Kernel panic when add ov4689 csi camera
Posted at 7/18/2022 22:03:48
View4515
Replies4
Hello! I am trying to connect ov4689 with RV1126_EVB_V12 using device tree, but have kernel panic error
- Starting kernel ...
- [ 0.000000] Booting Linux on physical CPU 0xf00
- [ 0.000000] Linux version 4.19.111 (root@4a847271fffe) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #2 SMP PREEMPT Mon Jul 18 12:32
- [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
- [ 0.000000] CPU: div instructions available: patching division code
- [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- [ 0.000000] OF: fdt: Machine model: Rockchip RV1109 V12 FACIAL GATE Board
- [ 0.000000] earlycon: uart8250 at MMIO32 0xff570000 (options '')
- [ 0.000000] bootconsole [uart8250] enabled
- [ 0.000000] Memory policy: Data cache writealloc
- [ 0.000000] Reserved memory: created CMA memory pool at 0x7f800000, size 8 MiB
- [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
- [ 0.000000] Reserved memory: created CMA memory pool at 0x5dc00000, size 512 MiB
- [ 0.000000] OF: reserved mem: initialized node isp, compatible id shared-dma-pool
- [ 0.000000] psci: probing for conduit method from DT.
- [ 0.000000] psci: PSCIv1.0 detected in firmware.
- [ 0.000000] psci: Using standard PSCI v0.2 function IDs
- [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
- [ 0.000000] psci: SMC Calling Convention v1.0
- [ 0.000000] percpu: Embedded 15 pages/cpu s32204 r8192 d21044 u61440
- [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 521656
- [ 0.000000] Kernel command line: user_debug=31 storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal rootwait earlycon=u7
- [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
- [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
- [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
- [ 0.000000] Memory: 1524572K/2094816K available (8192K kernel code, 383K rwdata, 1964K rodata, 1024K init, 898K bss, 37764K reserved, 53248)
- [ 0.000000] Virtual kernel memory layout:
- [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
- [ 0.000000] lowmem : 0xb0000000 - 0xf0000000 (1024 MB)
- [ 0.000000] pkmap : 0xafe00000 - 0xb0000000 ( 2 MB)
- [ 0.000000] modules : 0xaf000000 - 0xafe00000 ( 14 MB)
- [ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (9184 kB)
- [ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
- [ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 384 kB)
- [ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 899 kB)
- [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
- [ 0.000000] rcu: Preemptible hierarchical RCU implementation.
- [ 0.000000] Tasks RCU enabled.
- [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
- [ 0.000000] random: random: get_random_bytes called from start_kernel+0x328/0x4ac with crng_init=0
- [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
- [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
- [ 0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
- [ 0.000754] Switching to timer-based delay loop, resolution 41ns
- [ 0.002657] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
- [ 0.003616] pid_max: default: 4096 minimum: 301
- [ 0.004225] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
- [ 0.004850] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
- [ 0.006301] CPU: Testing write buffer coherency: ok
- [ 0.007159] /cpus/cpu@f00 missing clock-frequency property
- [ 0.007683] /cpus/cpu@f01 missing clock-frequency property
- [ 0.008203] /cpus/cpu@f02 missing clock-frequency property
- [ 0.008722] /cpus/cpu@f03 missing clock-frequency property
- [ 0.009241] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
- [ 0.010560] Setting up static identity map for 0x100000 - 0x100060
- [ 0.011318] rcu: Hierarchical SRCU implementation.
- [ 0.012419] smp: Bringing up secondary CPUs ...
- [ 0.013831] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
- [ 0.014910] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
- [ 0.015906] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
- [ 0.016045] smp: Brought up 1 node, 4 CPUs
- [ 0.018097] SMP: Total of 4 processors activated (192.00 BogoMIPS).
- [ 0.018678] CPU: All CPU(s) started in SVC mode.
- [ 0.020162] devtmpfs: initialized
- [ 0.048136] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
- [ 0.049521] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
- [ 0.050504] futex hash table entries: 16 (order: -2, 1024 bytes)
- [ 0.051312] pinctrl core: initialized pinctrl subsystem
- [ 0.053057] NET: Registered protocol family 16
- [ 0.054201] DMA: preallocated 256 KiB pool for atomic coherent allocations
- [ 0.056925] cpuidle: using governor menu
- [ 0.057359] Registered FIQ tty driver
- [ 0.058260] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
- [ 0.059003] hw-breakpoint: maximum watchpoint size is 8 bytes.
- [ 0.061817] console [pstore-1] enabled
- [ 0.062431] pstore: Registered ramoops as persistent store backend
- [ 0.063013] ramoops: attached 0x100000@0x8000000, ecc: 0/0
- [ 0.113038] cryptd: max_cpu_qlen set to 1000
- [ 0.114389] fiq debugger fiq mode enabled
- [[ 0.115202] console [ttyFIQ0] enabled
- 0.115202] console [ttyFIQ0] enabled
- [ 0.115887] bootconsole [uart8250] disabled
- [ 0.116601] Registered fiq debugger ttyFIQ0
- [ 0.117289] rockchip-pm rockchip-suspend: not set pwm-regulator-config
- [ 0.122433] rk_iommu ffb00f00.iommu: version = 1
- [ 0.123089] rk_iommu ffb20800.iommu: version = 1
- [ 0.123561] rk_iommu ffb60e00.iommu: version = 1
- [ 0.124212] rk_iommu ffb80480.iommu: version = 1
- [ 0.124857] rk_iommu ffb90800.iommu: version = 1
- [ 0.125335] rk_iommu ffbb0f00.iommu: version = 1
- [ 0.126392] SCSI subsystem initialized
- [ 0.126725] usbcore: registered new interface driver usbfs
- [ 0.126828] usbcore: registered new interface driver hub
- [ 0.127038] usbcore: registered new device driver usb
- [ 0.127162] media: Linux media interface: v0.10
- [ 0.127236] videodev: Linux video capture interface: v2.00
- [ 0.127306] pps_core: LinuxPPS API ver. 1 registered
- [ 0.127329] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
- [ 0.127373] PTP clock support registered
- [ 0.128874] Advanced Linux Sound Architecture Driver Initialized.
- [ 0.129652] Bluetooth: Core ver 2.22
- [ 0.129742] NET: Registered protocol family 31
- [ 0.129766] Bluetooth: HCI device and connection manager initialized
- [ 0.129796] Bluetooth: HCI socket layer initialized
- [ 0.129824] Bluetooth: L2CAP socket layer initialized
- [ 0.129884] Bluetooth: SCO socket layer initialized
- [ 0.130469] rockchip-cpuinfo cpuinfo: SoC : 11260000
- [ 0.130508] rockchip-cpuinfo cpuinfo: Serial : 5da4396c2aa764f5
- [ 0.131489] clocksource: Switched to clocksource arch_sys_counter
- [ 0.134193] NET: Registered protocol family 2
- [ 0.135104] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
- [ 0.135166] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
- [ 0.135331] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
- [ 0.135534] TCP: Hash tables configured (established 8192 bind 8192)
- [ 0.135702] UDP hash table entries: 512 (order: 2, 16384 bytes)
- [ 0.135784] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
- [ 0.136044] NET: Registered protocol family 1
- [ 0.137983] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
- [ 0.140804] Initialise system trusted keyrings
- [ 0.141070] workingset: timestamp_bits=29 max_order=19 bucket_order=0
- [ 0.149100] squashfs: version 4.0 (2009/01/31) Phillip Lougher
- [ 0.152222] Key type asymmetric registered
- [ 0.152255] Asymmetric key parser 'x509' registered
- [ 0.152331] bounce: pool size: 64 pages
- [ 0.152400] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
- [ 0.152429] io scheduler noop registered
- [ 0.152451] io scheduler deadline registered
- [ 0.152629] io scheduler cfq registered (default)
- [ 0.152658] io scheduler mq-deadline registered
- [ 0.152680] io scheduler kyber registered
- [ 0.152844] io scheduler bfq registered
- [ 0.155633] rockchip-mipi-dphy-rx ff4b8000.csi-dphy: bad remote port parent
- [ 0.157382] phy phy-ff4c0000.usb2-phy.1: Failed to get VBUS supply regulator
- [ 0.159461] rockchip-usb2phy-naneng ff4c8000.usb2-phy: failed to create phy
- [ 0.162019] pwm-backlight backlight: backlight supply power not found, using dummy regulator
- [ 0.162162] pwm-backlight backlight: Linked as a consumer to regulator.0
- [ 0.162578] mpp_service mpp-srv: unknown mpp version for missing VCS info
- [ 0.162612] mpp_service mpp-srv: probe start
- [ 0.163562] iommu: Adding device ffb80000.rkvdec to group 3
- [ 0.163619] mpp_rkvdec ffb80000.rkvdec: Linked as a consumer to ffb80480.iommu
- [ 0.163818] mpp_rkvdec ffb80000.rkvdec: probing start
- [ 0.164484] mpp_rkvdec ffb80000.rkvdec: shared_niu_a is not found!
- [ 0.164518] rkvdec_init:1182: No niu aclk reset resource define
- [ 0.164546] mpp_rkvdec ffb80000.rkvdec: shared_niu_h is not found!
- [ 0.164572] rkvdec_init:1185: No niu hclk reset resource define
- [ 0.164929] mpp_rkvdec ffb80000.rkvdec: probing finish
- [ 0.165680] iommu: Adding device ffbb0000.rkvenc to group 5
- [ 0.165752] mpp_rkvenc ffbb0000.rkvenc: Linked as a consumer to ffbb0f00.iommu
- [ 0.166071] mpp_rkvenc ffbb0000.rkvenc: probing start
- [ 0.166683] mpp_rkvenc ffbb0000.rkvenc: venc regulator not ready, retry
- [ 0.166716] rkvenc_init:1194: failed to add venc devfreq
- [ 0.167828] iommu: Adding device ffb90400.vdpu to group 4
- [ 0.167879] mpp_vdpu2 ffb90400.vdpu: Linked as a consumer to ffb90800.iommu
- [ 0.167990] mpp_vdpu2 ffb90400.vdpu: probe device
- [ 0.168567] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
- [ 0.168605] mpp_vdpu2 ffb90400.vdpu: reset_group->rw_sem_on=0
- [ 0.168873] mpp_vdpu2 ffb90400.vdpu: probing finish
- [ 0.169544] iommu: Adding device ffb90000.vepu to group 4
- [ 0.169594] mpp_vepu2 ffb90000.vepu: Linked as a consumer to ffb90800.iommu
- [ 0.169715] mpp_vepu2 ffb90000.vepu: probe device
- [ 0.170226] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
- [ 0.170268] mpp_vepu2 ffb90000.vepu: reset_group->rw_sem_on=0
- [ 0.170530] mpp_vepu2 ffb90000.vepu: probing finish
- [ 0.171094] iommu: Adding device ffb20000.iep to group 1
- [ 0.171163] mpp-iep2 ffb20000.iep: Linked as a consumer to ffb20800.iommu
- [ 0.171278] mpp-iep2 ffb20000.iep: probe device
- [ 0.172010] mpp-iep2 ffb20000.iep: allocate roi buffer failed
- [ 0.172241] mpp-iep2 ffb20000.iep: probing finish
- [ 0.172551] mpp_service mpp-srv: probe success
- [ 0.178088] dma-pl330 ff4e0000.dma-controller: Loaded driver for PL330 DMAC-241330
- [ 0.178132] dma-pl330 ff4e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
- [ 0.180672] rockchip-system-monitor rockchip-system-monitor: system monitor probe
- [ 0.181664] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
- [ 0.182613] ff560000.serial: ttyS0 at MMIO 0xff560000 (irq = 32, base_baud = 1500000) is a 16550A
- [ 0.183357] ff580000.serial: ttyS3 at MMIO 0xff580000 (irq = 33, base_baud = 1500000) is a 16550A
- [ 0.184000] ff590000.serial: ttyS4 at MMIO 0xff590000 (irq = 34, base_baud = 1500000) is a 16550A
- [ 0.184668] ff5a0000.serial: ttyS5 at MMIO 0xff5a0000 (irq = 35, base_baud = 1500000) is a 16550A
- [ 0.187354] random: fast init done
- [ 0.187865] random: crng init done
- [ 0.188129] iommu: Adding device ffb00000.vop to group 0
- [ 0.188228] rockchip-vop ffb00000.vop: Linked as a consumer to ffb00f00.iommu
- [ 0.192675] rockchip-drm display-subsystem: Linked as a consumer to ffb00000.vop
- [ 0.193839] rockchip-drm display-subsystem: Linked as a consumer to ffb30000.dsi
- [ 0.195313] rockchip-drm display-subsystem: devfreq is not set
- [ 0.195802] rockchip-drm display-subsystem: bound ffb00000.vop (ops 0xb093c280)
- [ 0.195885] dw-mipi-dsi ffb30000.dsi: [drm:dw_mipi_dsi_bind] *ERROR* Failed to find panel or bridge: -517
- [ 0.195922] rockchip-drm display-subsystem: failed to bind ffb30000.dsi (ops 0xb09429ac): -517
- [ 0.196198] rockchip-drm display-subsystem: master bind failed: -517
- [ 0.201788] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.1
- [ 0.201851] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsp not found, using dummy regulator
- [ 0.201959] panel-simple-dsi ffb30000.dsi.0: Linked as a consumer to regulator.0
- [ 0.202005] panel-simple-dsi ffb30000.dsi.0: ffb30000.dsi.0 supply vsn not found, using dummy regulator
- [ 0.203335] zram: Added device: zram0
- [ 0.205534] libphy: Fixed MDIO Bus: probed
- [ 0.207435] rk_gmac-dwmac ffc40000.ethernet: no regulator found
- [ 0.207480] rk_gmac-dwmac ffc40000.ethernet: clock input or output? (input).
- [ 0.207503] rk_gmac-dwmac ffc40000.ethernet: Can not read property: tx_delay.
- [ 0.207528] rk_gmac-dwmac ffc40000.ethernet: set tx_delay to 0x30
- [ 0.207555] rk_gmac-dwmac ffc40000.ethernet: Can not read property: rx_delay.
- [ 0.207580] rk_gmac-dwmac ffc40000.ethernet: set rx_delay to 0x10
- [ 0.207609] rk_gmac-dwmac ffc40000.ethernet: integrated PHY? (no).
- [ 0.207717] rk_gmac-dwmac ffc40000.ethernet: clock input from PHY
- [ 0.212757] rk_gmac-dwmac ffc40000.ethernet: init for RMII
- [ 0.213053] rk_gmac-dwmac ffc40000.ethernet: User ID: 0x30, Synopsys ID: 0x51
- [ 0.213086] rk_gmac-dwmac ffc40000.ethernet: DWMAC4/5
- [ 0.213115] rk_gmac-dwmac ffc40000.ethernet: DMA HW capability register supported
- [ 0.213141] rk_gmac-dwmac ffc40000.ethernet: RX Checksum Offload Engine supported
- [ 0.213165] rk_gmac-dwmac ffc40000.ethernet: TX Checksum insertion supported
- [ 0.213189] rk_gmac-dwmac ffc40000.ethernet: Wake-Up On Lan supported
- [ 0.213262] rk_gmac-dwmac ffc40000.ethernet: TSO supported
- [ 0.213283] rk_gmac-dwmac ffc40000.ethernet: Enable RX Mitigation via HW Watchdog Timer
- [ 0.213303] rk_gmac-dwmac ffc40000.ethernet: TSO feature enabled
- [ 0.324868] libphy: stmmac: probed
- [ 0.328694] dwc3 ffd00000.dwc3: Failed to get clk 'ref': -2
- [ 0.333993] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- [ 0.334034] ehci-platform: EHCI generic platform driver
- [ 0.334716] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
- [ 0.334768] ohci-platform: OHCI generic platform driver
- [ 0.336387] usbcore: registered new interface driver usb-storage
- [ 0.337447] i2c /dev entries driver
- [ 0.339480] rk808 0-0020: chip id: 0x8090
- [ 0.339592] rk808 0-0020: No cache defaults, reading back from HW
- [ 0.346021] rk808 0-0020: source: on=0x40, off=0x00
- [ 0.346064] rk808 0-0020: support dcdc3 fb mode:-22, -1331325532
- [ 0.346088] rk808 0-0020: support pmic reset mode:0,0
- [ 0.350573] rk808-regulator rk808-regulator: there is no dvs0 gpio
- [ 0.350703] rk808-regulator rk808-regulator: there is no dvs1 gpio
- [ 0.350810] DCDC_REG1: supplied by vcc5v0_sys
- [ 0.351574] DCDC_REG2: supplied by vcc5v0_sys
- [ 0.352219] DCDC_REG3: supplied by vcc5v0_sys
- [ 0.352738] DCDC_REG4: supplied by vcc5v0_sys
- [ 0.353264] DCDC_REG5: supplied by vcc5v0_sys
- [ 0.353881] LDO_REG1: supplied by vcc_buck5
- [ 0.354497] LDO_REG2: supplied by vcc_buck5
- [ 0.355033] LDO_REG3: supplied by vcc_buck5
- [ 0.355533] LDO_REG4: supplied by vcc_buck5
- [ 0.356028] LDO_REG5: supplied by vcc_buck5
- [ 0.356533] LDO_REG6: supplied by vcc_buck5
- [ 0.356617] vcc_dvdd: Bringing 1100000uV into 1300000-1300000uV
- [ 0.357207] LDO_REG7: supplied by vcc5v0_sys
- [ 0.357290] vcc_avdd: Bringing 2800000uV into 3300000-3300000uV
- [ 0.357871] LDO_REG8: supplied by vcc5v0_sys
- [ 0.358547] LDO_REG9: supplied by vcc5v0_sys
- [ 0.359175] SWITCH_REG1: supplied by vcc5v0_sys
- [ 0.359642] SWITCH_REG2: supplied by vcc3v3_sys
- [ 0.361932] input: rk805 pwrkey as /devices/platform/ff3f0000.i2c/i2c-0/0-0020/rk805-pwrkey/input/input0
- [ 0.364962] rk808-rtc rk808-rtc: registered as rtc0
- [ 0.365551] rk808-rtc rk808-rtc: setting system clock to 2017-08-04 09:00:01 UTC (1501837201)
- [ 0.368510] goodix_ts_probe() start
- [ 0.368590] Goodix-TS 5-0014: 5-0014 supply tp not found, using dummy regulator
- [ 0.368702] Goodix-TS 5-0014: Linked as a consumer to regulator.0
- [ 0.518497] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
- [ 0.615158] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
- [ 0.711827] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
- [ 0.808494] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
- [ 0.905160] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
- [ 1.001822] <<-GTP-ERROR->> I2C Read: 0x8000, 10 bytes failed, errcode: -6! Process reset.
- [ 1.098201] <<-GTP-ERROR->> I2C read 0x8000, 10 bytes, double check failed!
- [ 1.098228] <<-GTP-ERROR->> Failed to get chip-type, set chip type default: GOODIX_GT9
- [ 1.098543] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
- [ 1.194865] <<-GTP-ERROR->> GTP i2c test failed time 1.
- [ 1.211820] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
- [ 1.308198] <<-GTP-ERROR->> GTP i2c test failed time 2.
- [ 1.325150] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
- [ 1.421533] <<-GTP-ERROR->> GTP i2c test failed time 3.
- [ 1.438483] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
- [ 1.534865] <<-GTP-ERROR->> GTP i2c test failed time 4.
- [ 1.551819] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -6! Process reset.
- [ 1.648199] <<-GTP-ERROR->> GTP i2c test failed time 5.
- [ 1.664861] <goodix_ts_probe>_2749 I2C communication ERROR!
- [ 1.664888] <goodix_ts_probe>_2817 prob error !!!!!!!!!!!!!!!
- [ 1.664997] Goodix-TS 5-0014: Dropping the link to regulator.0
- [ 1.666111] ircut cam_ircut: driver version: 00.01.00
- [ 1.666409] ircut cam_ircut: failed get pulse-width,use dafult value 100
- [ 1.666723] ircut cam_ircut: probe successful!
- [ 1.667407] ERROR: could not get clock /mipi-csi2@ffb10000:srst_csihost_p(1)
- [ 1.667440] rockchip-mipi-csi2: failed to get rst clock, maybe useless
- [ 1.667722] rockchip-mipi-csi2: probe success, v4l2_dev:(null)!
- [ 1.669309] rkcifhw ffae0000.rkcif: no iommu attached, using non-iommu buffers
- [ 1.669365] rkcifhw ffae0000.rkcif: assigned reserved memory node isp
- [ 1.669525] rkcif rkcif_dvp: rkcif driver version: v00.01.09
- [ 1.669642] rkcif rkcif_dvp: attach to cif hw node
- [ 1.669674] rkcif rkcif_dvp: no iommu attached, using non-iommu buffers
- [ 1.669711] rkcif rkcif_dvp: assigned reserved memory node isp
- [ 1.670213] rkcif_dvp: Failed to register subdev notifier(-19)
- [ 1.670627] rkcif rkcif_dvp: detach to cif hw node
- [ 1.670744] rkcif rkcif_mipi_lvds: rkcif driver version: v00.01.09
- [ 1.670855] rkcif rkcif_mipi_lvds: attach to cif hw node
- [ 1.670886] rkcif rkcif_mipi_lvds: no iommu attached, using non-iommu buffers
- [ 1.670922] rkcif rkcif_mipi_lvds: assigned reserved memory node isp
- [ 1.672036] rkcif rkcif_mipi_lvds: fwnode has already been registered or in notifier's subdev list
- [ 1.672071] rkcif_mipi_lvds: Failed to register subdev notifier(-17)
- [ 1.672966] rkcif rkcif_mipi_lvds: detach to cif hw node
- [ 1.673007] rkcif: probe of rkcif_mipi_lvds failed with error -17
- [ 1.673566] rkcif_sditf rkcif_mipi_lvds_sditf: failed attach cif dev
- [ 1.673608] Unable to handle kernel NULL pointer dereference at virtual address 00000008
- [ 1.679617] pgd = 4b3126e5
- [ 1.679869] [00000008] *pgd=00000000
- [ 1.680205] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
- [ 1.680686] Modules linked in:
- [ 1.680976] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.19.111 #2
- [ 1.681523] Hardware name: Generic DT based system
- [ 1.681976] PC is at rkcif_subdev_probe+0x104/0x190
- [ 1.682419] LR is at rkcif_subdev_probe+0xfc/0x190
- [ 1.682857] pc : [<b05d25d0>] lr : [<b05d25c8>] psr: 60000013
- [ 1.683417] sp : ee8a1d00 ip : 00000000 fp : 00000014
- [ 1.683888] r10: 00000000 r9 : b0d4b1e0 r8 : 00000000
- [ 1.684359] r7 : eeb1f810 r6 : ee16c8b8 r5 : ee16c844 r4 : ee16c840
- [ 1.684943] r3 : 00004001 r2 : 00000000 r1 : 00000001 r0 : 00000000
- [ 1.685530] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
- [ 1.686171] Control: 10c5387d Table: 0000406a DAC: 00000055
- [ 1.686686]
- [ 1.686686] PC: 0xb05d2550:
- [ 1.687079] 2550 e586300c e5c60012 e5943000 e58470a8 e5930170 eb024c45 e2508000 0a000026
- [ 1.687824] 2570 eb024712 e3500000 0a000023 e1a00008 eb025136 e3500000 0a000027 e5903064
- [ 1.688568] 2590 e3530000 12832a03 11a08003 15824530 158430e4 0a000026 e3a02002 e3043001
- [ 1.689312] 25b0 e58420e0 e3a01001 e28420c8 e584301c e1a00005 ebff586d e3500000 b8bd81f0
- [ 1.690056] 25d0 e5983008 e3a02020 e1a00006 e593102c e3510000 05931008 eb0a4809 e1a00005
- [ 1.690800] 25f0 ebffa82a e3500000 b8bd81f0 e1a00007 ebfb49ef e3a00000 e8bd81f0 e30119c0
- [ 1.691544] 2610 e5940000 e34b10a8 ebfb112d e59480e4 eaffffe0 e3e0000b e8bd81f0 e30119dc
- [ 1.692288] 2630 e5940000 e34b10a8 ebfb1125 e59480e4 eaffffd8 e3011a00 e5940000 e34b10a8
- [ 1.693035]
- [ 1.693035] LR: 0xb05d2548:
- [ 1.693427] 2548 e1c681b0 e3a02000 e586300c e5c60012 e5943000 e58470a8 e5930170 eb024c45
- [ 1.694171] 2568 e2508000 0a000026 eb024712 e3500000 0a000023 e1a00008 eb025136 e3500000
- [ 1.694915] 2588 0a000027 e5903064 e3530000 12832a03 11a08003 15824530 158430e4 0a000026
- [ 1.695659] 25a8 e3a02002 e3043001 e58420e0 e3a01001 e28420c8 e584301c e1a00005 ebff586d
- [ 1.696402] 25c8 e3500000 b8bd81f0 e5983008 e3a02020 e1a00006 e593102c e3510000 05931008
- [ 1.697147] 25e8 eb0a4809 e1a00005 ebffa82a e3500000 b8bd81f0 e1a00007 ebfb49ef e3a00000
- [ 1.697893] 2608 e8bd81f0 e30119c0 e5940000 e34b10a8 ebfb112d e59480e4 eaffffe0 e3e0000b
- [ 1.698638] 2628 e8bd81f0 e30119dc e5940000 e34b10a8 ebfb1125 e59480e4 eaffffd8 e3011a00
- [ 1.699384]
- [ 1.699384] SP: 0xee8a1c80:
- [ 1.699777] 1c80 eefcbbc8 ba4991a6 40000013 ba4991a6 ee16c844 b05d25d0 60000013 ffffffff
- [ 1.700521] 1ca0 ee8a1ce4 00000000 ee8a0000 b01019f0 00000000 00000001 00000000 00004001
- [ 1.701266] 1cc0 ee16c840 ee16c844 ee16c8b8 eeb1f810 00000000 b0d4b1e0 00000000 00000014
- [ 1.702011] 1ce0 00000000 ee8a1d00 b05d25c8 b05d25d0 60000013 ffffffff 00000000 00000000
- [ 1.702755] 1d00 eeb1f810 00000000 b0d4b1e0 00000000 00000000 b049d088 b0e326b4 eeb1f810
- [ 1.703499] 1d20 b0e326b8 b049b390 eeb1f810 b0d4b1e0 b0d4b1e0 b0d08c48 00000000 eefdf808
- [ 1.704243] 1d40 ee976394 b049b5a0 b0e359b4 b0970b30 a0000013 eeb1f810 00000000 b0d4b1e0
- [ 1.704987] 1d60 b0d08c48 00000000 eefdf808 ee976394 00000014 b049b848 00000000 b0d4b1e0
- [ 1.705734]
- [ 1.705734] R4: 0xee16c7c0:
- [ 1.706128] c7c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.706872] c7e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.707617] c800 eeb1f994 eeb1f994 b049e5ec 00000000 00000000 00000000 00000000 00000000
- [ 1.708361] c820 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.709103] c840 eeb1f810 00000000 00000000 00000000 00000000 ee16c8b8 00000002 00004001
- [ 1.709847] c860 00000000 00000001 00000000 00000000 ee16c908 00000000 00000000 00000000
- [ 1.710590] c880 00000000 00000000 00000000 00000000 00000000 ee16c894 ee16c894 00000000
- [ 1.711334] c8a0 00000000 00000004 00000000 b0970b10 00000000 00000000 6b636f72 70696863
- [ 1.712080]
- [ 1.712080] R5: 0xee16c7c4:
- [ 1.712473] c7c4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.713216] c7e4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 eeb1f994
- [ 1.713959] c804 eeb1f994 b049e5ec 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.714703] c824 00000000 00000000 00000000 00000000 00000000 00000000 00000000 eeb1f810
- [ 1.715447] c844 00000000 00000000 00000000 00000000 ee16c8b8 00000002 00004001 00000000
- [ 1.716192] c864 00000001 00000000 00000000 ee16c908 00000000 00000000 00000000 00000000
- [ 1.716936] c884 00000000 00000000 00000000 00000000 ee16c894 ee16c894 00000000 00000000
- [ 1.717682] c8a4 00000004 00000000 b0970b10 00000000 00000000 6b636f72 70696863 6669632d
- [ 1.718429]
- [ 1.718429] R6: 0xee16c838:
- [ 1.718821] c838 00000000 00000000 eeb1f810 00000000 00000000 00000000 00000000 ee16c8b8
- [ 1.719565] c858 00000002 00004001 00000000 00000001 00000000 00000000 ee16c908 00000000
- [ 1.720308] c878 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ee16c894
- [ 1.721051] c898 ee16c894 00000000 00000000 00000004 00000000 b0970b10 00000000 00000000
- [ 1.721795] c8b8 6b636f72 70696863 6669632d 6964732d 00006674 00000000 00000000 00000000
- [ 1.722539] c8d8 00000000 00000000 00000000 00000000 eeb1f810 00000000 00000000 00000000
- [ 1.723283] c8f8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.724026] c918 ee16c844 00000000 00000002 00000000 00000000 00000000 00000000 00000000
- [ 1.724774]
- [ 1.724774] R7: 0xeeb1f790:
- [ 1.725167] f790 00040004 eeb1f794 eeb1f794 00000000 00000000 00000000 00000000 00000000
- [ 1.725910] f7b0 00000000 b049cbc8 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.726652] f7d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.727396] f7f0 00000000 00000000 00000000 00000000 ee91a5c0 ffffffff 00000000 00000000
- [ 1.728141] f810 b0d37a20 ee912c80 ee91a5c0 eeb1fa1c eeb1f61c b0d37a28 ee860080 b0d3774c
- [ 1.728886] f830 ee91e000 00000003 00000007 00000000 00000000 ee898000 00000000 00000000
- [ 1.729630] f850 eeb1f850 eeb1f850 b0d37bd8 b0d4b1e0 00000000 ee16c844 eeb1f868 eeb1f868
- [ 1.730376] f870 eeb1f870 eeb1f870 eeb1f878 eeb1f878 eeb1f880 eeb1f880 00000000 00000001
- [ 1.731123]
- [ 1.731123] R9: 0xb0d4b160:
- [ 1.731515] b160 b05d13d0 b05d1514 b05d1e0c b05d1c08 00000000 00000000 00000000 b0a8186c
- [ 1.732259] b180 b0d37bd8 00000000 00000000 00000000 00000000 b096f6c4 00000000 b049d040
- [ 1.733003] b1a0 00000000 b049d004 b049ca18 00000000 00000000 00000000 b096fe6c 00000000
- [ 1.733748] b1c0 ee981d00 00000000 00000000 b05d24cc b05d2258 00000000 00000000 00000000
- [ 1.734492] b1e0 b0a81a18 b0d37bd8 00000000 00000000 00000000 00000000 b0970b30 00000000
- [ 1.735236] b200 b049d040 00000000 b049d004 b049ca18 00000000 00000000 00000000 b0970cb8
- [ 1.735981] b220 00000000 ee988500 00000000 00000000 b09718ac 00000000 00000000 b09718d8
- [ 1.736725] b240 00000000 00000000 00000000 b0971928 b05d6cf4 b05d69d4 00000000 00000000
- [ 1.737474] Process swapper/0 (pid: 1, stack limit = 0x40e6566d)
- [ 1.738013] Stack: (0xee8a1d00 to 0xee8a2000)
- [ 1.738418] 1d00: eeb1f810 00000000 b0d4b1e0 00000000 00000000 b049d088 b0e326b4 eeb1f810
- [ 1.739153] 1d20: b0e326b8 b049b390 eeb1f810 b0d4b1e0 b0d4b1e0 b0d08c48 00000000 eefdf808
- [ 1.739889] 1d40: ee976394 b049b5a0 b0e359b4 b0970b30 a0000013 eeb1f810 00000000 b0d4b1e0
- [ 1.740623] 1d60: b0d08c48 00000000 eefdf808 ee976394 00000014 b049b848 00000000 b0d4b1e0
- [ 1.741358] 1d80: eeb1f810 b049b8d0 00000000 b0d4b1e0 b049b850 b0499754 00000000 ee854658
- [ 1.742094] 1da0: ee912cb4 ba4991a6 b0d37bd8 b0d4b1e0 ee988500 b0d37bd8 00000000 b049a6f4
- [ 1.742829] 1dc0: b0a81a18 eeb35a10 ee976340 b0d4b1e0 eeb35a10 ee976340 eeb35a00 b049c0e4
- [ 1.743563] 1de0: b096fef8 eeb35a10 ee976340 b05d21bc 00000000 b0a8186c eeb35a10 00000062
- [ 1.744298] 1e00: 00000000 eeb35a10 00000000 b0d4b17c 00000000 00000000 b0d4b17c 00000000
- [ 1.745033] 1e20: eefc3400 b049d088 b0e326b4 eeb35a10 b0e326b8 b049b390 eeb35a10 b0d4b17c
- [ 1.745768] 1e40: b0d4b17c b0d08c48 00000000 00000007 b0c3103c b049b5a0 b0e359b4 b096f6c4
- [ 1.746503] 1e60: a0000013 eeb35a10 00000000 b0d4b17c b0d08c48 00000000 00000007 b0c3103c
- [ 1.747237] 1e80: eefc3400 b049b848 00000000 b0d4b17c eeb35a10 b049b8d0 00000000 b0d4b17c
- [ 1.747972] 1ea0: b049b850 b0499754 00000000 ee854658 ee9398b4 ba4991a6 b0d37bd8 b0d4b17c
- [ 1.748709] 1ec0: ee981d00 b0d37bd8 00000000 b049a6f4 b0a8186c b0d08c48 ffffe000 b0d4b17c
- [ 1.749444] 1ee0: b0d08c48 ffffe000 b0c1ca70 b049c0e4 b0d5fd00 b0d08c48 ffffe000 b010265c
- [ 1.750180] 1f00: b0ae9e7c 000000d8 000000bc b0142200 b0ae8fcc 00000000 b0c005b0 00000000
- [ 1.750915] 1f20: 00000006 00000006 b0a22a5c b0a43dbc b0a190d0 b0d08c48 00000000 eefc34c0
- [ 1.751650] 1f40: eefc34d0 ba4991a6 00000000 ba4991a6 b0d5fd00 b0d5fd00 b0c48f94 b0c31034
- [ 1.752385] 1f60: 000000d8 b0c3103c eefc3400 b0c00ee4 00000006 00000006 00000000 b0c005b0
- [ 1.753119] 1f80: b0869dfc 00000000 b0869dfc 00000000 00000000 00000000 00000000 00000000
- [ 1.753852] 1fa0: 00000000 b0869e04 00000000 b01010d8 00000000 00000000 00000000 00000000
- [ 1.754586] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.755318] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
- [ 1.756073] [<b05d25d0>] (rkcif_subdev_probe) from [<b049d088>] (platform_drv_probe+0x48/0x9c)
- [ 1.756848] [<b049d088>] (platform_drv_probe) from [<b049b390>] (really_probe+0x210/0x2bc)
- [ 1.757599] [<b049b390>] (really_probe) from [<b049b5a0>] (driver_probe_device+0x60/0x160)
- [ 1.758349] [<b049b5a0>] (driver_probe_device) from [<b049b848>] (device_driver_attach+0x58/0x60)
- [ 1.759142] [<b049b848>] (device_driver_attach) from [<b049b8d0>] (__driver_attach+0x80/0xb8)
- [ 1.759912] [<b049b8d0>] (__driver_attach) from [<b0499754>] (bus_for_each_dev+0x68/0xb4)
- [ 1.760650] [<b0499754>] (bus_for_each_dev) from [<b049a6f4>] (bus_add_driver+0xf0/0x1e4)
- [ 1.761389] [<b049a6f4>] (bus_add_driver) from [<b049c0e4>] (driver_register+0x78/0x10c)
- [ 1.762117] [<b049c0e4>] (driver_register) from [<b05d21bc>] (rkcif_plat_probe+0x3b0/0x43c)
- [ 1.762866] [<b05d21bc>] (rkcif_plat_probe) from [<b049d088>] (platform_drv_probe+0x48/0x9c)
- [ 1.763628] [<b049d088>] (platform_drv_probe) from [<b049b390>] (really_probe+0x210/0x2bc)
- [ 1.764377] [<b049b390>] (really_probe) from [<b049b5a0>] (driver_probe_device+0x60/0x160)
- [ 1.765126] [<b049b5a0>] (driver_probe_device) from [<b049b848>] (device_driver_attach+0x58/0x60)
- [ 1.765921] [<b049b848>] (device_driver_attach) from [<b049b8d0>] (__driver_attach+0x80/0xb8)
- [ 1.766693] [<b049b8d0>] (__driver_attach) from [<b0499754>] (bus_for_each_dev+0x68/0xb4)
- [ 1.767431] [<b0499754>] (bus_for_each_dev) from [<b049a6f4>] (bus_add_driver+0xf0/0x1e4)
- [ 1.768168] [<b049a6f4>] (bus_add_driver) from [<b049c0e4>] (driver_register+0x78/0x10c)
- [ 1.768898] [<b049c0e4>] (driver_register) from [<b010265c>] (do_one_initcall+0x54/0x194)
- [ 1.769643] [<b010265c>] (do_one_initcall) from [<b0c00ee4>] (kernel_init_freeable+0x144/0x1dc)
- [ 1.770432] [<b0c00ee4>] (kernel_init_freeable) from [<b0869e04>] (kernel_init+0x8/0x110)
- [ 1.771172] [<b0869e04>] (kernel_init) from [<b01010d8>] (ret_from_fork+0x14/0x3c)
- [ 1.771844] Exception stack(0xee8a1fb0 to 0xee8a1ff8)
- [ 1.772308] 1fa0: 00000000 00000000 00000000 00000000
- [ 1.773042] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.773773] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
- [ 1.774375] Code: e1a00005 ebff586d e3500000 b8bd81f0 (e5983008)
- [ 1.774991] ---[ end trace 4b59f3377d9bef70 ]---
- [ 1.778826] Kernel panic - not syncing: Fatal exception
- [ 1.779315] CPU3: stopping
- [ 1.779577] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.19.111 #2
- [ 1.780247] Hardware name: Generic DT based system
- [ 1.780708] [<b010f408>] (unwind_backtrace) from [<b010b970>] (show_stack+0x10/0x14)
- [ 1.781406] [<b010b970>] (show_stack) from [<b0855524>] (dump_stack+0x90/0xa4)
- [ 1.782056] [<b0855524>] (dump_stack) from [<b010e31c>] (handle_IPI+0x178/0x18c)
- [ 1.782736] [<b010e31c>] (handle_IPI) from [<b03c0ab4>] (gic_handle_irq+0x74/0x78)
- [ 1.783420] [<b03c0ab4>] (gic_handle_irq) from [<b0101a78>] (__irq_svc+0x58/0x8c)
- [ 1.784082] Exception stack(0xee8cff58 to 0xee8cffa0)
- [ 1.784545] ff40: 00000000 0000077c
- [ 1.785280] ff60: eefb650c b011a880 ee8ce000 b0d08c70 b0d08cac 00000008 00000000 00000000
- [ 1.786015] ff80: b0c505f0 ee8cffb0 3e368000 ee8cffa8 b0108990 b0108994 60000013 ffffffff
- [ 1.786755] [<b0101a78>] (__irq_svc) from [<b0108994>] (arch_cpu_idle+0x38/0x3c)
- [ 1.787431] [<b0108994>] (arch_cpu_idle) from [<b014e620>] (do_idle+0x1c0/0x29c)
- [ 1.788105] [<b014e620>] (do_idle) from [<b014e9cc>] (cpu_startup_entry+0x18/0x1c)
- [ 1.788787] [<b014e9cc>] (cpu_startup_entry) from [<001023cc>] (0x1023cc)
- [ 1.789397] CPU0: stopping
- [ 1.789656] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.19.111 #2
- [ 1.790326] Hardware name: Generic DT based system
- [ 1.790768] [<b010f408>] (unwind_backtrace) from [<b010b970>] (show_stack+0x10/0x14)
- [ 1.791472] [<b010b970>] (show_stack) from [<b0855524>] (dump_stack+0x90/0xa4)
- [ 1.792121] [<b0855524>] (dump_stack) from [<b010e31c>] (handle_IPI+0x178/0x18c)
- [ 1.792794] [<b010e31c>] (handle_IPI) from [<b03c0ab4>] (gic_handle_irq+0x74/0x78)
- [ 1.793478] [<b03c0ab4>] (gic_handle_irq) from [<b0101a78>] (__irq_svc+0x58/0x8c)
- [ 1.794151] Exception stack(0xb0d01f10 to 0xb0d01f58)
- [ 1.794615] 1f00: 00000000 00000eac eef8950c b011a880
- [ 1.795349] 1f20: b0d00000 b0d08c70 b0d08cac 00000001 00000000 00000000 b0c505f0 b0d01f68
- [ 1.796081] 1f40: 00000002 b0d01f60 b0108990 b0108994 60000013 ffffffff
- [ 1.796686] [<b0101a78>] (__irq_svc) from [<b0108994>] (arch_cpu_idle+0x38/0x3c)
- [ 1.797361] [<b0108994>] (arch_cpu_idle) from [<b014e620>] (do_idle+0x1c0/0x29c)
- [ 1.798034] [<b014e620>] (do_idle) from [<b014e9cc>] (cpu_startup_entry+0x18/0x1c)
- [ 1.798719] [<b014e9cc>] (cpu_startup_entry) from [<b0c00d84>] (start_kernel+0x490/0x4ac)
- [ 1.799459] [<b0c00d84>] (start_kernel) from [<00000000>] ( (null))
- [ 1.800033] CPU1: stopping
- [ 1.800291] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.19.111 #2
- [ 1.800951] Hardware name: Generic DT based system
- [ 1.801405] [<b010f408>] (unwind_backtrace) from [<b010b970>] (show_stack+0x10/0x14)
- [ 1.802100] [<b010b970>] (show_stack) from [<b0855524>] (dump_stack+0x90/0xa4)
- [ 1.802749] [<b0855524>] (dump_stack) from [<b010e31c>] (handle_IPI+0x178/0x18c)
- [ 1.803421] [<b010e31c>] (handle_IPI) from [<b03c0ab4>] (gic_handle_irq+0x74/0x78)
- [ 1.804104] [<b03c0ab4>] (gic_handle_irq) from [<b0101a78>] (__irq_svc+0x58/0x8c)
- [ 1.804765] Exception stack(0xee8cbf58 to 0xee8cbfa0)
- [ 1.805227] bf40: 00000000 00000464
- [ 1.805963] bf60: eef9850c b011a880 ee8ca000 b0d08c70 b0d08cac 00000002 00000000 00000000
- [ 1.806698] bf80: b0c505f0 ee8cbfb0 00000000 ee8cbfa8 b0108990 b0108994 60000013 ffffffff
- [ 1.807437] [<b0101a78>] (__irq_svc) from [<b0108994>] (arch_cpu_idle+0x38/0x3c)
- [ 1.808110] [<b0108994>] (arch_cpu_idle) from [<b014e620>] (do_idle+0x1c0/0x29c)
- [ 1.808783] [<b014e620>] (do_idle) from [<b014e9cc>] (cpu_startup_entry+0x18/0x1c)
- [ 1.809463] [<b014e9cc>] (cpu_startup_entry) from [<001023cc>] (0x1023cc)
- [ 1.810070] PMU CRU:
- [ 1.810289] 00000000: 00000001 00000000 00000000 00000000 00002063 00001441 00000000 00000007
- [ 1.811060] 00000020: 00007f00 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.811829] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.812599] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.813368] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.814137] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.814906] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.815677] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.816448] 00000100: 00000100 0000000b 0000000b 0000000b 00000800 00000000 00000000 0000e3f1
- [ 1.817220] 00000120: 00000000 0000000b 00000000 00000000 00000005 0040b71b 00000000 00000000
- [ 1.817990] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.818761] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.819533] 00000180: 00000060 00000081 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.820302] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.821070] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.821840] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.822609] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.823378] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.824140] 00000240: 00040020 00000000
- [ 1.824486] CRU:
- [ 1.824678] 00000000: 00004064 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
- [ 1.825449] 00000020: 0000404d 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
- [ 1.826221] 00000040: 0000607d 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
- [ 1.826991] 00000060: 0000215e 00001443 00000000 00000007 00007f00 00000000 00000000 00000000
- [ 1.827762] 00000080: 00000000 00000000 00000000 00000000 00000055 00000000 00000000 00000000
- [ 1.828535] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.829305] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.830074] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.830845] 00000100: 00000580 00000013 00000540 0000050b 00000105 00000b0b 00000b0b 00000707
- [ 1.831616] 00000120: 0000000b 00000000 00000800 00000000 00000800 00000000 00000800 00000000
- [ 1.832386] 00000140: 00000800 00000000 00000800 00000000 00000017 00000000 00000000 00000000
- [ 1.833156] 00000160: 00000000 00000205 00000007 00000b0b 00000000 00000000 0000014f 00001305
- [ 1.833926] 00000180: 00000000 0000070b 00000000 00000003 0000000b 00000000 00000000 00000000
- [ 1.834697] 000001a0: 00004183 00000101 00008382 00008183 00000183 00000103 00000102 00000106
- [ 1.835468] 000001c0: 00000000 00000101 00000101 00000703 00000000 00000503 00004203 0000801d
- [ 1.836239] 000001e0: 00000002 00000002 0000800b 0000000e 00000000 00001309 00000000 00000103
- [ 1.837009] 00000200: 0000000b 00000055 00000701 00000055 00000501 00000101 00000000 00000000
- [ 1.837780] 00000220: 0000000b 00000007 00000000 00000000 00000101 00000101 00000000 00000000
- [ 1.838551] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.839322] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.840084] 00000280: 00000000 00000000 00000000 0000043c 00001833 00009909 00000009 00000000
- [ 1.840853] 000002a0: 00000000 00000000 00000000 00000000 00000182 00000000 00000000 00000800
- [ 1.841623] 000002c0: 00000073 00000000 00000000 00002000 00000000 00000000 00000000 00000000
- [ 1.842394] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.843164] 00000300: 00000000 00000000 00000400 00000000 00000000 00000000 00000000 00000000
- [ 1.843935] 00000320: 00000000 00000000 00000000 00000000 00001000 00000000 00000000 00000000
- [ 1.844707] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.845477] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.846249] 00000380: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.847018] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.847790] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.848566] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.849340] 00000400: 00640064 00000000 00000000 00000000 00001101 00000000 00000000 00000000
- [ 1.850110] 00000420: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.850881] 00000440: 00000004 00000000 00000004 00000000 00000004 00000000 00000000 00000000
- [ 1.851650] 00000460: 00000032 00000094 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.852420] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.853191] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.853961] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.854731] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.855502] 00000500: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.856273] 00000520: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
- [ 1.857043] 00000540: 00040020 00000000 00040020 00000000 00040020 00000000 00000000 00000000
- [ 1.857815] 00000560: 00000000 00000000 00040020 00000000 00040020 00000000 00040020 00000000
- [ 1.858578] 00000580: 00040020 00000000
- [ 1.858929] CPU0 online:0
- [ 1.859184] PC: <0xb010e2bc> handle_IPI+0x118/0x18c
- [ 1.859658]
- [ 1.859805] CPU1 online:0
- [ 1.860058] PC: <0xb010e2bc> handle_IPI+0x118/0x18c
- [ 1.860528]
- [ 1.860675] CPU2 online:1
- [ 1.860932] PC: <0xb0411df8> rockchip_panic_notify+0xb4/0x114
- [ 1.861481]
- [ 1.861627] CPU3 online:0
- [ 1.861879] PC: <0xb010e2bc> handle_IPI+0x118/0x18c
- [ 1.862350]
- [ 1.862496] PMU:
- [ 1.862687] 00000000: 030a0000 0000000c 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.863458] 00000020: 000fffff 000fffff 000fffff 000fffff 000fffff 00000000 00005dc0 00005dc0
- [ 1.864231] 00000040: 00005dc0 00005dc0 00005dc0 000fffff 00000000 00000000 00000000 00000000
- [ 1.865000] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.865770] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.866539] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.867310] 000000c0: 00000100 00000010 00000000 00000000 00100100 00000000 00100100 00000000
- [ 1.868081] 000000e0: 0000ffff 0000ffff 00000000 00000000 00000000 00000000 00000000 00000000
- [ 1.873041] ---[ end Kernel panic - not syncing: Fatal exception ]---
Copy the code
This is my device tree overlay
- /dts-v1/;
- #include "rv1126.dtsi"
- #include "rv1126-evb-v12.dtsi"
- model = "Rockchip RV1109 V12 FACIAL GATE Board";
- compatible = "rockchip,rv1109-evb-ddr3-v12-facial-gate", "rockchip,rv1126";
- ovision,model = "OModule";
- ovision,version = "0.1";
- chosen {
- bootargs = "earlycon=uart8250,mmio32,0xff570000 console=ttyFIQ0 root=PARTUUID=614e0000-0000 rootfstype=ext4 rootwait snd_aloop.index=7";
- pwmleds {
- compatible = "pwm-leds";
- pwmi_ir {
- label = "PWM-IR";
- pwms = <&pwm11 0 25000 0>;
- max-brightness = <255>;
- vcc1v2_dvdd: vcc1v2-dvdd {
- compatible = "regulator-fixed";
- regulator-name = "vcc1v2_dvdd";
- regulator-min-microvolt = <1200000>;
- regulator-max-microvolt = <1200000>;
- vcc2v8_avdd: vcc2v8-avdd {
- regulator-name = "vcc2v8_avdd";
- regulator-min-microvolt = <2800000>;
- regulator-max-microvolt = <2800000>;
- &csi_dphy0 {
- status = "okay";
- ports {
- port@0 {
- mipi_in_ucam0: endpoint@1 {
- remote-endpoint = <&ucam_out0>;
- data-lanes = <1 2 3 4>;
- port@1 {
- csidphy0_out: endpoint@0 {
- remote-endpoint = <&mipi_csi2_input>;
- &csi_dphy1 {
- status = "okay";
- ports {
- port@0 {
- csi_dphy1_input: endpoint@1 {
- //remote-endpoint = <&ucam_out1>;
- port@1 {
- csi_dphy1_output: endpoint@0 {
- //remote-endpoint = <&isp_in>;
- &i2c1 {
- /delete-node/ ar0230@10;
- /delete-node/ os04a10@36;
- ov4689: ov4689@36 {
- compatible = "ovti,ov4689";
- reg = <0x36>;
- clocks = <&cru CLK_MIPICSI_OUT>;
- clock-names = "xvclk";
- power-domains = <&power RV1126_PD_VI>;
- pinctrl-names = "rockchip,camera_default";
- pinctrl-0 = <&mipicsi_clk0>;
- avdd-supply = <&vcc_avdd>;
- dovdd-supply = <&vcc_dovdd>;
- dvdd-supply = <&vcc_dvdd>;
- pwdn-gpios = <&gpio1 RK_PD4 GPIO_ACTIVE_HIGH>;
- reset-gpios = <&gpio1 RK_PD6 GPIO_ACTIVE_HIGH>;
- rockchip,camera-module-index = <1>;
- rockchip,camera-module-facing = "front";
- rockchip,camera-module-name = "JSD3425-C1";
- rockchip,camera-module-lens-name = "JSD3425-C1-36IRC-4M-F20";
- rockchip,camera-hdr-mode = <0>;
- port {
- ucam_out0: endpoint {
- remote-endpoint = <&mipi_in_ucam0>;
- /* isp cma buffer don't fiddle with it, dual camera(1920 * 1080) need 92M buffer */
- &isp_reserved {
- size = <0x20000000>;
- &mipi_csi2 {
- status = "okay";
- ports {
- port@0 {
- mipi_csi2_input: endpoint@1 {
- remote-endpoint = <&csidphy0_out>;
- port@1 {
- mipi_csi2_output: endpoint@0 {
- remote-endpoint = <&cif_mipi_in>;
- &pwm11 {
- status = "okay";
- pinctrl-names = "active";
- pinctrl-0 = <&pwm11m1_pins_pull_down>;
- &rk809 {
- regulators {
- vcc_dvdd: LDO_REG6 {
- regulator-min-microvolt = <1300000>;
- regulator-max-microvolt = <1300000>;
- vcc_avdd: LDO_REG7 {
- regulator-min-microvolt = <3300000>;
- regulator-max-microvolt = <3300000>;
- &rkcif_mipi_lvds {
- status = "okay";
- port {
- cif_mipi_in: endpoint {
- remote-endpoint = <&mipi_csi2_output>;
- &rkcif_mipi_lvds_sditf {
- status = "okay";
- port {
- cif_sditf: endpoint {
- remote-endpoint = <&isp_in>;
- &rkisp_vir0 {
- status = "okay";
- ports {
- port@0 {
- isp_in: endpoint@0 {
- remote-endpoint = <&csi_dphy1_output>;
- &rkisp_vir1 {
- status = "okay";
- ports {
- port@0 {
- reg = <0>;
- #address-cells = <1>;
- #size-cells = <0>;
- isp_virt1_in: endpoint@0 {
- reg = <0>;
- remote-endpoint = <&cif_sditf>;
- &rkispp_vir1 {
- status = "okay";
- &rkispp {
- status = "okay";
- /* the max input w h and fps of mulit sensor */
- //max-input = <1920 1080 30>;
- &backlight {
- pwms = <&pwm0 0 25000 0>;
- &pwm0 {
- status = "okay";
- &pwm3 {
- status = "disabled";
- &u2phy0 {
- vup-gpios = <&gpio0 RK_PC1 GPIO_ACTIVE_LOW>;
Copy the code
Please help! |
