[Linux] E: Unable to locate package issue
86
Linux E: Unable to locate package issue
Posted at 8/23/2022 09:02:28      View3492 | Replies7        Print      Only Author   [Copy Link] 1#
I'm trying to install the 'stressapptest' pkg.
but the error occurred like as below.
firefly@firefly:~$ sudo apt-get install stressapptest
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package stressapptest
So, I tried something as below cmd but the result was same.
firefly@firefly:~/proj$ sudo apt update
firefly@firefly:~/proj$ sudo add-apt-repository universe
firefly@firefly:~/proj$ sudo add-apt-repository multiverse
How can I solve this problem ?
Posted at 8/23/2022 09:45:30        Only Author  2#
It is not a problem. Just because Ubuntu have no stressapptest for arm64, so you can't find it
check the link:
https://packages.ubuntu.com/sear ... &searchon=names
Ubuntu only provides amd64 version
So you have to build stressapptest from source, but i seem to remember firefly firmware already come with the stressapptest
Posted at 8/23/2022 11:03:17        Only Author  3#
You mean that 'stressapptest' is already installed on the firefly Ubuntu ?
Posted at 8/23/2022 11:30:22        Only Author  4#
OK Thanks a lot.
I have checked it works well.
Posted at 1/10/2026 17:41:27        Only Author  5#
This article has provided me with many valuable insights. Im sharing the Latest AANP-FNP exam vce free test that got me my promotion and pay raise. Its available to you for free todaybest of luck with your career ambitions!
Posted at 1/23/2026 03:10:22        Only Author  6#
1Y0-342}Ʒ|_ᡢΆ}Ϥʤ˺Ϥɤ_J뤳ȤǤ褦ˡTopexam1Y0-342}һΥ`ɤoϤṩޤĤΥЩ`ΤɤǤ`ɤǤޤ顢TopexamΥȤǗƥ`ɤ뤳ȤǤޤYƤُ뤹뤫ɤQƤȡ1Y0-342}Ʒ|֪ʤޤޤˆ}ُ뤷Ƥڤˤʤ뤳Ȥܤ뤳ȤǤޤ
Posted at 2/21/2026 04:29:48        Only Author  7#
Thank you for your article, it really broadened my horizons! Wishing you success! Here are the free 1Y0-342 relevant answers resources for you!
Posted at 3/5/2026 08:42:14        Only Author  8#
Wenn man an sich glaubt, kann man wirklich was erreichen. Der Grund, warum Fast2test jedem IT-Fachmann helfen kann, liegt in seiner Fähigkeit. Die Prfungsmaterialien zur UiPath UiAAAv1 Zertifizierung von Fast2test können Ihnen zum Erfolg verhelfen. Jede Beschränkung fängt im Herzen an. Wenn Sie die UiPath UiAAAv1 Prfung bestehen wollen, werden Sie Fast2test wählen. Eigentlich ist die Distanz zwischen Erfolg und Niederlage nicht weit. Fast2test fhrt Sie zum Erfolg.
