[General] Accessing CAM-C1126S2U
32
General Accessing CAM-C1126S2U
Posted at 8/18/2022 22:44:24      View3933 | Replies9        Print      Only Author   [Copy Link] 1#
Hello all,
I purchased a CAM-C1126S2U. When I connect the device to my USB port I find the usb ethernet module which is virtualized by RNDIS. I set static ip to that interface as 172.16.110.2 and check it using ifconfig.
When I try to ping the device itself 172.16.110.1 there is no response. Either there is no page shown when the same ip address is entered to the browser.
I am following the wiki page here: https://wiki.t-firefly.com/en/CAM-C11262U/usage.html#adb-debug
How can I access the device?
Posted at 8/19/2022 14:31:30        Only Author  2#
Device IP address: 172.16.110.2 (172.16.110.6)
Host(Your PC) IP address: 172.16.110.1  not 172.167.110.2
Posted at 8/31/2022 14:01:05        Only Author  3#
Hello thanks for the answer.
I was able to ping 172.16.110.6 however when I try to hit web interface with the same IP a blank page is being loaded. Web UI is not showing as mentioned in wiki page that I have shared in beginning post. How can I access to web UI?
Posted at 11/9/2022 04:43:11        Only Author  4#
Hi, follow below steps:
1. As for FW, I was using latest "CAM_CRV1126_1109S2U_UVCC_GPT_20220113_1518-20221031T231709Z-001" - so check your host (Win or Linux) IP should be 172.16.110.1 and Cam dev kit should have address as 172.16.110.2. Also check that you have "adb" working.
2. Download "ArcFaceGo_RV1109_App.zip" from Resources,
3. Unzip it on your host machine and depending your OS choose .cmd or .sh executable script (your Cam should be connected to your host machine at this moment),
4. Script will create two separate instances in two directories: GO and Server,
5. Follow the instruction from "Reame.docx" (translate it if needed) and initialize both instances in sequence as it is in instruction. Restart may be needed - I don't remember exactly
6. Type in browser 172.16.110.6 and you should see Welcome screen and request for setting new access credentials - in chinese
7. To start working with this app you need to authorize it by exporting ID file choosing from menu and sending to authors, they will send you back license key to import into app. I was too lazy and didn't pass this step
8. The End - Enjoy
Posted at 11/15/2022 14:48:03        Only Author  5#
I have follow the instruction and setup the camera as AI_UVC, it's working good when connected to Windows 10. But when I connect the camera to Android 11 Box using USB 3.0 port, it is not working, and it is display an error message as attached file. Please help me with this.
Posted at 11/7/2025 13:28:01        Only Author  6#
Choosing Examstrack for your 400-007 preparation represents a strategic investment in your professional development and networking career trajectory. The platform offers reliable, current, and well-structured resources that help you master the exam content efficiently and effectively. By utilizing these comprehensive preparation materials, you're not merely studying to pass an examinationyou're building the specialized expertise required to excel as a Cisco Certified Internetwork Expert and contribute to the design and implementation of sophisticated enterprise network solutions. Trust Examstrack to guide you toward achieving your certification goals and advancing your career to the highest levels of networking excellence.
Achieve CCDE Certification with Examstrack at >>>>> https://www.examstrack.com/cisco-dumps/400-007-exam
Posted at 1/10/2026 03:39:15        Only Author  7#
Your article is absolutely brilliant, thank you for sharing! I used the New C-THR70-2505 exam simulator to get promoted and raise my salary. Its now free for everyone. Best of luck with your career goals!
Posted at 1/11/2026 08:18:51        Only Author  8#
The article was so wonderful; it was truly astonishing! Free access to the 1z1-809 valid study guide ppt exam resourcesyour pathway to promotions and salary boosts!
Posted at 1/29/2026 10:02:55        Only Author  9#
I found the article very inspiring, thanks for the share! I advanced with the H12-841_V1.5 valid study questions sheet, earning both a promotion and salary increase. Now, its free for everyone. Best wishes to all!
Posted at 1/30/2026 12:26:19        Only Author  10#
Ĥ⤢ʤߤC-S4CPB-2508JԇYvBԇYο뤨뤿ˡTopexamϳˆ}|Ƥä¤ԇYΥХˏꤸƆ}¤ƤޤFڤЈǤϡTopexamϤʤ褤xkǤLgˤ錄äơTopexam϶यYJɤޤ˽ŤƤʤʤ顢ܤˡ„ƤߤƤ⤤ǤTopexamԇY}äȤˤäȤޤ顣TopexamԇYC-S4CPB-2508οṩƤʤԇY˺ϸ񤵤뤳Ȥ^ޤ
