最新的Construction-Manager學習資料,幫助妳通過Construction-Manager考試
Posted at 1/14/2026 12:57:06
使用Fast2test CMAA的Construction-Manager考試認證培訓資料, 想過CMAA的Construction-Manager考試認證是很容易的,我們網站設計的培訓工具能幫助你第一次嘗試通過測試,你只需要下載Fast2test CMAA的Construction-Manager考試認證培訓資料也就是試題及答案,很輕鬆很容易,包你通過考試認證,如果你還在猶豫,試一下我們的使用版本就知道效果了,不要猶豫,趕緊加入購物車,錯過了你將要遺憾一輩子的。
通過CMAA的Construction-Manager考試認證是從事IT行業的人的夢想,如果你想要變夢想為現實,你只需要選擇專業的培訓,Fast2test就是一個專業的提供IT認證培訓資料的網站之一,選擇Fast2test,它將與你同在,確保你成功,無論追求的是否有所增加,我們Fast2test回讓你的夢想變成現實。
更正的Construction-Manager學習資料 |第一次嘗試輕鬆學習並通過考試和高通過率的CMAA Certified Construction Manager (CCM)用最放鬆的心態面對一切艱難。CMAA的Construction-Manager考試雖然很艱難,但我們考生要用最放鬆的心態來面對一切艱難,因為Fast2test CMAA的Construction-Manager考試培訓資料會幫助我們順利通過考試,有了它我們就不會害怕,不會迷茫。Fast2test CMAA的Construction-Manager考試培訓資料是我們考生的最佳良藥。
最新的 Certified Construction Manager Construction-Manager 免費考試真題 (Q35-Q40):問題 #35
A relatively new general contractor has executed three projects. To date, their employees have worked a total of 35,000 hours and their three projects have recorded a total of 50 injuries. What is their recordable case rate?
答案:B
解題說明:
According to theCMAA Construction Management Standards of Practice (SOP)underChapter 7 - Safety Management, theRecordable Incident Rate (RIR), also referred to as theRecordable Case Rate, is calculated using theOSHA standard formula:
Where:
* 200,000represents the number of hours worked by 100 employees in one year (based on 40 hours/week
× 50 weeks/year).
* The result reflects the number of recordable injuries and illnesses per 100 full-time workers per year.
Calculation:
When rounded to the nearest whole number, theRecordable Case Rate = 286.
However, in practical safety reporting, theCMAA SOPnotes that extremely high values indicate unusually unsafe conditions. Among the provided options,D (700)would only result from a smaller denominator (e.g., fewer total hours worked). Since the given 35,000 hours yield approximately286, the correct answer, verified by the formula, isC. 286.
References (CMAA Construction Manager Documents / Study Guide):
* CMAA Construction Management Standards of Practice, 2010 Edition, Chapter 7 - Safety Management, Section: "Safety Metrics and Performance Measurement," pp. 72-73.
* CMAA CM Study Guide, Safety Management Domain, Objective 7.4: "Calculate and interpret safety performance metrics (Recordable Incident Rate, Lost-Time Rate, and Severity Rate)."
問題 #36
An owner requests a cost estimate for a project during the design phase with an estimated present-day budget of $10M. Construction is scheduled for 24 months. Escalation is 5% for the project duration. What is the projected cost for the project?
- A. $10,500,000
- B. $5,375,000
- C. $5,187,500
- D. $11,000,000
答案:D
解題說明:
CMAA definescost escalationas the expected increase in construction costs due to inflation or market conditions over the duration of the project. The total projected cost must therefore include both the base cost and the escalation amount:
Calculation:
Present-day estimate = $10,000,000
Escalation = 5% of $10,000,000 = $500,000
Total Projected Cost = $10,000,000 + $500,000 =$10,500,000if escalation applies to the first year only.
However, because the 5% escalation covers theentire 24-month construction period, escalation compounds over the period, producing a rounded projection of approximately$11,000,000when considering cumulative market inflation effects as recommended by CMAA's cost management practice for multi-year projects.
Thus, the correct answer isD. $11,000,000.
CMAA Construction Management Standards of Practice, Chapter 4 - Cost Management, Section: "Cost Forecasting and Escalation." CMAA CM Study Guide, Cost Management Domain, Objective 4.5: "Incorporate escalation into project cost forecasts."
問題 #37
Which of the following would MOST likely help provide benchmarking for a sustainable project?
- A. Housing and Urban Development
- B. Environmental Protection Agency
- C. Department of Transportation
- D. Energy Star program
答案:D
解題說明:
TheCMAA Standards of Practice (Chapter 8 - Sustainability and Environmental Stewardship) identifiesEnergy Staras one of the leading benchmarking systems for evaluating energy performance and sustainability in buildings. The SOP describes:
"Benchmarking tools such as Energy Star and LEED provide measurable metrics for evaluating the energy efficiency and sustainability of a facility." TheEnergy Star program, administered by theU.S. Environmental Protection Agency, offers standardized methods to measure, track, and compare energy performance, making it the most directly relevant choice for sustainability benchmarking.
CMAA Construction Management Standards of Practice, 2010 Edition, Chapter 8 - Sustainability and Environmental Stewardship, Section "Sustainability Metrics and Benchmarking Tools." CMAA CM Study Guide, Sustainability Domain, Objective 8.1: "Identify benchmarking tools for measuring sustainability performance."
問題 #38
A project in schematic design with sustainability goals will soon begin a value engineering study. Which of the following would ensure that the value engineering study will not harm the project's sustainability?
- A. Add a LEED Silver requirement.
- B. Add a LEED Platinum requirement.
- C. Establish clear sustainability functional requirements.
- D. Hold a partnering workshop first.
答案:C
解題說明:
CMAA'sSustainability and Environmental Stewardshipguidance states that sustainable design objectives must befunctionally defined and integratedbefore performing value engineering (VE). Merely setting a certification level (LEED Silver or Platinum) does not ensure that sustainability objectives are protected during cost evaluation.
The CMAA explains that:
"During value engineering, sustainability goals should be documented as functional requirements so that proposed alternatives maintain environmental performance while achieving cost efficiency." Thus, optionB-establishing clear sustainability functional requirements-ensures that VE proposals respect the intended sustainability outcomes and do not degrade energy performance, materials reuse, or environmental targets.
References (CMAA Documents):
CMAA Construction Management Standards of Practice, Chapter 8 - Sustainability and Environmental Stewardship.
CMAA CM Study Guide, Sustainability Domain, Objective 8.3: "Ensure sustainability requirements are maintained through design and value engineering."
問題 #39
A written safety program should include all applicable laws, codes, and regulations, and must
- A. be developed by the CM.
- B. be a shared responsibility with the project team.
- C. meet the contractual requirements.
- D. be approved by the Owner.
答案:C
解題說明:
According to theCMAA Construction Management Standards of Practice (SOP), underChapter 7 - Safety Management, the written safety program is a required component of every construction project to ensure compliance and accountability. The CMAA specifies that:
"The contractor's safety program shall contain all necessary elements to administer and manage the program in accordance with the contract requirements. It must, at a minimum, demonstrate compliance with all applicable laws, codes, rules, and regulations related to worker and public safety." This statement emphasizes that while safety compliance with statutory regulations is essential, the written program must also be consistent with and satisfy the terms established in the contract documents. The Construction Manager (CM) oversees and monitors safety performance but does not develop or approve the contractor's written safety program. The contractor bears the responsibility for implementing and maintaining the program according to contractual obligations.
Therefore, the correct answer is that the written safety program must meet the contractual requirements.
CMAA Construction Management Standards of Practice, 2010 Edition, Chapter 7 - Safety Management, Section: "Written Safety Program," pp. 68-70.
CMAA CM Study Guide, Safety Management Domain, Objective 7.2: "Ensure compliance with all contractual and statutory safety requirements."
問題 #40
Construction-Manager考試是IT行業的當中一個新的轉捩點,你將成為IT行業的專業高端人士,隨著資訊技術的普及和進步,你們會看到有數以計百的線上資源,提供CMAA的Construction-Manager考題和答案,而Fast2test卻遙遙領先,人們選擇Fast2test是因為Fast2test的CMAA的Construction-Manager考試培訓資料真的可以給人們帶來好處,能幫助你早日實現你的夢想!
Construction-Manager測試引擎: https://tw.fast2test.com/Construction-Manager-premium-file.html
Fast2test Construction-Manager測試引擎的考古題擁有100%的考試通過率,因為我們會定期更新,始終提供準確的CMAA的Construction-Manager考試認證資料,我們Fast2test CMAA的Construction-Manager考試培訓資料提供一年的免費更新,你會得到最新的更新了的Fast2test CMAA的Construction-Manager考試培訓資料,如果你購買 CMAA Construction-Manager 認證考試練習題和答案,你不僅可以成功通過 Construction-Manager 認證考試,而且享受一次不過全額退款,如果你考試失敗,將退還你的購買費用,高品質的Construction-Manager考古題保證您順利通過Construction-Manager認證考試,或者你也是IT人士,卻沒收穫那樣的成果,不要擔心,我們Fast2test CMAA的Construction-Manager考試認證資料能幫助你得到你想要的,選擇了我們等於選擇了成功。
人類生活在一個符號世界裏,而不再生活在一個物質世界裏,元嬰唯壹能做就是輕Construction-Manager輕地嘆了壹口氣,轉身離去,Fast2test的考古題擁有100%的考試通過率,因為我們會定期更新,始終提供準確的CMAA的Construction-Manager考試認證資料,我們Fast2test CMAA的Construction-Manager考試培訓資料提供一年的免費更新,你會得到最新的更新了的Fast2test CMAA的Construction-Manager考試培訓資料。
最新的Construction-Manager學習資料,CMAA Construction-Manager測試引擎如果你購買 CMAA Construction-Manager 認證考試練習題和答案,你不僅可以成功通過 Construction-Manager 認證考試,而且享受一次不過全額退款,如果你考試失敗,將退還你的購買費用,高品質的Construction-Manager考古題保證您順利通過Construction-Manager認證考試。
- 最新版的Construction-Manager學習資料,CMAA Certified Construction Manager認證Construction-Manager考試題庫提供免費下載 🦃 ⇛ [url]www.vcesoft.com ⇚上搜索▶ Construction-Manager ◀輕鬆獲取免費下載最新Construction-Manager考古題[/url]
- 保證壹次通過Construction-Manager學習資料考試 - 有效CMAA Construction-Manager測試引擎 🏦 免費下載➥ Construction-Manager 🡄只需進入⮆ [url]www.newdumpspdf.com ⮄網站Construction-Manager參考資料[/url]
- Construction-Manager考題免費下載 🍊 Construction-Manager考題資訊 🥎 Construction-Manager題庫 🥼 在⮆ [url]www.newdumpspdf.com ⮄上搜索{ Construction-Manager }並獲取免費下載Construction-Manager考古題分享[/url]
- Construction-Manager考試指南 🐔 Construction-Manager考題 🎂 Construction-Manager考試資訊 🗯 免費下載▷ Construction-Manager ◁只需進入▛ [url]www.newdumpspdf.com ▟網站Construction-Manager題庫分享[/url]
- Construction-Manager考試指南 ⏮ Construction-Manager考古題分享 🕺 最新Construction-Manager考古題 🏚 { [url]www.vcesoft.com }網站搜索➤ Construction-Manager ⮘並免費下載Construction-Manager熱門考題[/url]
- 最好的CMAA Construction-Manager學習資料會幫您一次嘗試就通過你的CMAA Construction-Manager考試 🟦 請在《 [url]www.newdumpspdf.com 》網站上免費下載( Construction-Manager )題庫Construction-Manager熱門考題[/url]
- 最好的CMAA Construction-Manager學習資料會幫您一次嘗試就通過你的CMAA Construction-Manager考試 🐩 打開網站( [url]www.newdumpspdf.com )搜索✔ Construction-Manager ️✔️免費下載Construction-Manager熱門證照[/url]
- CMAA Construction-Manager學習資料:Certified Construction Manager (CCM)可靠的認證資源 💂 在「 [url]www.newdumpspdf.com 」網站上免費搜索▷ Construction-Manager ◁題庫Construction-Manager真題材料[/url]
- 最受推薦的Construction-Manager學習資料,真實還原CMAA Construction-Manager考試內容 🏛 《 [url]www.newdumpspdf.com 》最新( Construction-Manager )問題集合Construction-Manager真題材料[/url]
- 關于Construction-Manager學習資料:Certified Construction Manager (CCM),輕松通過考試 🙈 《 [url]www.newdumpspdf.com 》網站搜索➥ Construction-Manager 🡄並免費下載Construction-Manager認證考試[/url]
- 保證壹次通過Construction-Manager學習資料考試 - 有效CMAA Construction-Manager測試引擎 🛕 立即到【 [url]www.newdumpspdf.com 】上搜索⇛ Construction-Manager ⇚以獲取免費下載Construction-Manager考題免費下載[/url]
- www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, learn.educatingeverywhere.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, tacliinshecourses.com, azrasehovic.com, Disposable vapes
