2026 20:02:25        Only Author  5#
Im Informationszeitalter kümmern sich viele Leute um die IT-Branche. Aber es fehlen trozt den vielen Exzellenten doch IT-Fachleute. Viele Firmen stellen ihre Angestellte nach ihren Fragenkataloge Zertifikaten ein. Deshalb sind die Zertifikate bei den Firmen sehr beliebt. Aber es ist nicht so leicht, diese Zertifikate zu erhalten. Die Broadcom 250-583 Zertifizierungsprüfung ist eine schwierige Zertifizierungsprüfung. Obwohl viele Menschen beteiligen sich an der Broadcom 250-583 Zertifizierungsprüfung, ist jedoch die Pass-Quote eher niedrig.
Posted at 2/12/2026 18:23:41        Only Author  6#
This article is absolutely remarkable, I’m so thankful for your share. I’m just about to take the New free study 1Z0-1085-25 questions exam. Wish me success!
