[General] First-hand HP HPE7-A02 Exam Tests - HPE7-A02 Aruba Certified Network Security Pr
76
General First-hand HP HPE7-A02 Exam Tests - HPE7-A02 Aruba Certified Network Security Pr
Posted at 1/15/2026 03:53:55      View181 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE7-A02 dumps are available on Google Drive shared by Test4Engine: https://drive.google.com/open?id=14SPBaMsSuN4MPB3jtCqy0sl66nFQDUP-
An Aruba Certified Network Security Professional Exam (HPE7-A02) practice questions is a helpful, proven strategy to crack the HP HPE7-A02 exam successfully. It helps candidates to know their weaknesses and overall performance. Test4Engine has hundreds of Aruba Certified Network Security Professional Exam (HPE7-A02) exam dumps that are useful to practice in real time. The HP HPE7-A02 practice questions have a close resemblance with the actual HPE7-A02 exam.
HPE7-A02 exam is a comprehensive test that covers a wide range of topics related to network security, including wireless security, firewall technologies, VPN technologies, intrusion prevention and detection, and network access control. HPE7-A02 Exam consists of 60 multiple-choice questions and candidates are given 90 minutes to complete the exam. A passing score of 70% or higher is required to obtain the certification.
HPE7-A02 Test Torrent and HPE7-A02 Preparation Materials: Aruba Certified Network Security Professional Exam - HPE7-A02 Practice TestOur HPE7-A02 learning quiz is the accumulation of professional knowledge worthy practicing and remembering, so you will not regret choosing our HPE7-A02 study guide. The best way to gain success is not cramming, but to master the discipline and regular exam points of question behind the tens of millions of questions. Our HPE7-A02 Preparation materials can remove all your doubts about the exam. If you believe in our products this time, you will enjoy the happiness of success all your life
HP Aruba Certified Network Security Professional Exam Sample Questions (Q50-Q55):NEW QUESTION # 50
A company has a variety of HPE Aruba Networking solutions, including an HPE Aruba Networking infrastructure and HPE Aruba Networking ClearPass Policy Manager (CPPM). The company passes traffic from the corporate LAN destined to the data center through a third-party SRX firewall. The company would like to further protect itself from internal threats.
What is one solution that you can recommend?
  • A. Have the third-party firewall send Syslogs to CPPM, which can work with network devices to lock internal attackers out of the network.
  • B. Configure CPPM to poll the third-party firewall for a broad array of information about internal clients, such as profile and posture.
  • C. Add ClearPass Device Insight (CPDI) to the solution; integrate it with the third-party firewall to develop more complete device profiles.
  • D. Use tunnel mode SSIDs and user-based tunneling (UBT) on AOS-CX switches to pass all internal traffic directly through the third-party firewall.
To further protect the company from internal threats, you can recommend having the third-party SRX firewall send Syslogs to HPE Aruba Networking ClearPass Policy Manager (CPPM). ClearPass can analyze these logs to detect potential security incidents and coordinate with network devices to respond to threats. By integrating Syslog data from the firewall, CPPM can identify malicious activities and take actions such as locking internal attackers out of the network or triggering specific security policies. This approach enhances the company's internal threat detection and response capabilities.
NEW QUESTION # 51
Your company wants to implement Tunneled EAP (TEAP).
How can you set up HPE Aruba Networking ClearPass Policy Manager (CPPM) to enforce certificated-based authentication for clients using TEAP?
  • A. Select an EAP-TLS-type authentication method for the TEAP method's inner method.
  • B. Select a service certificate when you specify TEAP as a service's authentication method.
  • C. For the service using TEAP, set the authentication source to an internal database.
  • D. Create an authentication method named "TEAP" with the type set to EAP-TLS.
To set up HPE Aruba Networking ClearPass Policy Manager (CPPM) to enforce certificate-based authentication for clients using Tunneled EAP (TEAP), you need to select an EAP-TLS-type authentication method for TEAP's inner method. TEAP allows for a combination of certificate-based (EAP-TLS) and password-based (EAP-MSCHAPv2) authentication. By choosing EAP-TLS as the inner method, you ensure that the clients are authenticated using their certificates, thus enforcing certificate-based authentication within the TEAP framework.
NEW QUESTION # 52
A company uses HPE Aruba Networking ClearPass Policy Manager (CPPM) as a TACACS+ server to authenticate managers on its AOS-CX switches. The company wants CPPM to control which commands managers are allowed to enter. You see there is no field to enter these commands in ClearPass.
How do you start configuring the command list on CPPM?
  • A. Add the Shell service to the managers' TACACS+ enforcement profiles.
  • B. Create an enforcement policy with the TACACS+ type.
  • C. Edit the TACACS+ settings in the AOS-CX switches' network device entries.
  • D. Edit the settings for CPPM's default TACACS+ admin roles.
To control which commands managers are allowed to enter on AOS-CX switches using HPE Aruba Networking ClearPass Policy Manager (CPPM) as a TACACS+ server, you need to add the Shell service to the TACACS+ enforcement profiles for the managers. This service allows you to define and enforce specific command sets and access privileges for users authenticated via TACACS+. By configuring the Shell service in the enforcement profile, you can specify the commands that are permitted or denied for the managers, ensuring controlled and secure access to the switch's command-line interface.
Reference: Aruba's ClearPass Policy Manager documentation provides detailed instructions on setting up TACACS+ services, including configuring Shell profiles for command authorization and enforcement policies.
NEW QUESTION # 53
What is one benefit of integrating HPE Aruba Networking ClearPass Policy Manager (CPPM) with third-party solutions such as Mobility Device Management (MDM) and firewalls?
  • A. CPPM can make the third-party solutions more secure by adding signature-based threat detection capabilities.
  • B. CPPM can offload policy decisions to the third-party solutions, enabling CPPM to respond to authentication requests more quickly.
  • C. CPPM can take over filtering internal traffic so that the third-party solutions have more processing power to devote to filtering external traffic.
  • D. CPPM can exchange contextual information about clients with third-party solutions, which helps make better decisions.
* Contextual Exchange for Better Decisions:
* HPE Aruba ClearPass can integrate with third-party solutions like MDM and firewalls to exchange contextual information about endpoints (e.g., device type, posture, location).
* This integration allows ClearPass and the third-party solutions to make better access control and security decisions.
* For example:
* An MDM can inform CPPM about device compliance, and CPPM can adjust enforcement policies dynamically.
* Firewalls can receive updated context about users and devices to enforce policies more effectively.
* Option Analysis:
* Option A: Correct. Exchanging contextual information improves access control decisions.
* Option B: Incorrect. CPPM does not provide signature-based threat detection.
* Option C: Incorrect. CPPM does not offload policy decisions; it integrates for collaboration.
* Option D: Incorrect. CPPM does not replace third-party traffic filtering capabilities.
NEW QUESTION # 54
Which statement describes Zero Trust Security?
  • A. Companies should focus on protecting their resources rather than on protecting the boundaries of their internal network.
  • B. Companies that support remote workers cannot achieve zero trust security and must determine if the benefits outweigh the cost.
  • C. Companies can achieve zero trust security by strengthening their perimeter security to detect a wider range of threats.
  • D. Companies must apply the same access controls to all users, regardless of identity.
What is Zero Trust Security?
* Zero Trust Security is a security model that operates on the principle of "never trust, always verify."
* It focuses on securing resources (data, applications, systems) and continuously verifying the identity and trust level of users and devices, regardless of whether they are inside or outside the network.
* The primary aim is to reduce reliance on perimeter defenses and implement granular access controls to protect individual resources.
Analysis of Each Option
A:  Companies must apply the same access controls to all users, regardless of identity:
* Incorrect:
* Zero Trust enforces dynamic and identity-based access controls, not the same static controls for everyone.
* Users and devices are granted access based on their specific context, role, and trust level.
B:  Companies that support remote workers cannot achieve zero trust security and must determine if the benefits outweigh the cost:
* Incorrect:
* Zero Trust is particularly effective for securing remote work environments by verifying and authenticating remote users and devices before granting access to resources.
* The model is adaptable to hybrid and remote work scenarios, making this statement false.
C:  Companies should focus on protecting their resources rather than on protecting the boundaries of their internal network:
* Correct:
* Zero Trust shifts the focus from perimeter security (traditional network boundaries) to protecting specific resources.
* This includes implementing measures such as:
* Micro-segmentation.
* Continuous monitoring of user and device trust levels.
* Dynamic access control policies.
* The emphasis is on securing sensitive assets rather than assuming an internal network is inherently safe.
D:  Companies can achieve zero trust security by strengthening their perimeter security to detect a wider range of threats:
* Incorrect:
* Zero Trust challenges the traditional reliance on perimeter defenses (firewalls, VPNs) as the sole security mechanism.
* Strengthening perimeter security is not sufficient for Zero Trust, as this model assumes threats can already exist inside the network.
Final Explanation
Zero Trust Security emphasizes protecting resources at the granular level rather than relying on the traditional security perimeter, which makes C the most accurate description.
References
* NIST Zero Trust Architecture Guide.
* Zero Trust Principles and Implementation in Modern Networks by HPE Aruba.
* "Never Trust, Always Verify" Framework Overview from Cybersecurity Best Practices.
NEW QUESTION # 55
If you are the first time to prepare the HPE7-A02 exam, it is better to choose a type of good study materials. After all, you cannot understand the test syllabus of the HPE7-A02 exam in the whole round. It is important to predicate the tendency of the HPE7-A02 study materials if you want to easily pass the exam. And our HPE7-A02 Exam Questions are the one which can exactly cover the latest information of the exam in the first time for our professionals are good at this subject and you can totally rely on us.
HPE7-A02 Reliable Test Braindumps: https://www.test4engine.com/HPE7-A02_exam-latest-braindumps.html
BONUS!!! Download part of Test4Engine HPE7-A02 dumps for free: https://drive.google.com/open?id=14SPBaMsSuN4MPB3jtCqy0sl66nFQDUP-
Posted at 1/22/2026 22:28:33        Only Author  2#
Thank you for your powerful article, it left a lasting impression. Wishing you success! Heres the free Accurate D-PE-FN-01 answers exam content.
Posted at 1/25/2026 03:05:58        Only Author  3#
DumpTOP에서 출시한 Microsoft인증 MD-102덤프는Microsoft인증 MD-102시험에 대비하여 IT전문가들이 제작한 최신버전 공부자료로서 시험패스율이 100%입니다.DumpTOP는 고품질 Microsoft인증 MD-102덤프를 가장 친근한 가격으로 미래의 IT전문가들께 제공해드립니다. DumpTOP의 소원대로 멋진 IT전문가도 거듭나세요.
Posted at 2/14/2026 01:51:56        Only Author  4#
Thank you for sharing such a motivational article! Free Latest NCP-MCA test simulator test questionswishing everyone the best of luck on their exams!
