[Hardware] Fortinet FCSS_SDW_AR-7.6 Certification Dumps, Reliable FCSS_SDW_AR-7.6 Test Ques
82
Hardware Fortinet FCSS_SDW_AR-7.6 Certification Dumps, Reliable FCSS_SDW_AR-7.6 Test Ques
Posted at 1/15/2026 00:41:55      View155 | Replies1        Print      Only Author   [Copy Link] 1#
Our FCSS_SDW_AR-7.6 training materials provide three different versions to the client and they include the PDF version, PC version, APP online version. Each versions using method and functions are different but the questions and answers of our FCSS_SDW_AR-7.6 Study Materials is the same. The client can decide which version of our FCSS_SDW_AR-7.6 exam questions to choose according their hobbies and their practical conditions.
The only aim of our company is to help each customer pass their exam as well as getting the important certification in a short time. If you want to pass your exam and get the FCSS_SDW_AR-7.6 certification which is crucial for you successfully, I highly recommend that you should choose the FCSS_SDW_AR-7.6 certification braindumps from our company so that you can get a good understanding of the exam that you are going to prepare for. We believe that if you decide to buy the FCSS_SDW_AR-7.6 Exam Materials from our company, you will pass your exam and get the certification in a more relaxed way than other people.
Save Money and Time with TestkingPass Fortinet FCSS_SDW_AR-7.6 Exam QuestionsOur FCSS_SDW_AR-7.6 Practice Materials are compiled by first-rank experts and FCSS_SDW_AR-7.6 Study Guide offer whole package of considerate services and accessible content. Furthermore, FCSS_SDW_AR-7.6 Actual Test improves our efficiency in different aspects. Having a good command of professional knowledge will do a great help to your life. With the advent of knowledge times, we all need some professional certificates such as FCSS_SDW_AR-7.6 to prove ourselves in different working or learning condition.
Fortinet FCSS - SD-WAN 7.6 Architect Sample Questions (Q79-Q84):NEW QUESTION # 79
Refer to the exhibits.
The exhibits show an SD-WAN event log, the member status, and the SD-WAN rule configuration.
Which two conclusions can you draw from the information shown? (Choose two.)
  • A. Port2 has a lower latency than port1.
  • B. The administrator configured the SD-WAN rule ID 1 with the default strategy mode.
  • C. The administrator configured the service ID 1 with the highest priority member for port2.
  • D. FortiGate updated the outgoing interface list on the rule so it prefers port2.
Answer: A,D
The SD-WAN rule (config service edit 1) is configured with set mode priority. This means the rule selects the best interface based on a defined performance metric, as opposed to a simple static priority or SLA. The event log (image_41cfb5.png) shows Metric latency and Message Service prioritized by performance metric will be redirected in sequence order. This indicates that the rule is using latency to determine the preferred member. Given that the log message is about a change, and the most logical reason for a change in a priority mode is that a different member is now the best performer, it implies that the latency on port2 has become lower than that on port1.
The log message Service prioritized by performance metric will be redirected in sequence order confirms that FortiGate is changing the member being used for this service. Because the mode is priority, FortiGate dynamically selects the member that currently meets the best performance criteria, which in this case is latency. The log implies a new member has been selected as the most optimal, and with the default configuration, the members are sorted based on their performance, so the outgoing interface list is effectively updated to prefer the new best-performing member (port2).
NEW QUESTION # 80
Refer to the exhibits. The exhibits show the configuration for SD-WAN performance. SD-WAN rule, the application IDs of Facebook and YouTube along with the firewall policy configuration and the underlay zone status. Which two statements are true about the health and performance of SD-WAN members 3 and 4? (Choose two.)
  • A. Encrypted traffic is not used for the performance measurement.
  • B. The performance is an average of the metrics measured for Facebook and YouTube traffic passing through the member.
  • C. FortiGate identifies the member as dead when there is no Facebook and YouTube traffic passing through the member.
  • D. Only related TCP traffic is used for performance measurement.
Based on the SD-WAN configuration exhibit for health checks and service with application IDs for Facebook (15832) and YouTube (31077) and health-check set to "Passive" mode for members 3 and 4, the following conclusions about the health and performance of SD-WAN members 3 and 4 are true:
The passive health-check mode measures performance based on real application traffic, which generally includes TCP traffic affecting the monitored applications.
The performance is an average of the metrics measured for Facebook and YouTube traffic passing through the member The configured service includes both Facebook and YouTube app IDs, and performance measurement aggregates data from these applications.
NEW QUESTION # 81
Refer to the exhibit. The administrator configured the SD-WAN rule ID 4 with two members (port1 and port2) and strategy lowest cost (SLA).
What are the two characteristics of the session shown in the exhibit? (Choose two.)
  • A. FortiGate steered this flow according to the application detected and the outgoing interface is port3.
  • B. FortiGate will never re-evaluate this session.
  • C. FortiGate will re-evaluate this session if the outgoing interface goes down.
  • D. FortiGate steered this flow according to an SD-WAN rule.
The line sdwan_mbr_seq=1 sdwan_service_id=4 indicates that this session is part of an SD-WAN rule. sdwan_service_id=4 confirms that the session is being handled by SD-WAN rule ID 4. This directly links the flow to the SD-WAN configuration.
The line no_offload_reason: redir-to-ips denied-by-nturbo shows that the session is not offloaded to the NPU (Network Processing Unit) and is being processed by the main CPU. A session that is not offloaded can be re-evaluated. If the outgoing interface (the one currently being used) goes down, the FortiGate will re-evaluate the session against the SD-WAN rules to find a new active member to steer the traffic through. This is a fundamental behavior of SD-WAN, which ensures network resilience.
NEW QUESTION # 82
The SD-WAN overlay template helps to prepare SD-WAN deployments. To complete the tasks performed by the SD-WAN overlay template, the administrator must perform some post-run tasks. What are two mandatory post-run tasks that must be performed? (Choose two.)
  • A. Assign an sdwan_id metadata variable to each device (branch and hub)
  • B. Configure routing through the overlay tunnels created by the SD-WAN overlay template.
  • C. Configure SD-WAN rules
  • D. Assign a hub id metadata variable to each hub device.
  • E. Create policy packages and assign them to the branch devices.
Answer: C,E
After using the SD-WAN overlay template, two mandatory post-run tasks remain:
"First, administrators must create and assign policy packages to branch devices, as security and access policies are not included in overlay templates. Second, SD-WAN rules must be configured so that traffic can be matched and steered appropriately through the established overlays. Neglecting either task results in ungoverned traffic or inefficient routing, undermining the benefits of SD-WAN." Templates automate topology, but policy and rule definition are critical for operational effectiveness.
[FCSS_SDW_AR-7.4 1-0.docx Q25]
Fortinet SD-WAN Reference Architecture 7.4, "Post-Deployment Tasks for SD-WAN Overlay Templates"
NEW QUESTION # 83
Refer to the exhibits, which show the configuration of an SD-WAN rule and the corresponding rule status and routing table.
The administrator wants to understand the expected behavior for traffic matching the SD-WAN rule.
Based on the exhibits, what can the administrator expect for traffic matching the SD-WAN rule?
  • A. The traffic will be routed over HUB1-VPN3.
  • B. The traffic will be load balanced across all three overlays
  • C. The traffic will be routed over HUB1-VPN1.
  • D. The traffic will be routed over HUB1-VPN2
The rule is in SLA mode with two SLAs. From the status, HUB1-VPN2 and HUB1-VPN3 meet the SLA (sla(0x2) and sla(0x3)), while HUB1-VPN1 does not (sla(0x0)). Among members that meet SLA, FortiGate uses the configured order (priority-members 4 5 6) to pick the first eligible one- HUB1-VPN2-so traffic is routed over HUB1-VPN2.
NEW QUESTION # 84
A certification is not only an affirmation to your ability but also can help you enter a better company and improve your salary. FCSS_SDW_AR-7.6 exam cram can help you get your certification successfully. We have a professional team to collect and research the latest information for the exam, and we offer you free update for 365 days after payment, so that you can obtain the latest information. In order to build up your confidence for FCSS_SDW_AR-7.6 Exam Braindumps, we are pass guarantee and money back guarantee if you fail to pass the exam.
Reliable FCSS_SDW_AR-7.6 Test Questions: https://www.testkingpass.com/FCSS_SDW_AR-7.6-testking-dumps.html
All you need to do is to take your time to practice our Reliable FCSS_SDW_AR-7.6 Test Questions - FCSS - SD-WAN 7.6 Architect test prep torrent and pay attention to new practices whenever the system sends you, Fortinet FCSS_SDW_AR-7.6 Certification Dumps Our responsible staff will be pleased to answer your questions whenever and wherever, So before choosing our FCSS_SDW_AR-7.6 training vce pdf, please take a look briefly about FCSS_SDW_AR-7.6 free pdf training with us together, But now I have to tell you that all of these can be achieved in our FCSS_SDW_AR-7.6 exam preparation materials.
Controlling How Tools Behave with the Options Bar, Import from Excel Ranges, FCSS_SDW_AR-7.6 All you need to do is to take your time to practice our FCSS - SD-WAN 7.6 Architect test prep torrent and pay attention to new practices whenever the system sends you.
Enhance Your Success Rate with TestkingPass's FCSS_SDW_AR-7.6 Exam DumpsOur responsible staff will be pleased to answer your questions whenever and wherever, So before choosing our FCSS_SDW_AR-7.6 training vce pdf, please take a look briefly about FCSS_SDW_AR-7.6 free pdf training with us together.
But now I have to tell you that all of these can be achieved in our FCSS_SDW_AR-7.6 exam preparation materials, First, you should have preview about the content of FCSS_SDW_AR-7.6 sure pass exam.
Posted at 1/18/2026 07:22:07        Only Author  2#
What a thought-provoking and inspiring read, thank you for sharing! MLA-C01 latest test tips offers outstanding content, all for free.
