Free PDF 2026 Salesforce Arch-303: Salesforce Certified B2C Commerce Architect U
Posted at 1/14/2026 16:35:25
Salesforce certification Arch-303 exam has become a very popular test in the IT industry, but in order to pass the exam you need to spend a lot of time and effort to master relevant IT professional knowledge. In such a time is so precious society, time is money. Exams4sures provide a training scheme for Salesforce Certification Arch-303 Exam, which only needs 20 hours to complete and can help you well consolidate the related IT professional knowledge to let you have a good preparation for your first time to participate in Salesforce certification Arch-303 exam.
As is known to us, the Arch-303 Certification has been increasingly important for a lot of modern people in the rapid development world. Why is the Arch-303 certification so significant for many people? Because having the certification can help people make their dreams come true, including have a better job, gain more wealth, have a higher social position and so on. We believe that you will be fond of our products.
100% Pass Quiz 2026 Arch-303: Salesforce Certified B2C Commerce Architect Useful Online Lab SimulationAfter you pass the test Arch-303 certification, your working abilities will be recognized by the society and you will find a good job. If you master our Arch-303 quiz torrent and pass the exam. You will be respected by your colleagues, your boss, your relatives, your friends and the society. All in all, buying our Arch-303 Test Prep can not only help you pass the exam but also help realize your dream about your career and your future. So don't be hesitated to buy our Arch-303 exam materials and take action immediately.
Salesforce Certified B2C Commerce Architect Sample Questions (Q38-Q43):NEW QUESTION # 38
The Client currently manages Customers, Inventory, and Product Information with dedicated backend systems as shown In the Systems Diagram below. There is also an external Email Marketing System (EMS) in place.
The EMS needs order data to email recommendations to customers using an existing email campaign. These recommendations should be to only send for products that are in stock. The EMS has no access to the backend systems so this data should come from the Salesforce B2C Commerce site.
Which relationships should be added to the Systems Diagram to complete it and fulfill the chant requirements necessary for the email campaign?
- A. Order and Customer data should be exported from Production. Product and Inventory data should be exported from Staging.
- B. Order, Customer, and Inventory data should be exported from Production. Product data should be exported from staging.
- C. Order andInventory should be exported from Production. Products should be exported from Staging.Customers should be exported from the external Customer Management System.
- D. Order, Customer, and Product data should be exported from Staging. Inventory data should be exported from Production.
In the given scenario, where the Email Marketing System (EMS) requires order data to send product recommendations based on stock availability, it is crucial that the most up-to-date and relevant data is used.
Here's why the chosen data sources are appropriate:
* Order and Customer Data from Production: Since order and customer interactions occur in real- time, exporting this data from the Production environment ensures that the most current information is used for the email marketing campaigns. This accuracy is vital for personalization and timeliness of the communications sent to customers.
* Product and Inventory Data from Staging: Given that the staging environment is typically one step behind production and is used for testing before changes go live, it provides a stable dataset that reflects what is currently live without the risk of including any unvetted changes. This setup is suitable for inventory and product data, which are less susceptible to minute-by-minute changes compared to order data and can be pre-validated before use in marketing efforts.
This configuration helps ensure that the EMS has access to reliable data reflecting current stock levels and product details, which is essential for crafting accurate marketing messages based on product availability.
NEW QUESTION # 39
A new project for a Client will involve a few different Integrations to their middleware system resulting in four different web services. All will use the same credentials to the middleware. Each will have the same timeout, but will require a separate log file prefix.
How should the Architect set this up with the Service framework using a minimal set of configuration?
- A. Four Service Configurations. Four Service Profiles, One Service Credential
- B. One Service Configuration, Four Service Profiles, One Service Credential.
- C. Four Service Configurations. Four Service Profiles, Four Service Credentials
- D. Four Service Configurations. One Service Profile, One Service Credential.
For setting up multiple integrations that require the same credentials and timeout settings but need separate log file prefixes:
* Four Service Configurations are needed to specify the unique endpoint and other specifics for each of the four web services.
* One Service Profile can be used for all these configurations because they share the same timeout and other settings, optimizing the configuration process.
* One Service Credential is sufficient since all services authenticate with the same credentials, simplifying credential management and security handling.
This setup reduces redundancy and complexity in the service framework, ensuring a streamlined and efficient integration process while meeting all specified requirements.
NEW QUESTION # 40
An Architect is configuring a data replication schedule.
Which task(s) can be removed In order to reduce replication times?
- A. Search Indexes
- B. Storefront URLs
- C. Campaign
- D. Static content
Reducing the replication times in data synchronization can be effectively achieved by removing or reducing frequency of tasks that are less critical or that do not change frequently. Static content, such as images and static texts that do not change often, can be safely removed from frequent replication schedules (Answer B).
This adjustment will reduce the data load and frequency of updates, thereby speeding up the overall replication process. Unlike dynamic content like campaigns, search indexes, or URLs that might change frequently and impact user experience or site functionality if not updated, static content does not typically necessitate immediate replication, making it a suitable candidate for removal to enhance replication efficiency.
NEW QUESTION # 41
The Client wants to offer custom made container products on its new B2C Commerce storefront. TheClient provided two business requirements.
* Customer can specify container length, width, and height.
* Customer can specify the material that the container is made of.
The Client also provided the Architect a current data schema (shown below) for reference while preparing the technical documentation.
Which two gaps between the requirements and the data schema should the Architect discuss with the Client?
Choose 2 answers
- A. The data schema includes a Color_ID field, but there isn't a business requirement to allow the customer to specify container color.
- B. The data schema includes an implied structure that the customer's choices should be captured as custom objects, but there isn't a business requirement to do so
- C. The data schema includes a material Price_Markup field, but there Isn't a business requirement to factor the material cost Into the final price calculation.
- D. The data schema includes unique identifiers for material and color fields,but neither are reflected in the business requirements.
Answer: A,D
The provided data schema includes several fields that do not match the stated business requirements, which focus on the custom dimensions and materials of the containers:
* Option A: The inclusion of unique identifiers for materials and color fields in the data schema suggests a level of detail and structure around these attributes that is not reflected in the business requirements. If the business does not require tracking or differentiating materials beyond just naming them, this might be unnecessarily complex.
* Option D: The data schema includes a Color_ID field, which implies the ability to specify the color of the container. However, the business requirements do not mention color as a customization option available to customers. This discrepancy needs to be addressed to ensure that the database design aligns with actual business needs.
NEW QUESTION # 42
The Client is Crowing and decided to migrate its ecommerce website to B2C Commerce. The Client provided the Architect with the f metrics for its existing website over the past 12 months and forecasted into the next year:
Noting these historical metrics and the forecasted growth of 300%, which load test targets meet best practices for testing the new B2C Commerce site?
- A. 1500 visits per hour, 30000 page views per hour, and 375 orders per hour
- B. 150000 visits per hour, 3000000 page views per hour, and 37500 orders per hour
- C. 3000 visits per hour, 60000 page views per hour, and 750 orders per hour
- D. 15000 visits per hour, 300000 page views per hour, and 3750 orders per hour
Considering the existing metrics and forecasted 300% growth, the appropriate load testing targets for the new B2C Commerce site would be:
* 15000 visits per hour: This figure is calculated by applying the expected growth to the peak visits per hour (1000 visits), resulting in 4000 visits. The choice of 15000 provides a higher buffer to accommodate unforeseen spikes in traffic.
* 300000 page views per hour: Similarly, this is scaled up from the peak page views per hour (20000) considering the growth, ensuring the site can handle high demand and interactions.
* 3750 orders per hour: This target is based on the peak orders per hour (250) with the growth applied, allowing testing of the system's ability to handle transactions under significant load.
These targets ensure that the system is robust enough to handle increased traffic and transactions without performance degradation, crucial for maintaining customer satisfaction and operational stability.
NEW QUESTION # 43
The Exams4sures is a reliable and trusted platform that is committed to making the Salesforce Certified B2C Commerce Architect (Arch-303) exam preparation instant, simple and successful. To do this the Exams4sures is offering top-rated and real Salesforce Certified B2C Commerce Architect (Arch-303) exam questions with high-in-demand features. These features are inclusively designed to ace the Salesforce Arch-303 exam preparation.
Arch-303 Exam Fees: https://www.exams4sures.com/Salesforce/Arch-303-practice-exam-dumps.html
Salesforce Arch-303 Online Lab Simulation By figuring out which kind of learner you are, this can influence the way in which you learn, and which approach to take to learning, Salesforce Arch-303 Online Lab Simulation What Terms our Dumps the Best, The high quality of Arch-303 valid torrent has helped many people achieve their dreams, Our Salesforce Arch-303 Exam Fees IT experts will check the update of all the Arch-303 Exam Fees dumps, if there is any update, we will send the latest dumps for you.
Filter data so you get the information you Arch-303 Exam Fees need quickly, An analytical or nonintuitive approach would miss the hidden dig, By figuring out which kind of learner you are, this Arch-303 can influence the way in which you learn, and which approach to take to learning.
2026 Arch-303 Online Lab Simulation Free PDF | Valid Arch-303 Exam Fees: Salesforce Certified B2C Commerce ArchitectWhat Terms our Dumps the Best, The high quality of Arch-303 valid torrent has helped many people achieve their dreams, Our Salesforce IT experts will check the update of all Reliable Arch-303 Test Experience the Salesforce Architect dumps, if there is any update, we will send the latest dumps for you.
You will be allowed to free update the Arch-303 test study material one-year after you purchase.
- Arch-303 Test Assessment 📈 New Arch-303 Real Test 🪔 Arch-303 Valid Dump 📋 The page for free download of ➽ Arch-303 🢪 on ⏩ [url]www.testkingpass.com ⏪ will open immediately 🔘New Arch-303 Study Notes[/url]
- How Good Is To Take Pdfvce Salesforce Arch-303 Practice Test Material? ❤️ 《 [url]www.pdfvce.com 》 is best website to obtain “ Arch-303 ” for free download 🦑New Arch-303 Exam Fee[/url]
- Arch-303 Interactive Course 🍡 Clear Arch-303 Exam 🎆 Latest Arch-303 Dumps Files 😘 Easily obtain ➠ Arch-303 🠰 for free download through ▛ [url]www.exam4labs.com ▟ ⏭Arch-303 Valid Exam Book[/url]
- Reliable Arch-303 Exam Cram 🦼 New Arch-303 Real Test 🌅 Arch-303 Test Assessment 🧅 The page for free download of 「 Arch-303 」 on ☀ [url]www.pdfvce.com ️☀️ will open immediately 💅New Arch-303 Real Test[/url]
- Arch-303 Trustworthy Practice 🧲 Arch-303 Reliable Dumps Ppt 🏤 Arch-303 Valid Exam Cost 🎦 Search for 【 Arch-303 】 and download exam materials for free through ⮆ [url]www.easy4engine.com ⮄ 💥
ass Arch-303 Guide[/url] - New Arch-303 Study Notes 🎴 Arch-303 Valid Exam Cost 🧞 Latest Arch-303 Dumps Files 🖍 Search on ▶ [url]www.pdfvce.com ◀ for ☀ Arch-303 ️☀️ to obtain exam materials for free download ➖Arch-303 Reliable Dumps Ppt[/url]
- Well-Prepared Arch-303 Online Lab Simulation Spend Your Little Time and Energy to Pass Arch-303 exam casually 💞 Easily obtain free download of ⇛ Arch-303 ⇚ by searching on ⇛ [url]www.practicevce.com ⇚ 📑
ass Arch-303 Guide[/url] - [url=https://praha4.zeleni.cz/?s=How%20Good%20Is%20To%20Take%20Pdfvce%20Salesforce%20Arch-303%20Practice%20Test%20Material? 🌳 The page for free download of ▶ Arch-303 ◀ on ▷ www.pdfvce.com ◁ will open immediately 🌐Official Arch-303 Practice Test]How Good Is To Take Pdfvce Salesforce Arch-303 Practice Test Material? 🌳 The page for free download of ▶ Arch-303 ◀ on ▷ www.pdfvce.com ◁ will open immediately 🌐Official Arch-303 Practice Test[/url]
- 2026 Arch-303 – 100% Free Online Lab Simulation | Reliable Arch-303 Exam Fees 🌂 Simply search for ➡ Arch-303 ️⬅️ for free download on ( [url]www.prep4away.com ) 🙌Arch-303 Exam Engine[/url]
- Arch-303 Preparation Materials and Study Guide: Salesforce Certified B2C Commerce Architect - Pdfvce 📹 Go to website 「 [url]www.pdfvce.com 」 open and search for ➥ Arch-303 🡄 to download for free 🧩New Arch-303 Exam Vce[/url]
- Clear Arch-303 Exam 🃏 Arch-303 Valid Exam Cost 📪 Arch-303 Reliable Dumps Ppt 🍴 Search for 【 Arch-303 】 and download exam materials for free through 「 [url]www.vce4dumps.com 」 ↗Arch-303 Test Assessment[/url]
- www.stes.tyc.edu.tw, cobe2go.com, ycs.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
