[Android] GT9271 Interface with AIO3399J
79
Android GT9271 Interface with AIO3399J
Posted at 8/30/2022 14:22:39      View5082 | Replies7        Print      Only Author   [Copy Link] 1#
Hi,
I am using AIO-3399J EVK and want to connect Goodix GT9271sensors to I2C4. I did the below changes in DTS files and build the code but when I checked dmesg
log no entry for gt9721 or goodix is found.
gt9271_ts2: gt9271@5d {
            compatible = "goodix,gt9271";
            reg = <0x5D>;
            interrupt-parent = <&gpio4>;
            interrupts = <27 0>;
            irq-gpios = <&gpio4 27 0>;
            reset-gpios = <&gpio0 12 0>;
            touchscreen-size-x = <1280>;
            touchscreen-size-y = <800>;
Any Suggestions on what extra I need to do to make it work?
NOTE : = >
I am trying to use i2cdetect command to debug I2C issue but it gives an error saying -
i2c detect not found.
I also tried to use sudo also but sudo also not working.
I tried to use su but su also not working.
EVK - AIO-3399J
BSP - Andriod 7.1 from firefly
Command - rk3399_firefly_aio_lvds_box_userdebug
Any suggestion on how I can enable i2c detect in BSP ?
And What changes do I need to make GT9271 work.
Posted at 8/31/2022 09:23:43        Only Author  2#
I guess you probably forgot to turn on the relevant config.
Posted at 9/1/2022 14:41:46        Only Author  3#
895816513 Posted at 8/31/2022 09:23
Hi,
Thanks for your response.can you suggest what config I need to do?
I did changes for GT9271 on I2C4 and using i2C detect able to see its device address.
But when I checked -
dmesg | grep i2c
dmesg | grep gt9271
dmesg | grep goodix
But no log is available for my GT9271 or goodix driver and it is not loading.
Any suggestion on what steps I need to do ?
Thanks
Posted at 10/11/2022 11:55:58        Only Author  4#
You can check whether the driver is really compiled and whether there is a corresponding. o file.
Posted at 10/11/2022 11:57:23        Only Author  5#
You can use the i2c tools tool to view the device address, but I see your information that the driver is not compiled or does not match the device tree.
Posted at 10/1/2025 12:47:24        Only Author  6#
Hey, this GT9271 integration sounds like quite the puzzle! Debugging low-level issues is tricky, but I'm sure you'll crack it. Speaking of tracking things, a good BMI Calculator is super useful for keeping tabs on personal health goals. Good luck!
Posted at 1/11/2026 12:39:45        Only Author  7#
Thank you for bringing such a soul-stirring piece of content! The PMI-CPMAI detailed study plan resources are excellent, and theyre available to you free of charge.
Posted at 2/28/2026 23:40:55        Only Author  8#
Just saw that 'Slider validation: Verification succeeded!' note in the Firefly forum post-makes me think of how precise tools matter, like when I use the forge calculator roblox to plan my game upgrades during coffee breaks. Its wild how a tiny detail in tech or a game calc can save so much hassle, right?
