[Hardware] 100% Pass Quiz VMware - Fantastic 2V0-17.25 - Free VMware Cloud Foundation 9.0 A
86
Hardware 100% Pass Quiz VMware - Fantastic 2V0-17.25 - Free VMware Cloud Foundation 9.0 A
Posted at 1/13/2026 16:17:32      View221 | Replies4        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of It-Tests 2V0-17.25 dumps for free: https://drive.google.com/open?id=1LZ40SEik_ch2S26OXADcdxlrEU1eXV4F
The advent of our VMware 2V0-17.25 study guide with three versions has helped more than 98 percent of exam candidates get the certificate successfully. Rather than insulating from the requirements of the VMware 2V0-17.25 Real Exam, our VMware 2V0-17.25 practice materials closely co-related with it. And their degree of customer's satisfaction is escalating.
We are benefiting more and more candidates for our excellent 2V0-17.25 exam materials which is compiled by the professional experts accurately and skillfully. We are called the best friend on the way with our customers to help pass their 2V0-17.25 exam and help achieve their dreaming certification. The reason is that we not only provide our customers with valid and reliable 2V0-17.25 study questions, but also offer best service online since we uphold the professional ethical.
Free 2V0-17.25 Practice offer you accurate Valid Exam Guide to pass VMware Cloud Foundation 9.0 Administrator examAfter you purchase our 2V0-17.25 study materials, we will provide one-year free update for you. Within one year, we will send the latest version to your mailbox with no charge if we have a new version of 2V0-17.25 learning materials. We will also provide some discount for your updating after a year if you are satisfied with our 2V0-17.25 Exam Questions. And if you find that your version of the 2V0-17.25 practice guide is over one year, you can enjoy 50% discount if you buy it again.
VMware Cloud Foundation 9.0 Administrator Sample Questions (Q39-Q44):NEW QUESTION # 39
An organization is integrating VMware vCenter with Active Directory (AD) to streamline user authentication. As part of this process, the administrator needs to add AD as an identity source in vCenter.
Which three steps must be performed to successfully add AD as an identity source? (Choose three.)
  • A. Select 'Identity Sources' and choose 'Active Directory Domain'.
  • B. Navigate to the vCenter Single Sign-On configuration in the vSphere Client.
  • C. Create an Active Directory object for the vCenter Server Appliance.
  • D. Configure DNS settings on all ESXi hosts to point to the AD DNS servers.
  • E. Enter the Domain Name and the credentials of an AD user with a minimum of read-only access to Base DN for users and groups.
  • F. Reboot the vCenter to apply the identity source settings.
Answer: A,B,E
You must provide the AD domain name plus credentials (read-only is sufficient) to bind and query the Base DN for users and groups.
In the vSphere Client's Identity Sources section, choose "Active Directory Domain" when adding a new source.
These options are found under Administration Single Sign-On Configuration Identity Sources in the vSphere Client.
NEW QUESTION # 40
An administrator needs to ensure that specific virtual machines within a VMware Cloud Foundation environment use storage that can tolerate at least two host failures. As resources are limited, the configuration should use the available resources as efficiently as possible.
Which three steps should be performed to configure a storage policy that meets the requirements?
(Choose three.)
  • A. Set Failures to Tolerate to "2 failures - RAID-1 (Mirroring)" in the policy configuration.
  • B. Apply the storage policy to the target VMs.
  • C. Configure the policy to use thin provisioning.
  • D. Reconfigure the existing Default Storage Policy in the vSphere Client.
  • E. Create a new VM Storage Policy in the vSphere Client.
  • F. Set Failures to Tolerate to "2 failures - RAID-6 (Erasure Coding)" in the policy configuration.
Answer: B,E,F
A new VM storage policy needs to be created in the vSphere Client to define specific requirements for the storage configuration, including tolerance for two host failures.
Once the storage policy is created, it must be applied to the specific virtual machines that require the storage configuration that tolerates two host failures.
To ensure the storage configuration tolerates two host failures efficiently, RAID-6 (Erasure Coding) is the appropriate choice. RAID-6 can tolerate two host failures while minimizing resource usage compared to other configurations like RAID-1.
NEW QUESTION # 41
Which two resources can be configured in a VM Class in VMware vSphere with vSphere Supervisor? (Choose two.)
  • A. Memory
  • B. PCI devices
  • C. Network interface
  • D. Storage
  • E. CPU
Answer: A,E
A VM Class predefines hardware for Supervisor-managed VMs: "The VM class... defines such parameters as the number of virtual CPUs, memory capacity, and reservation settings." Administration steps show these are configurable: "You can configure hardware resources such as CPU, memory, and different devices" when editing a VM class.
Additionally, the DCLI/API specification underscores CPU and Memory fields: "--cpu-count ... Required." and "--memory-mb ... Required." for a VM class.
While network adapters, PCI devices, and instance storage can also be added via advanced config, the question asks for two; CPU and Memory are canonical, always-present VM Class resources per the core definition above.
NEW QUESTION # 42
What is the impact of consolidating snapshots on a virtual machine?
  • A. It changes the VM's hardware compatibility settings.
  • B. It disconnects the VM from the network temporarily.
  • C. It temporarily increases the available disk space consumption on the datastore while merging data.
  • D. It reverts the VM to the state of the first snapshot taken.
When consolidating snapshots, the data from the snapshot files is merged back into the original virtual disk. This process temporarily increases the disk space usage on the datastore because of the additional space required to merge the snapshot data into the primary disk.
NEW QUESTION # 43
During a routine maintenance operation, an administrator needs to move a running VM from one host to another without downtime.
Which vSphere feature is used?
  • A. vMotion
  • B. vSphere Replication
  • C. Storage DRS
  • D. vRealize Orchestrator
vMotion enables live migration of a powered-on virtual machine from one ESXi host to another without service interruption.
NEW QUESTION # 44
The content of our 2V0-17.25 quiz torrent is imbued with useful exam questions easily appear in the real condition. We are still moderately developing our latest 2V0-17.25 exam torrent all the time to help you cope with difficulties. All exam candidates make overt progress after using our 2V0-17.25 Quiz torrent. By devoting ourselves to providing high-quality practice materials to our customers all these years, we can guarantee all content are the essential part to practice and remember. Stop dithering and make up your mind at once, 2V0-17.25 test prep will not let you down.
2V0-17.25 Valid Exam Guide: https://www.it-tests.com/2V0-17.25.html
As time is so precious, why do you still waver in your determination to buy our 2V0-17.25 guide torrent, You have no time to waste that your work is really busy and you want to finish 2V0-17.25 certification in the shortest time, VMware Free 2V0-17.25 Practice It is noteworthy that a logical review material can avoid doing useless work, We strongly recommend using our VMware 2V0-17.25 exam dumps to prepare for the VMware 2V0-17.25 certification.
This new edition extends to managing your career Latest Study 2V0-17.25 Questions and your management journey  it shows how the skills and rules of survival and success change at each level, Most enterprises 2V0-17.25 implement an internal Directory Services server that handles any internal requests.
Pass Guaranteed Quiz 2026 VMware 2V0-17.25: VMware Cloud Foundation 9.0 Administrator High Hit-Rate Free PracticeAs time is so precious, why do you still waver in your determination to buy our 2V0-17.25 Guide Torrent, You have no time to waste that your work is really busy and you want to finish 2V0-17.25 certification in the shortest time.
The VMware 2V0-17.25 PDF format can be used offline, and candidates can even prepare for it in the classroom or library by printing questions or on their smart devices.
BTW, DOWNLOAD part of It-Tests 2V0-17.25 dumps from Cloud Storage: https://drive.google.com/open?id=1LZ40SEik_ch2S26OXADcdxlrEU1eXV4F
Posted at 1/15/2026 06:23:07        Only Author  2#
The article was a breath of fresh air in terms of insight. We are offering Latest SIE exam pass4sure, full of valuable content, for free, hoping it proves helpful.
Posted at 2/20/2026 23:26:27        Only Author  3#
I cant stop thinking about that article. This Financial-Management review guide helped me get promoted and receive a salary increase. Now, its free for everyone. Wishing you success in your career journey!
Posted at 2/21/2026 09:26:59        Only Author  4#
ARDMS SPI시험이 정말 어렵다는 말을 많이 들으신 만큼 저희 Pass4Test는ARDMS SPI덤프만 있으면ARDMS SPI시험이 정말 쉬워진다고 전해드리고 싶습니다. ARDMS SPI덤프로 시험패스하고 자격증 한방에 따보세요. 자격증 많이 취득하면 더욱 여유롭게 직장생활을 즐길수 있습니다.
Posted at 3/7/2026 02:14:28        Only Author  5#
Your article is exceptional, thank you for sharing it with us! Here comes the Sales-101 Actual Test exam! Wish me luck and success!
